【已解决】at 模块发现一个问题:AT+CIPSTATUS 指令回复的数...
发布于 2019-02-20 18:17:20 浏览:4872
* 本帖最后由 tcsun 于 2019-2-21 11:22 编辑 * 我用at 模块其它的AT指令都是好的,今天发现用AT+CIPSTATUS 指令发现数所不完。 我写的查询tcp 联接的函数如下: int L206_get_tcp_status(void) { at_response_t resp = RT_NULL; char *type_connect; char *ip; char *conn_status; int port; resp = at_create_resp(512, 11, rt_tick_from_millisecond(3000)); if (!resp) { rt_kprintf("No memory for response structure!
"); return -RT_ENOMEM; } if (at_exec_cmd(resp, "AT+CIPSTATUS") < 0) { rt_kprintf("get tcp conect status commands error!
"); return -RT_ERROR; } // at_resp_parse_line_args_by_kw(resp, "STATE: ", "STATE: %s", conn_status); // rt_kprintf("connect status:%s
",conn_status); } 打印的数据如下: L206_get_tcp_status msh />L206_get_tcp_status [D/AT] send: 0000-0020: 41 54 2B 43 49 50 53 54 41 54 55 53 AT+CIPSTATUS [D/AT] recvline: 0000-0020: 0D 0A .. [D/AT] recvline: 0000-0020: 22 22 2C 22 49 4E 49 54 49 41 4C 22 0D 0A "","INITIAL".. [D/AT] recvline: 0000-0020: 22 49 4E 49 54 49 41 4C 22 0D 0A "INITIAL".. [D/AT] recvline: 0000-0020: 43 3A 20 34 2C 2C 22 22 2C 22 22 2C 22 22 2C 22 49 4E 49 54 49 41 4C 22 0D 0A C: 4,,"","","","INITIAL".. [D/AT] recvline: 0000-0020: 43 3A 20 35 2C 2C 22 22 2C 22 22 2C 22 22 2C 22 49 4E 49 54 49 41 4C 22 0D 0A C: 5,,"","","","INITIAL".. [E/at.clnt] execute command (AT+CIPSTATUS) timeout (300 ticks)! get tcp conect status commands error! 但我用手动直接发送这个指令AT+CIPSTATUS 或者用at client方式 原始数据是这样的: msh />at client uart2 ======== Welcome to using RT-Thread AT command client cli ======== Cli will forward your command to server port(uart2). Press 'ESC' to exit. AT+CIPSTATUS [D/AT] send: 0000-0020: 03 41 54 2B 43 49 50 53 54 41 54 55 53 .AT+CIPSTATUS OK STATE: CONNECT OK C: 0,0,"TCP","124.193.136.53","8180","CONNECTED" C: 1,,"","","","INITIAL" C: 2,,"","","","INITIAL" C: 3,,"","","","INITIAL" C: 4,,"","","","INITIAL" C: 5,,"","","","INITIAL" ----------------------------------------------------------------- 哪位帮忙指点一下是什么原因,找了半天都没有找出问题!
Cheney_Chen
2019-02-20
1. 可能是串口驱动接收缓冲区过小(默认是64),数据来不及读取就被覆盖 2. 可能是 shell 串口波特率设置过小(默认是115200),日志显示不完全,改为 921600 试试
tcsun
2019-02-21
好的,我先试试,不过在使用at client uart2 时数据是好的!应说明串口设备应没有问题的吧!
tcsun
2019-02-21
@Cheney_Chen 谢谢,修改#define RT_SERIAL_RB_BUFSZ 256 后OK!
4.9k
tcsun
62
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
NXP MCXN947测评之 adc
