新版bsp在哪里修改HSE_VALUE比较好?
发布于 2019-05-07 11:38:52 浏览:2359
新版stm32 bsp的HSE_VALUE在哪定义比较好啊?刚发生个问题,拷贝的原子阿波罗工程,但是我用有源晶振8M,但是发现个问题,在stm32f4xx_hal_conf.h中, #if !defined (HSE_VALUE) #define HSE_VALUE ((uint32_t)25000000U) /*!< Value of the External oscillator in Hz */ #endif /* HSE_VALUE */ 这就需要在某个地方设置HSE_VALUE了,请问在哪好?
z14git
2019-05-07
修改 你的BSP目录/board/CubeMX_Config 下的stm32cubemx工程文件,在cubemx中修改改晶振后,重新生成代码,在cubemx生成的main.c中,复制void SystemClock_Config(void)函数到board.c中
我夏了夏天
2019-05-07
楼上正解
armink
2019-05-07
直接在 keil 工程配置中定义 HSE_VALUE=8000000
春和景明
2019-05-07
>修改 你的BSP目录/board/CubeMX_Config 下的stm32cubemx工程文件,在cubemx中修改改晶振后,重新生成代码, ... --- 谢谢!但是我就是这么弄得啊!但是没有效果。直到我手动修改了HSE_VALUE的定义值。 #define HSE_VALUE ((uint32_t)8000000U) /*!< Value of the External oscillator in Hz */ stm32 HAL库RCC初始化用得着HSE_VALUE的值吗。但是一下函数中并没有修改HSE_VALUE值的代码啊。 一下是我从main.c中拷贝过来的。。。。麻烦看看,有设置错误吗? void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0}; /** Configure the main internal regulator output voltage */ __HAL_RCC_PWR_CLK_ENABLE(); __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); /** Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLM = 8; RCC_OscInitStruct.PLL.PLLN = 336; RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2; RCC_OscInitStruct.PLL.PLLQ = 7; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /** Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) { Error_Handler(); } PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC; PeriphClkInitStruct.PLLSAI.PLLSAIN = 144; PeriphClkInitStruct.PLLSAI.PLLSAIR = 4; PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_4; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK) { Error_Handler(); } }
春和景明
2019-05-07
>直接在 keil 工程配置中定义 HSE_VALUE=8000000 --- env中是否可以加入 配置选项啊
armink
2019-05-07
>env中是否可以加入 配置选项啊 --- 技术上都能实现,但是没必要呀,哪有 BSP 板子上的晶振会变的。 env 配置的是一些经常变更的配置。
z14git
2019-05-07
没有效果说明你操作有误,重新用cubemx生成代码后,stm32f4xx_hal_conf.h里的定义也会更新的
2.4k
春和景明
46
48
STM32 407 串口接收数据 系统卡死
RTT nrf24l01 设备驱动程序
stm32f10x串口只能发送数据,无法接收
rt-thread线程调度异常在stm32f103芯片上
RTT是否支持STM32F429
rt-thread在stm32f411下的移植问题
