wifi 88w8782固件传输完成,cmd id 0xa9超时
发布于 2019-01-17 11:28:36 浏览:3126
* 本帖最后由 _Tony_ 于 2019-1-17 14:17 编辑 * 请教一个问题,MCU是ARM9,使用RT-Thread SDIO驱动框架能成功读写sd卡,换成88w8782 wifi传输完固件,发送命令0xa9(HostCmd_CMD_FUNC_INIT)响应超时了,具体log见附件。请问一下,这一般是什么原因造成的? wlan: Loading MWLAN driver vendor=0x02DF device=0x9121 class=0 function=1 rx_work=0 cpu_num=1 Wlan: FW download over, firmwarelen=254036 downloaded 254036 WLAN FW is active Timeout cmd id (32.560000) = 0xa9, act = 0x0 a9 00 08 00 01 00 00 00 00 00 00 00 00 00 00 00 BSS type = 0 BSS role= 0 ------------Dump info----------- Commmand Timeout pending command id: 0x3 ioctl_buf=00000000 pending command id: 0xd9 ioctl_buf=00000000 pending command id: 0xe4 ioctl_buf=00000000 pending command id: 0xe4 ioctl_buf=00000000 pending command id: 0xd6 ioctl_buf=00000000 pending command id: 0x1e ioctl_buf=00000000 pending command id: 0x83 ioctl_buf=00000000 pending command id: 0xdf ioctl_buf=00000000 pending command id: 0x28 ioctl_buf=00000000 No pending scan command 下载附件 [log.txt](https://oss-club.rt-thread.org/uploads/201901/17/141659x8zqvfpzw720yyf8.txt)
2019-01-21
命令0xa9的响应是resp是哪种类型? 是否驱动中没有支持?
_Tony_
2019-01-21
[i=s] 本帖最后由 _Tony_ 于 2019-1-21 16:44 编辑 [/i] >命令0xa9的响应是resp是哪种类型? 是否驱动中没有支持? --- 以下是对应的log,看着是有响应的。wlan_init_fw 返回对应是MLAN_STATUS_PENDING,不知道有没有什么影响? DNLD_CMD (46.265000): 0xa9, act 0x0, len 8, seqno 0x1 DNLD_CMD: a9 00 08 00 01 00 00 00 Enter: wlan_sdio_host_to_card Enter: wlan_write_data_sync [D/SDIO] CMD:53 ARG:0x92000100 RES:R5 rw:w len:256 blksize:256 [I/SDIO] resp[0] = 0x00002000 Leave: wlan_write_data_sync SDIO Blk Wr: 0c 00 01 00 a9 00 08 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Leave: wlan_sdio_host_to_card Leave: wlan_dnld_cmd_to_fw Leave: wlan_exec_next_cmd Leave: mlan_main_process Leave: wlan_init_fw wlan_init_fw returned ret=0x1 Leave: mlan_init_fw Enter: wlan_cmd_timeout_func Timeout cmd id (66.331000) = 0xa9, act = 0x0 a9 00 08 00 01 00 00 00 00 00 00 00 00 00 00 00 BSS type = 0 BSS role= 0
2019-01-21
>[D/SDIO] CMD:53 ARG:0x92000100 RES:R5 rw:w len:256 blksze:256 我是说这个,你看下是否有没处理全的响应类型,每个命令可能有自己对应的响应类型 另外,SDIO也可以用逻辑分析仪来抓,这样比较直观。抓的时候速度调低些。
2019-01-21
看了你日志,可能我理解有误,你这个A9是你WIFI模块本身的命令。 不是SDIO的。 所以你得检查模块和固件本身。 1。 A9之外其它的命令是否有响应?还是A9是第一个? 2。 固件是否成功下载进去了?可能下载的数据出了错? 3。 固件本身是否与模块匹配? 不然固件可能 无法2次boot 4。 more...
_Tony_
2019-01-21
>看了你日志,可能我理解有误,你这个A9是你WIFI模块本身的命令。 >不是SDIO的。 --- 1、0x00a9(HostCmd_CMD_FUNC_INIT)是第一个发出的模块命令,后续也都无法识别,后面有丢出信息 QUEUE_CMD: cmd=0xa9 is queued QUEUE_CMD: cmd=0x3 is queued QUEUE_CMD: cmd=0xd9 is queued ... ------------Dump info----------- Commmand Timeout pending command id: 0x3 ioctl_buf=00000000 pending command id: 0xd9 ioctl_buf=00000000 pending command id: 0xe4 ioctl_buf=00000000 ... 2、固件有传输过去了。若固件在传输过程中传输错误,会报CRC错误,并多次尝试重传,都失败后,会提示固件传输失败并终止传输。 3、固件是 \packages\wlanmarvell-latest\FwImage 对应型号的镜像,应该不会错的。wifi packages是latest版本;
jw__liu
2019-03-11
关注中
_Tony_
2019-11-18
问题解决了,忘记结贴了! 将SD主机时钟一直开着,空闲的时候也让时钟一直在跑,就没出现crc错误,wifi模块也能正常驱动使用了! 可能空闲时候关闭SD时钟,通过其他方式也可以解决问题,后面没有再去深究了。
2019-11-18
见过有些芯片要靠SDIO时钟活着,不能关掉省电。 甚至要求SDIO只能是特定的几个频率。 这应该和芯片的硬件设计有关。
_Tony_
2019-11-18
>见过有些芯片要靠SDIO时钟活着,不能关掉省电。 >甚至要求SDIO只能是特定的几个频率。 >这应该和芯片的硬件设 ... --- 感谢前段时间的指导,感恩!:handshake
3.1k
_Tony_
代码分享,stm32f407的sdio驱动。
求个在STM32F103 RTT上使用SDIO接口的例子
是否能增加一个 SDIO AP61xx 的驱动呢
sdio和fsmc驱动lcd冲突
关于rt-thread系统sdio驱动框架使用
sdio驱动是怎么使用的?也没有文档和例程啊
