RT-Thread发布
SVN-1621版本LWIP BUG
发布于 2011-07-10 15:03:06 浏览:7861
这两天更新到svn1623版本后,出现系统启动失败的情况,打印信息如下: \ | / - RT - Thread Operating System / | \ 0.4.0 build Jul 10 2011 2006 - 2011 Copyright by rt-thread team thread:?0 ?0 ??0 ??0 ??0 ??0 ??0 ??0 ??0 ??0 ?0 ?0 ?0 ?0 ?0 ?0 ?0 ?0 $?0 $?0 ,?0 ,?0 4?0 4?0 0 0 D?0 D?0 L?0 L?0 thread pri status sp stack size max used left tick error -------- ---- ------- ---------- ---------- ---------- ---------- --- etx 0x90 suspend 0x00000044 0x00000400 0x00000114 0x00000010 000 erx 0x90 suspend 0x000000ac 0x00000400 0x000000ac 0x0000000f 000 ---到此死机 经过版本跟踪后确定问题出在svn1621版本的更新上,svn1621更新了如下文件: U components/net/lwip-1.4.0/src/arch/include/arch/cc.h U components/net/lwip-1.4.0/src/arch/sys_arch.c U components/net/lwip/src/arch/include/arch/cc.h U components/net/lwip/src/arch/sys_arch.c 我使用的是lwip不是lwip-1.4.0,经过比较代码改动如下: luohui@luohui-desktop:/work/mywork/RT-Thread/svn/rt-thread$ svn diff -r 1620:1621 components/net/lwip/src/arch/sys_arch.c Index: components/net/lwip/src/arch/sys_arch.c =================================================================== --- components/net/lwip/src/arch/sys_arch.c (版本 1620) +++ components/net/lwip/src/arch/sys_arch.c (版本 1621) @@ -224,20 +224,29 @@ return t; } -sys_prot_t sys_arch_protect(void) -{ - /* disable interrupt */ - return rt_hw_interrupt_disable(); +sys_prot_t sys_arch_protect(void) +{ + rt_base_t level; + + /* disable interrupt */ + level = rt_hw_interrupt_disable(); + + /* must also lock scheduler */ + rt_enter_critical(); + + return level; +} + +void sys_arch_unprotect(sys_prot_t pval) +{ + /* unlock scheduler */ + rt_exit_critical(); + + /* enable interrupt */ + rt_hw_interrupt_enable(pval); + + return; } - -void sys_arch_unprotect(sys_prot_t pval) -{ - /* enable interrupt */ - rt_hw_interrupt_enable(pval); - - return; -} - void sys_arch_assert(const char* file, int line) { rt_kprintf("
Assertion: %d in %s, thread %s
", line, file, luohui@luohui-desktop:/work/mywork/RT-Thread/svn/rt-thread$ svn diff -r 1620:1621 components/net/lwip/src/arch/include/arch/cc.h Index: components/net/lwip/src/arch/include/arch/cc.h =================================================================== --- components/net/lwip/src/arch/include/arch/cc.h (版本 1620) +++ components/net/lwip/src/arch/include/arch/cc.h (版本 1621) @@ -92,9 +92,6 @@ #define LWIP_PLATFORM_DIAG(x) do {rt_kprintf x;} while(0) #define LWIP_PLATFORM_ASSERT(x) { rt_kprintf(x); sys_arch_assert(__FILE__, __LINE__); } -#define SYS_ARCH_DECL_PROTECT(x) -#define SYS_ARCH_PROTECT(x) -#define SYS_ARCH_UNPROTECT(x) #include "string.h" 请帮忙确定这个问题原因。
2011-07-10
9260平台吧,一启动就死掉了?刚从北京回来,我问问。
mbbill
2011-07-10
我觉得这个patch没有问题。而是暴露出原先就潜藏的一些bug。 粗略的看了一下代码,9260平台的rtthread_startup()函数调用了lwip_sys_init(),这是不应该的。 lwip_sys_init 不是一个可重入的函数,它里面会间接的调用到malloc或者send_sem之类的东西,所以只能在线程上下文里面用,不能在上电以后进入第一个task之前关中断的时候调用。 上个月我提交过的一个补丁一方面就是用来发现这一类问题的,你可以试着在rtthread_startup的头尾加上 rt_interrupt_enter 和rt_interrupt_leave,然后打开RT_DEBUG宏。
weety
2011-07-11
>9260平台吧,一启动就死掉了?刚从北京回来,我问问。 --- 是9260平台,一启动就死掉了,是我这边的问题,我再仔细调调。
weety
2011-07-11
>我觉得这个patch没有问题。而是暴露出原先就潜藏的一些bug。 >粗略的看了一下代码,9260平台的rtthread_startup()函数调用了lwip_sys_init(),这是不应该的。 >lwip_sys_init 不是一个可重入的函数,它里面会间接的调用到malloc或者send_sem之类的东西,所以只能在线程上下文里面用,不能在上电以后进入第一个task之前关中断的时候调用。 > >上个月我提交过的一个补丁一方面就是用来发现这一类问题的,你可以试着在rtthread_startup的头尾加上 rt_interrupt_enter 和rt_interrupt_leave,然后打开RT_DEBUG宏。 --- 我已经加入了上述代码,并打开了RT_DEBUG、SCHEDULER_DEBUG、RT_THREAD_DEBUG 等宏,没有额外的打印信息,还是上面提到的那些信息。
2011-07-12
看到你把代码修改成初始化线程去调用lwip初始化函数,这样做以后是否依然还有问题?
mbbill
2011-07-12
[http://code.google.com/p/rt-thread/source/detail?r=1623](http://code.google.com/p/rt-thread/source/detail?r=1623)
weety
2011-07-12
这个问题我在仔细查查看,目前应该确认是在lwip初始化时,调度器还没有初始化,然后给调度器上锁后导致的问题,具体这样改动后有没有影响我再继续跟踪下。
7.9k
weety
60
RT-Thread单内核v0.2.2正式版
[发布] RT-Thread RTOS v0.2.3版本
RT-Thread 0.3.0 beta
RT-Thread/STM32 0.3.0 RC1发布
RT-Thread/LM3S 0.3.0 RC1版发布
建议弄个MIPS版本的。龙芯上用。
开源实时操作系统RT-Thread 0.3.0正式版发布
关于RT-THREAD的UDP讨论
这里是BUG回报板块!
【学习分享】初探RT-Thread系统调度
NXP MCXN947测评之 I2C (硬件) 实践
