关于中断上下文切换部分代码的问题
发布于 2019-03-09 16:55:19 浏览:2493
```rt_hw_context_switch_interrupt: /** 1.判断rt_thread_switch_interrupt_flag变量的值是否为1 */ ldr r2, =rt_thread_switch_interrupt_flag/** 加载变量rt_thread_switch_interrupt_flag的地址到r2寄存器中 */ ldr r3, [r2] /** 读取rt_thread_switch_interrupt_flag寄存器的值到R3寄存器中 */ cmp r3, #1 /** 判断rt_thread_switch_interrupt_flag的值是否为1 */ /** 如果rt_thread_switch_interrupt_flag值为1 */ beq _reswitch /** 如果rt_thread_switch_interrupt_flag值为1,跳转到标号_reswitch执行 */ mov r3, #1 /** 如果rt_thread_switch_interrupt_flag值为0,将其值设置为1 */ str r3, [r2] ldr r2, =rt_interrupt_from_thread /** 加载rt_interrupt_from_thread变量的地址到R2寄存器中 */ str r0, [r2] /** 将被切换出的线程的栈顶地址保存到变量rt_interrupt_from_thread中 */ _reswitch: ldr r2, =rt_interrupt_to_thread /** 加载rt_interrupt_to_thread变量的地址到R2寄存器中 */ str r1, [r2] /** 将被切入的线程的栈顶地址保存到变量rt_interrupt_to_thread中 */ mov pc, lr ```上面是中断上下文切换的代码。发现rt_hw_context_switch_interrupt并没有完成线程的切换,只是用全局变rt_interrupt_from_thread和rt_interrupt_to_thread保存了被换出和换入的线程的栈顶指针,而真正的切换过程在中断处理中完成。 如下: ```IRQ_Handler PROC STMFD SP!, {R0-R12,LR} BL rt_interrupt_enter BL rt_hw_trap_irq BL rt_interrupt_leave LDR R0, =rt_thread_switch_interrupt_flag LDR R1, [R0] CMP R1, #1 BEQ rt_hw_context_switch_interrupt_do LDMFD SP!, {R0-R12,LR} SUBS PC, LR, #4 ENDP rt_hw_context_switch_interrupt_do PROC MOV R1, #0 ; Clear flag STR R1, [R0] ; Save to flag variable LDMFD SP!, {R0-R12,LR} ; Reload saved registers STMFD SP, {R0-R2} ; Save R0-R2 SUB R1, SP, #4*3 ; Save old task's SP to R1 SUB R2, LR, #4 ; Save old task's PC to R2 MRS R0, SPSR ; Get CPSR of interrupt thread MSR CPSR_c, #MODE_SVC:OR:NOINT ; Switch to SVC mode and no interrupt STMFD SP!, {R2} ; Push old task's PC STMFD SP!, {R3-R12,LR} ; Push old task's LR,R12-R3 LDMFD R1, {R1-R3} STMFD SP!, {R1-R3} ; Push old task's R2-R0 STMFD SP!, {R0} ; Push old task's CPSR LDR R4, =rt_interrupt_from_thread LDR R5, [R4] ; R5 = stack ptr in old tasks's TCB STR SP, [R5] ; Store SP in preempted tasks's TCB LDR R6, =rt_interrupt_to_thread LDR R6, [R6] ; R6 = stack ptr in new tasks's TCB LDR SP, [R6] ; Get new task's stack pointer LDMFD SP!, {R4} ; Pop new task's SPSR MSR SPSR_cxsf, R4 LDMFD SP!, {R0-R12,LR,PC}^ ; pop new task's R0-R12,LR & PC SPSR to CPSR ENDP```但是有个问题,就是如何触发的中断呢?我看ST是通过手动触发PendSV 异常来触发这个中断然后跳到中断里的(自动保存一部分上下文)。跟arm9的这个上下文切换不太一样。
yqiu
2019-03-09
可以参考下这个文档 [https://www.rt-thread.org/document/site/programming-manual/porting/porting/](https://www.rt-thread.org/document/site/programming-manual/porting/porting/)
还没想好
2019-03-09
需要切换任务时,会主动往一个寄存器里面写 1 ,触发PendSV 中断。 然后 CPU 就会在合适的时候响应 PendSV 中断。在中断中完成任务切换
Cold
2019-03-12
>需要切换任务时,会主动往一个寄存器里面写 1 ,触发PendSV 中断。 然后 CPU 就会在合适的时候响应 PendSV ... --- 你说的这个是ST的方式,AMR9不是这样的,内核不一样
Cold
2019-03-12
>可以参考下这个文档 https://www.rt-thread.org/document/site/programming-manual/porting/porting/ ... --- 谢了,找打想要的答案了~
Cold
2020-06-10
补充上来: 在不同的 CPU 架构里,线程之间的上下文切换和中断到线程的上下文切换,上下文的寄存器部分可能是有差异的,也可能是一样的。在 Cortex-M 里面上下文切换都是统一使用 PendSV 异常来完成,切换部分并没有差异。但是为了能适应不同的 CPU 架构,RT-Thread 的 libcpu 抽象层还是需要实现三个线程切换相关的函数: 1) rt_hw_context_switch_to():没有来源线程,切换到目标线程,在调度器启动第一个线程的时候被调用。 2) rt_hw_context_switch():在线程环境下,从当前线程切换到目标线程。 3) rt_hw_context_switch_interrupt ():在中断环境下,从当前线程切换到目标线程。 在线程环境下进行切换和在中断环境进行切换是存在差异的。线程环境下,如果调用 rt_hw_context_switch() 函数,那么可以马上进行上下文切换;而在中断环境下,需要等待中断处理函数完成之后才能进行切换。 由于这种差异,在 ARM9 等平台,rt_hw_context_switch() 和 rt_hw_context_switch_interrupt() 的实现并不一样。在中断处理程序里如果触发了线程的调度,调度函数里会调用 rt_hw_context_switch_interrupt() 触发上下文切换。中断处理程序里处理完中断事务之后,中断退出之前,检查 rt_thread_switch_interrupt_flag 变量,如果该变量的值为 1,就根据 rt_interrupt_from_thread 变量和 rt_interrupt_to_thread 变量,完成线程的上下文切换。**** 在 Cortex-M 处理器架构里,基于自动部分压栈和 PendSV 的特性,上下文切换可以实现地更加简洁。
2.5k
Cold
50
