RTThread 在x86的安装及编程问题
发布于 2019-04-07 17:32:23 浏览:3329
目前打算在PC104上开发软件,看到RTthread支持x86,就想试一下,但到x86BSP子目录下,用scons进行编译,但提示没有安装VS,请问后续应该安装何版本的VS,具体如何编译,此外我还想用menuconfig其进行设置,但提示没有Kconfig文件,后续如何做?还有,有没有x86方面的例程或文档提供?不盛感激!
lookit
2019-04-08
>可以把问题描述的清晰点。 >或者你可以先看env常见问题中是否有答案[https://www.rt-thread.org/document/sit](https://www.rt-thread.org/document/sit) ... --- DELL@DELL-PC D:\rt\master\rt-thread-master\bsp\x86 > gcc -v Using built-in specs. Target: mingw32 Configured with: ../gcc-4.2.1-2-src/configure --with-gcc --enable-libgomp --host=mingw32 --build=mingw32 --target=mingw32 --program-suffix=-sjlj --with-arch=i486 --with-tune=generic --disable-werror --prefix=/mingw --with-local-prefix=/mingw --enable-threads --disable-nls --enable-languages=c,c++,fortran,objc,obj-c++,ada --disable-win32-registry --enable-sjlj-exceptions --enable-libstdcxx-debug --enable-cxx-flags=-fno-function-sections -fno-data-sections --enable-version-specific-runtime-libs --disable-bootstrap Thread model: win32 gcc version 4.2.1-sjlj (mingw32-2) DELL@DELL-PC D:\rt\master\rt-thread-master\bsp\x86 > scons scons: Reading SConscript files ... '"D:\rt\env_released_1.1.1\env\tools\ConEmu\ConEmu\..\..\..\tools\gnu_gcc\arm_gcc\mingw\bin\gcc -m32 -fno-builtin -fno-stack-protector -nostdinc"' is not recognized as an internal or external command, operable program or batch file. scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build CC build\applications\application.o Error in calling command:gcc Exception: No such file or directory Please check Toolchains PATH setting.明明有安装有GCC,却偏偏说找不到GCC。
2019-04-08
编译x86分支?这个你需要在linux下,使用make、scons应该都可以
lookit
2019-04-08
>编译x86分支?这个你需要在linux下,使用make、scons应该都可以 --- 那我来试试
lookit
2019-04-08
>DELL@DELL-PC D:\rt\master\rt-thread-master\bsp\x86 >> gcc -v >Using built-in specs. --- 逐行对比stm32f429-apollo及x86的rtconfig.py终于明白原因了,x86的rtconfig.py的第35行为PREFIX = '',而stm32f429-apollo的第33行是PREFIX = 'arm-none-eabi-',而到=D:\rt\env_released_1.1.1\env\tools\ConEmu\ConEmu\..\..\..\tools\gnu_gcc\arm_gcc\mingw\bin,也即D:\rt\env_released_1.1.1\env\ tools\gnu_gcc\arm_gcc\mingw\bin目录下发现只有arm-none-eabi-gcc.exe,而没有gcc.exe,因此出现找不到gcc文件的错误提示也就理所应当了。
lookit
2019-04-09
>编译x86分支?这个你需要在linux下,使用make、scons应该都可以 --- 我尝试过了,还是编译不过,卡在没有rtdevice.h上
2019-04-09
唔,还果真是。这个应该是不支持menuconfig的缘故,rtdevice.h在components/drivers/include目录下
tangdachan
2019-09-11
>唔,还果真是。这个应该是不支持menuconfig的缘故,rtdevice.h在components/drivers/include目录下 ... --- 那请问这个问题要怎么解决呢?
2019-09-11
>那请问这个问题要怎么解决呢? --- 最好是有支持newlib的x86 gcc工具链
tangdachan
2019-09-12
>最好是有支持newlib的x86 gcc工具链 --- 不过x86是不是不支持多核啊:L
2019-09-12
>不过x86是不是不支持多核啊 --- 对,还没支持多核。你要用于什么场合?
3.3k
lookit
STM32 407 串口接收数据 系统卡死
RTT nrf24l01 设备驱动程序
stm32f10x串口只能发送数据,无法接收
rt-thread线程调度异常在stm32f103芯片上
RTT是否支持STM32F429
rt-thread在stm32f411下的移植问题
MCXN947测评系列(二)串口设备测评
猪的行独
