网络学习营
[ 学习 ] STM32 HAL enc28j60 初始化配置
发布于 2019-04-08 14:59:19 浏览:2764
* 本帖最后由 wuhanstudio 于 2019-4-8 15:08 编辑 * 如果 enc28j60 也能像 AT 组件那样直接在 env 里配置设备名,加上 CS、INT、RST 引脚,然后自动初始化就好了。 ```[ ] Enable at device init by thread (NEW)``` ![FastAdmin]() ENC28J60 初始化 1. 首先在 env 里面选择 SPI 和ENC28J60```RT-Thread Components ---> Device Drivers ---> (*) Using SPI Bus/Device device drivers (*) Using ENC28J60 SPI Ethernet network interface``` 2. 生成项目 scons --target=mdk5 -s,并新建文件 drv_enc28j60.c 添加到 Drivers ![TIM截图20190408154234.png](/uploads/201904/08/144704ihhawubrh5k8cqqv.png) 3. 编辑 drv_enc28j60.c ```#include
#define ENC28J60_BUS "spi1" #define ENC28J60_DEVICE "spi10" // ENC28J60_CS // ENC28J60_MISO // ENC28J60_MOSI #define ENC28J60_CS 14 // PA0 for STM32F103RC defined in drv_gpio.c #define ENC28J60_INT 15 // PA1 for STM32F103RC defined in drv_gpio.c #define ENC28J60_RESET 20 // PA4 for STM32F103RC defined in drv_gpio.c void enc28j60_int_handler(void *args) { /* enter interrupt */ rt_interrupt_enter(); enc28j60_isr(); /* leave interrupt */ rt_interrupt_leave(); } static int rt_hw_enc28j60_init(void) { /* Configure SPI */ extern rt_err_t stm32_spi_bus_attach_device(rt_uint32_t pin, const char *bus_name, const char *device_name); stm32_spi_bus_attach_device(ENC28J60_CS, ENC28J60_BUS, ENC28J60_DEVICE); /* Configure Reset */ rt_pin_mode(ENC28J60_RESET, PIN_MODE_INPUT_PULLUP); rt_pin_write(ENC28J60_RESET,0); rt_thread_delay(1); rt_pin_write(ENC28J60_RESET,1); enc28j60_attach(ENC28J60_DEVICE); /* Configure Interrupt */ rt_pin_mode(ENC28J60_INT, PIN_MODE_INPUT_PULLUP); rt_pin_attach_irq(ENC28J60_INT, PIN_IRQ_MODE_FALLING, enc28j60_int_handler, (void*)"callbackargs"); rt_pin_irq_enable(ENC28J60_INT, PIN_IRQ_ENABLE); return 0; } INIT_DEVICE_EXPORT(rt_hw_enc28j60_init); ``` 4. 上传代码就能 ping 通了 ![TIM截图20190408154528.png](/uploads/201904/08/144949umh2z52z52z2k0vo.png) ![FastAdmin](https://www.rt-thread.org/qa/static/image/hrline/line5.png) > 参考链接: [https://www.rt-thread.org/qa/for ... &highlight=enc28j60](https://www.rt-thread.org/qa/forum.php?mod=viewthread&tid=7985&highlight=enc28j60)
iot小胡
2019-07-26
我这个显示这个报错,里面的stm32_spi_bus_attach_device找不到,这是什么情况 .\build\keil\Obj\rt-thread.axf: Error: L6218E: Undefined symbol stm32_spi_bus_attach_device (referred from drv_enc28j60.o).
wuhanstudio
2019-07-27
>我这个显示这个报错,里面的stm32_spi_bus_attach_device找不到,这是什么情况 >.\build\keil\Obj\rt-thread ... --- 最新的 rt-thread 把 stm32_spi_bus_attach_device 改为了 rt_hw_spi_device_attach,换个名字就好了
iot小胡
2019-08-13
>最新的 rt-thread 把 stm32_spi_bus_attach_device 改为了 rt_hw_spi_device_attach,换个名字就好了 ... --- 已经解决了,谢谢啦
2.8k
wuhanstudio
242
【LWIP学习营】第一关开发环境搭建
LWIP学习营第一周入门移植问题汇总贴
【LWIP学习营】f407+lan8720A小结
【LwIP学习营】【第一周】仅零散记录,无主题
【LwIP学习营】【第一周】LWIP移植
【LwIP学习营】【第一周】开发板适配
【LwIP学习营】【第一周】环境搭建和配置验证
