STM32L0
STM32L071从deep sleep唤醒之后时钟的问题
发布于 2019-06-20 15:10:01 浏览:2687
deep sleep之前sysclk采用的是16M的HSI,但从deep sleep唤醒回到进入normal run模式状态之后就变成了只有2MHz,不知道在哪个地方被修改关闭了HSI。 程序本身没有关闭HSI的操作 ![1.png](/uploads/201906/20/150933dy6em60mblbbyg0z.png)
Tristan_C
2019-06-20
文中是休眠前的,补充休眠到run之后的时钟情况,HSI被关闭了 看了pm组件,里面是有void run(struct rt_pm *pm, uint8_t mode)函数的,但跟踪调试发现似乎没有被调用,不知道这个问题有没有讲究,清大神门指点一二,感激不尽!
Tristan_C
2019-06-20
无奈之下注册了休眠状态改变事件 在事件回调函数中,退出休眠事件RT_PM_EXIT_SLEEP的话,重新配置时钟,就可以正常,HSI恢复运行,但这样的PM模式使用起来就得不停切换配置时钟了,请大神门指点呢。 ```c rt_pm_notify_set(sleep_switch, RT_NULL); void sleep_switch(uint8_t event, uint8_t mode, void *data) { if(RT_PM_ENTER_SLEEP == event) { rt_pin_write(LED0_PIN, PIN_LOW); } else if(RT_PM_EXIT_SLEEP == event) { rt_pin_write(LED0_PIN, PIN_HIGH); SystemClock_Config(); } } ``` 时钟配置函数如下: ```c void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInit = {0}; /**Configure the main internal regulator output voltage */ __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); /**Configure LSE Drive Capability */ HAL_PWR_EnableBkUpAccess(); __HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW); /**Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE; RCC_OscInitStruct.LSEState = RCC_LSE_ON; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /**Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK) { Error_Handler(); } } ``` ![2nn7.png](https://club.rt-thread.org/uploads/201906/20/162014imfk7bfo2b7o2nn7.png)
Tristan_C
2019-06-20
问题已经解决,STM32L071系列芯片需要手动配置从stop(sleep模式)状态切换到active(run模式)时,采用的时钟时MSI还是HSI,系统初始化的时候时钟配置加上下面这句代码即可 ``` /**Ensure that HSI is wake-up system clock */ __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI); ```
水清沙白
2019-06-20
>问题已经解决,STM32L071系列芯片需要手动配置从stop(sleep模式)状态切换到active(run模式)时,采用的 ... --- STM32 的 STOP 模式会把时钟关掉的,唤醒后用用的是一个很低速的时钟,L4 系列上是 HSI,需要重新配置时钟树。
Tristan_C
2019-06-25
我用的是L0,休眠前配置了主时钟为HSI,休眠之后再唤醒默认采用MSI,需要在初始化的时候配置唤醒时钟采用HSI,才可以,要不然RTT的系统tick就出问题了
shao7936626
2019-09-26
L071的BSP哪里来的
ARMVvN
2021-04-09
```c __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_HSI); ``` 这句话我在工程中找不到,楼主是否可以提供在哪个.h文件中,或者CUBEMX如何配置才有。 万分感谢
2.7k
Tristan_C
27
STM32L0 drv_usart.c的BUG及解决【已解决】
stm32l051上移植rtt或求BSP
有没有人在STM32L051XX上移植RTT的?
STM32L0的RTC时间非常快
STM32L051c8生成nano终端端口选择LPUART1不能正常输出
stm32L053C8Tx加入Watchdog后系统一直反复重启
STM32L051 ,M0 的 CPULIB 支持 M0+ 的嘛??
Nano L071RB Jlink下载程序触发Hard fault
STM32L071芯片sleep切换到run之后,需要重新手动配置系统时钟吗
MCXN947测评系列(二)串口设备测评
