内核学习营
risc-v_RISCV
scons编译rv32m1_vega ri5cy内核报错
发布于 2019-07-06 19:13:57 浏览:1827
[tocm] 编译主机: win10 env版本: env_released_1.1.2 内核目录: rt-thread t-thread\bsp v32m1_vega i5cy # 操作步骤: ## step0 执行env.bat ## step1 执行scons, 报错如下: ``` > scons scons: Reading SConscript files ... scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build CC build\applications\main.o Error in calling command:riscv-none-embed-gcc Exception: No such file or directory Please check Toolchains PATH setting. scons: *** [build\applications\main.o] Error 2 scons: building terminated because of errors. ``` ## 问题 riscv-none-embed-gcc 已加入系统变量 ``` PS C:\Users\Administrator> riscv-none-embed-gcc riscv-none-embed-gcc.exe: fatal error: no input files compilation terminated. ``` 还有什么设置要做? 麻烦各位了。
2019-07-08
env是属于主动设置环境变量,所以你需要在env里把环境变量设置下,指向到你按照RISC-V GCC的目录 例如在env终端控制台下,输入命令进行设置: ``` set RTT_EXEC_PATH=E:\Tools\env\tools\ConEmu\ConEmu\..\..\..\tools\gnu_gcc\riscv64\bin ``` 方便起见,你也可以在env/conemu中主动配置一项RISC-V相关的配置。可以把 ``` env\tools\ConEmu\ConEmu\CmdInit.cmd ``` 修改下,命名成CmdInitRV.cmd(如果你只用RISC-V,则直接改上面文件也就可以了)
wuhanstudio
2019-07-08
scons 会在 rtconfig.py 里面获取工具链 ``` if CROSS_TOOL == 'gcc': PLATFORM = 'gcc' EXEC_PATH = r'/opt/unknown-gcc/bin' else: print('Please make sure your toolchains is GNU GCC!') exit(0) if os.getenv('RTT_EXEC_PATH'): EXEC_PATH = os.getenv('RTT_EXEC_PATH') ```
2019-07-08
>scons 会在 rtconfig.py 里面获取工具链 但是会优先使用环境变量的,所以对于env,还是一定得配环境变量,仅rtconfig.py中配置会被覆盖掉的。
wuhanstudio
2019-07-08
>但是会优先使用环境变量的,所以对于env,还是一定得配环境变量,仅rtconfig.py中配置会被覆盖掉的。 ... 哈哈,熊大说得对,RTT_EXEC_PATH 得要,想和他说明一下 scons 的配置文件在哪里可以找到 :P
carl_cai
2019-07-08
感谢各位的帮助, 已成功构建: ``` > scons scons: Reading SConscript files ... scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build CC build\board\board.o CC build\board\clock_config.o CC build\board\fsl_host.o CC build\board\pin_mux.o CC build\driver\drv_gpio.o CC build\driver\drv_sdcard.o CC build\driver\drv_uart.o CC build\kernel\components\dfs\filesystems\devfs\devfs.o CC build\kernel\components\dfs\filesystems\elmfat\dfs_elm.o CC build\kernel\components\dfs\filesystems\elmfat\ff.o CC build\kernel\components\dfs\filesystems\elmfat\option\ccsbcs.o CC build\kernel\components\dfs\src\dfs.o CC build\kernel\components\dfs\src\dfs_file.o CC build\kernel\components\dfs\src\dfs_fs.o CC build\kernel\components\dfs\src\dfs_posix.o CC build\kernel\components\dfs\src\poll.o CC build\kernel\components\dfs\src\select.o CC build\kernel\components\drivers\misc\pin.o CC build\kernel\components\drivers\rtc\rtc.o CC build\kernel\components\drivers\serial\serial.o CC build\kernel\components\drivers\src\completion.o CC build\kernel\components\drivers\src\dataqueue.o CC build\kernel\components\drivers\src\pipe.o CC build\kernel\components\drivers\src\ringblk_buf.o CC build\kernel\components\drivers\src\ringbuffer.o CC build\kernel\components\drivers\src\waitqueue.o CC build\kernel\components\drivers\src\workqueue.o CC build\kernel\components\finsh\cmd.o CC build\kernel\components\finsh\msh.o CC build\kernel\components\finsh\msh_cmd.o CC build\kernel\components\finsh\msh_file.o CC build\kernel\components\finsh\shell.o CC build\kernel\components\finsh\symbol.o CC build\kernel\components\libc\compilers\common\gmtime_r.o CC build\kernel\components\libc\compilers\newlib\libc.o CC build\kernel\components\libc\compilers\newlib\libc_syms.o CC build\kernel\components\libc\compilers\newlib\stdio.o CC build\kernel\components\libc\compilers\newlib\syscalls.o CC build\kernel\components\libc\compilers\newlib\time.o CC build\kernel\components\utilities\ulog\backend\console_be.o CC build\kernel\components\utilities\ulog\ulog.o AS build\kernel\libcpu\risc-v\common\context_gcc.o CC build\kernel\libcpu\risc-v\common\cpuport.o CC build\kernel\libcpu\risc-v\rv32m1\interrupt.o AS build\kernel\libcpu\risc-v\rv32m1\interrupt_gcc.o CC build\kernel\src\clock.o CC build\kernel\src\components.o CC build\kernel\src\cpu.o CC build\kernel\src\device.o CC build\kernel\src\idle.o CC build\kernel\src\ipc.o CC build\kernel\src\irq.o CC build\kernel\src\kservice.o CC build\kernel\src\mem.o CC build\kernel\src\mempool.o CC build\kernel\src\object.o CC build\kernel\src\scheduler.o CC build\kernel\src\signal.o CC build\kernel\src\thread.o CC build\kernel\src\timer.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\system_RV32M1_ri5cy.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_clock.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_common.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_lpuart.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_gpio.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_msmc.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_usdhc.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\drivers\fsl_intmux.o AS E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\devices\RV32M1\gcc\startup_RV32M1_ri5cy.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\sdmmc_2.1.2\src\fsl_sd.o CC E:\rt-thread\bsp\rv32m1_vega\rv32m1_sdk_riscv\sdmmc_2.1.2\src\fsl_sdmmc.o LINK rtthread.elf riscv-none-embed-size rtthread.elf text data bss dec hex filename 241008 2452 7684 251144 3d508 rtthread.elf scons: done building targets. ```
1.8k
carl_cai
【内核学习营】+王秀峰+led_rgb
