采用4G模块EC20来做OTA升级时无法完全下载,提示TCP Window Full?
发布于 2019-07-10 17:23:26 浏览:4527
* 本帖最后由 shauew 于 2019-7-16 18:43 编辑 * 服务器是使用MyWebServer部署在公网上面: ![{B9267B54-F9E1-45D2-A439-3B733868AC11}_20190711174434.jpg](/uploads/201907/11/174546xa4brgbna9wi0frr.jpg) 运行日志如下: ```msh />http_ota http://xxxxxx/rtthread.rbl http file_size:93148 [I/http_ota] Start erase flash (download) partition! [I/http_ota] Erase flash (download) partition success! [I/http_ota] OTA file size is (93148) [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [E/at.clnt] read line failed. The line data length is out of buffer size(512)! [I/http_ota] Download: [==============================> ] 30% [I/http_ota] Download: [================================> ] 32% [E/http_ota] Exit: server return err (0)! msh />``` 抓包截图,文件见附件。 ![微信截图_20190716183205.png](/uploads/201907/16/184223bvrhvdav7cvk57vk.png) 下载附件 [ota.pcapng](https://oss-club.rt-thread.org/uploads/201907/16/184313xgky0u1b0i005ett.attach)
36
shauew
2019-07-10
[i=s] 本帖最后由 shauew 于 2019-7-10 18:38 编辑 [/i] EC20的接收缓冲区改成1024还是不行 能到 36%
shauew
2019-07-10
EC20的接收缓冲区改成4096可以接收到87,但还是不行。 ``` using uri: http://148.70.111.155/rtthread.rbl http file_size:93148 [I/http_ota] Start erase flash (download) partition! [I/http_ota] Erase flash (download) partition success! [I/http_ota] Download: [===================================================================================> ] 83% [I/http_ota] Download: [=======================================================================================> ] 87% [E/at.skt] AT socket (0) receive timeout (6000)! [E/web] receive data timeout. [E/http_ota] Exit: server return err (-2)! ```
Cheney_Chen
2019-07-11
看一下这时候最大内存占用
zhangjun
2019-07-11
那改到10240看看呢
shauew
2019-07-11
>看一下这时候最大内存占用 --- 内存有128k,使用情况如下: ``` thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- ec20_lin 30 suspend 0x00000098 0x00000400 28% 0x00000012 -02 tshell 20 running 0x00000140 0x00000800 38% 0x00000007 000 at_clnt 9 suspend 0x000000ac 0x00000600 22% 0x00000004 000 sys_work 23 suspend 0x00000060 0x00000800 29% 0x00000008 000 tidle0 31 ready 0x00000044 0x00000400 08% 0x0000001b 000 main 10 suspend 0x0000008c 0x00000800 18% 0x00000002 000 ```
shauew
2019-07-11
>那改到10240看看呢 --- 改成10k也还是不行,感觉还是webclient没接收完的感觉。
shauew
2019-07-11
[i=s] 本帖最后由 shauew 于 2019-7-11 17:39 编辑 [/i] 新建一个小点儿的文件来测试下载是没有问题的,是不是因为文件太大? ``` http file_size:12 [I/http_ota] Start erase flash (download) partition! [I/http_ota] Erase flash (download) partition success! [I/http_ota] Download: [====================================================================================================] 100% [I/http_ota] Download firmware to flash success. [I/http_ota] System now will restart... ```
shauew
2019-07-11
新的错误日志 ``` msh />http_ota http://xxxxxx/zero.rbl http file_size:75136 [I/http_ota] Start erase flash (download) partition! [I/http_ota] Erase flash (download) partition success! [I/http_ota] Download: [======================================================================================> ] 86% [E/http_ota] Exit: server return err (0)! msh /> ``` 总感觉每次到87%左右就会出现服务器错误。
armink
2019-07-12
这个应该是已知问题,urc 数据生产速率远大于网络数据消费速率时,会导致内存耗尽,其他帖子中讨论过([https://www.rt-thread.org/qa/forum.php?mod=viewthread&tid=11599](https://www.rt-thread.org/qa/forum.php?mod=viewthread&tid=11599)),后面会修正该问题。
shauew
2019-07-12
>这个应该是已知问题,urc 数据生产速率远大于网络数据消费速率时,会导致内存耗尽,其他帖子中讨论过(https ... --- 谢谢老大,我去参考下。
4.5k
shauew
28
138
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
