关于CAN总线驱动使用解释
发布于 2019-07-16 19:57:37 浏览:2116
[tocm] * 本帖最后由 ylz0923 于 2019-7-30 11:44 编辑 * # CAN 设备 ## CAN 简介 基本扩展 CAN 外设又称 bxCAN,可与 CAN 网络进行交互。该外设支持 2.0A 和 B 版本的CAN 协议,旨在以最少的 CPU 负载高效管理大量的传入消息,并可按需要的优先级实现消息发送。 ## 硬件注意事项 - 总线上必须有两个以上的CAN设备节点 - 总线两端须接终端电阻 ## 软件配置注意事项 - 每个CAN设备至少配置一个过滤器, 且过滤器处于活动状态(can驱动中已经配置默认过滤器) - CAN设备的基础配置, 总线管理和自动重发 ### CAN基础配置 CAN配置结构体 ``` /** * @brief CAN init structure definition */ typedef struct { uint32_t Prescaler; /*!< Specifies the length of a time quantum. This parameter must be a number between Min_Data = 1 and Max_Data = 1024. */ uint32_t Mode; /*!< Specifies the CAN operating mode. This parameter can be a value of @ref CAN_operating_mode */ uint32_t SyncJumpWidth; /*!< Specifies the maximum number of time quanta the CAN hardware is allowed to lengthen or shorten a bit to perform resynchronization. This parameter can be a value of @ref CAN_synchronisation_jump_width */ uint32_t TimeSeg1; /*!< Specifies the number of time quanta in Bit Segment 1. This parameter can be a value of @ref CAN_time_quantum_in_bit_segment_1 */ uint32_t TimeSeg2; /*!< Specifies the number of time quanta in Bit Segment 2. This parameter can be a value of @ref CAN_time_quantum_in_bit_segment_2 */ FunctionalState TimeTriggeredMode; /*!< Enable or disable the time triggered communication mode. This parameter can be set to ENABLE or DISABLE. */ FunctionalState AutoBusOff; /*!< Enable or disable the automatic bus-off management. This parameter can be set to ENABLE or DISABLE. */ FunctionalState AutoWakeUp; /*!< Enable or disable the automatic wake-up mode. This parameter can be set to ENABLE or DISABLE. */ FunctionalState AutoRetransmission; /*!< Enable or disable the non-automatic retransmission mode. This parameter can be set to ENABLE or DISABLE. */ FunctionalState ReceiveFifoLocked; /*!< Enable or disable the Receive FIFO Locked mode. This parameter can be set to ENABLE or DISABLE. */ FunctionalState TransmitFifoPriority;/*!< Enable or disable the transmit FIFO priority. This parameter can be set to ENABLE or DISABLE. */ } CAN_InitTypeDef; ``` drv_can.c中的配置 ``` static rt_err_t drv_configure(struct rt_can_device *dev_can, struct can_configure *cfg) { ... ... drv_init->TimeTriggeredMode = DISABLE; drv_init->AutoBusOff = ENABLE; /* 自动离线管理 */ drv_init->AutoWakeUp = DISABLE; drv_init->AutoRetransmission = DISABLE; drv_init->ReceiveFifoLocked = DISABLE; drv_init->TransmitFifoPriority = ENABLE; /* 自动重发 */ ... ... } ``` - 自动重发和自动离线管理同时打开的效果---总线物理断开后, 重新连接后可以自动重新通讯, 在总线断开期间发生函数不会返回. - 自动重发和自动离线管理同时关闭的效果---总线物理断开后, 重新连接后无法恢复通讯需要重新启动, 在总线断开期间发生函数返回错误. ### 过滤器配置 先上个demo:![app_can.c](/uploads/201907/16/195817abbnienoenhmf3ro.attach)
WillianChan
2019-07-18
楼主是想要分享自己的CAN开发经验吗?可以按照自己思路一步一步阐述出来
2.1k
ylz0923
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
