关于easyflashv4.0.0分配env空间不足的问题
发布于 2019-07-17 15:32:45 浏览:2083
之前使用V3.3是好用的,到V4.0时,会出现alloc env空间不足的情况 \ | / - RT - Thread Operating System / | \ 4.0.1 build Jul 17 2019 2006 - 2019 Copyright by rt-thread team [1] W/drv.rtc: RTC hasn't been configured, please use
command to config. [24] D/ut: pass_count = 32,utc_t1 =946687320 start_second =600 utc_day_remain=2511 [33] D/at45: result = 0 [D/FAL] (fal_flash_init:61) Flash device | nor_flash | addr: 0x00000000 | len: 0x00800000 | blk_size: 0x00000100 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | easyflash | nor_flash | 0x00000000 | 0x00080000 | [I/FAL] | ota_download | nor_flash | 0x00080000 | 0x00100000 | [I/FAL] | bakeup_flash | nor_flash | 0x00180000 | 0x00080000 | [I/FAL] | sample_data | nor_flash | 0x00200000 | 0x00700000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1766) ENV start address is 0x00000000, size is 16384 bytes. [Flash] check_failed_count = 0[Flash] EasyFlash V4.0.0 is initialize success. [Flash] You can get the latest version on [https://github.com/armink/EasyFlash](https://github.com/armink/EasyFlash) . [1747] D/fal: =============================================== [1753] D/fal: The system now boot 1 times [1757] D/fal: =============================================== [Flash] (packages\EasyFlash-latest\src\ef_env.c:1011) Trigger a GC check after alloc ENV failed. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1142) Warning: Alloc an ENV (size 39) failed when new ENV. Now will GC then retry. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1210) The remain empty sector is 1, GC threshold is 1. [Flash] (packages\EasyFlash-latest\src\ef_env.c:1011) Trigger a GC check after alloc ENV failed. 有没有人调试的时候也遇到过这种情况 ![微信截图_20190717153029.png](https://oss-club.rt-thread.org/uploads/201907/17/153227dj4pp78dudulll5x.png)
tsx1983
2019-07-18
有遇到过,V4.0感觉没V3.3好用,老是报莫名其妙的错误,都不知道咋回事
armink
2019-07-18
[i=s] 本帖最后由 armink 于 2019-7-18 10:02 编辑 [/i] 感觉像是 flash 驱动的问题,你这个上来就提示 alloc 失败了 先 fal bench 测试下驱动。
rainz
2019-07-18
>感觉像是 flash 驱动的问题,你这个上来就提示 alloc 失败了 >先 fal bench 测试下驱动。 > ... --- 确实是驱动的问题,因为我玩的atmel 641e不支持sfud fal_flash_sfud是我自己改的。。 现在环境变量正确存入到flash中,但是目前无法识别相同的变量,每次都会存进去一个新的变量。。。。驱动应该还是有问题,我在调调,希望能使用的上4.0的easyflash。
armink
2019-07-19
>确实是驱动的问题,因为我玩的atmel 641e不支持sfud fal_flash_sfud是我自己改的。。 >现在环境变量正确存 ... --- 嗯,最小擦除大小好像配置的也有问题,不可能是 256 吧?
rainz
2019-07-19
之前应该是调出来了 我看了你的design介绍 每次只是把ENV的header的参数置位了 数据保留 等要增加新的数据再被覆盖 另外我用的AT45DB641Eflash芯片最小擦除大小是1 page,256字节。。。
armink
2019-07-19
>之前应该是调出来了 我看了你的design介绍 每次只是把ENV的header的参数置位了 数据保留 等要增加新的数据 ... --- 256 确实太小了,可以配置 EasyFlash 里的最小擦除单位可以为更大单位,比如 4096 ,只要底层驱动支持按照 4096 大小擦除就行了
2.1k
rainz
恩智浦mcxn947的RT-Thread的PIN驱动测评
