Kernel
STM32F103关于互斥型信号量的疑惑
发布于 2019-07-26 16:28:49 浏览:1793
* 本帖最后由 aozima 于 2019-7-28 02:44 编辑 * 先上代码: ```#include "board.h" #include "rtthread.h" /* 定义线程控制块 */ static rt_thread_t receive_thread = RT_NULL; static rt_thread_t send_thread = RT_NULL; /* 定义互斥量控制块 */ static rt_mutex_t tex_mux = RT_NULL; /* 用到的全局变量 */ uint8_t ucValue[2] = {0x00, 0x00}; /* 声明线程函数 */ static void receive_thread_entry(void* parameter); static void send_thread_entry(void* parameter); int main(void) { tex_mux = rt_mutex_create("test_sem", RT_IPC_FLAG_FIFO); receive_thread = rt_thread_create("receive", receive_thread_entry, RT_NULL, 512, 3, 20); if(receive_thread != RT_NULL) rt_thread_startup(receive_thread); else return -1; send_thread = rt_thread_create("send", send_thread_entry, RT_NULL, 512, 2, 20); if(send_thread != RT_NULL) rt_thread_startup(send_thread); else return -1; } static void receive_thread_entry(void* parameter) { while(1) { rt_mutex_take(tex_mux, RT_WAITING_FOREVER); if(ucValue[0] == ucValue[1]) { rt_kprintf("%d
", ucValue[0]); rt_kprintf("%d
", ucValue[1]); rt_kprintf("22222222222222222222222222222222222222222222222222
"); } else rt_kprintf("Fail
"); rt_mutex_release(tex_mux); rt_thread_delay(1000); } } static void send_thread_entry(void *parameter) { while(1) { rt_mutex_take(tex_mux, RT_WAITING_FOREVER); rt_kprintf("1111111111111111111111111111111111111111111111111
"); ucValue [ 0 ] ++; rt_thread_delay ( 100 ); ucValue [ 1 ] ++; rt_mutex_release(tex_mux); rt_thread_yield(); } } ``` 打印效果: > 0 0 22222222222222222222222222222222222222222222222222 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 10 10 22222222222222222222222222222222222222222222222222 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 20 20 22222222222222222222222222222222222222222222222222 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 。。。。。。。。省略。。。。。。。 让我不理解的地方是,send_thread的优先级是2,receive_thread的优先级是3, 但是从打印效果来看是receive_thread的线程先执行的,然后我把main中两个线程的创建顺序调换了一下, 即先创建send_thread后创建receive_thread(二者的优先级未作改变),打印效果变成如下: > 1111111111111111111111111111111111111111111111111 1 1 22222222222222222222222222222222222222222222222222 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 11 11 22222222222222222222222222222222222222222222222222 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 1111111111111111111111111111111111111111111111111 。。。。。。。。省略。。。。。。。 结合两次打印效果来看,应该是哪个线程先创建,哪个线程就先执行,这样子的话,线程的优先级不就无效了吗? 关于线程优先级这里应该怎样执行??望大佬们不吝赐教谢谢谢谢谢谢!
qiudashan
2019-07-26
大佬在哪里:'(
qiudashan
2019-07-26
求大佬:'(
国际哥
2019-07-27
rt_thread_startup调用时,如果新启动的线程优先级比系统当前运行线程优先级高,将立刻切换到这个线程。回到你的问题,无论是send_thread还是receive_thread线程,都是系统目前最高优先级的两个任务(数字越小越优先,2和3优先级都挺高),谁先启动运行谁没毛病。 这只是rt_thread_startup()这个函数的规则而已,优先级的意义更多还是在于系统运行时任务的调度和抢占上 —— 执行调度时,若有比当前线程优先级更高的线程就绪,当前线程将立刻被换出,高优先级线程抢占处理器运行。 楼主大可不必过于纠结启动时这一点细节,总之,优先级还是有用、有效的。
国际哥
2019-07-27
[i=s] 本帖最后由 国际哥 于 2019-7-27 11:21 编辑 [/i] >求大佬 --- 大佬大佬
qiudashan
2019-07-28
>大佬大佬 --- “无论是send_thread还是receive_thread线程,都是系统目前最高优先级的两个任务(数字越小越优先,2和3优先级都挺高),谁先启动运行谁没毛病”。。。。。这段没明白。。。。意思是初始启动阶段无所谓优先级?
Ernest
2019-07-29
先上结论:自己坑自己 高优先级线程延时 1 秒,低优先级延时 0.1 秒,就出现了日志的现象
小小小菜鸟
2019-07-29
main()也是一个线程,而且优先级比你send_thread,receive_thread低,相当于说你mian函数初始化第一个线程,就被第一个线程抢占,直到第一个线程挂起,mian再来初始化第二个线程。所以就会出现你说的这种现象,谁放在前面谁先执行。
黄侃
2019-07-29
前面几个说的都不对,只有楼上是正解,main本身也是一个线程,优先级为10,当你创建第一个线程,优先级为3,并且执行了rt_thread_startup时,就已经跳转了。等跳转回main才回去执行下面的的创建优先级为2的线程。 另外不要使用yield
qiudashan
2019-07-29
>先上结论:自己坑自己 > >高优先级线程延时 1 秒,低优先级延时 0.1 秒,就出现了日志的现象 --- 两个线程的打印都还没有到延时的位置啊
qiudashan
2019-07-29
>main()也是一个线程,而且优先级比你send_thread,receive_thread低,相当于说你mian函数初始化第一个线程 ... --- 您是大佬啊{:2_39:}
1.8k
qiudashan
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
