DIY综合交流区
ART的ide/build目录下做ant操作失败
发布于 2013-01-06 18:13:41 浏览:5685
从github取的最新代码,安装完jdk环境,ant,cygwin后,进入到ide/build下做ant操作,结果提示以下错误 $ ant Buildfile: build.xml build: revision-check: windows-checkos: subprojects-build: compile: [methods] No changes to PApplet API. [mkdir] Created dir: C:\linux t-thread\ART\ide\core\bin [javac] Compiling 34 source files to C:\linux t-thread\ART\ide\core\bin build: [jar] Building jar: C:\linux t-thread\ART\ide\core\core.jar compile: [mkdir] Created dir: C:\linux t-thread\ART\ide\app\bin [javac] Compiling 70 source files to C:\linux t-thread\ART\ide\app\bin [javac] C:\linux t-thread\ART\ide\app\src\processing\app\Editor.java:2498: cannot find symbol [javac] symbol: class ARTUploader [javac] Uploader uploader = new ARTUploader(); [javac] ^ [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [javac] 1 error BUILD FAILED C:\linux t-thread\ART\ide\build\build.xml:35: The following error occurred while executing this line: C:\linux t-thread\ART\ide\build\build.xml:68: The following error occurred while executing this line: C:\linux t-thread\ART\ide\app\build.xml:47: Compile failed; see the compiler error output for details. Total time: 4 seconds 个人理解是ide\app\src\processing\app\debug\下面缺少ARTUploader.java文件
2013-01-06
我看看这个文件是否没上传到github上
2013-01-06
这个有些奇怪,我这边也没有ARTUploader.java的文件,难道丢失了,我需要编译一下试试
bbstr
2013-01-06
从git log的记录来看,似乎github上从未提交过这个ARTUploader.java文件
2013-01-07
这个代码有些问题,原打算是单独弄个菜单做WiFi固件的下载,后来想想没什么必要了。所以这个函数实际上并没有调用,可以把这个函数删除掉即可,github上的代码已经更新了
bbstr
2013-01-07
又遇到了新的错误 $ $ANT/ant Buildfile: build.xml build: revision-check: windows-checkos: subprojects-build: compile: [methods] No changes to PApplet API. build: compile: [copy] Copying 33 files to C:\linux\rt-thread\ART\ide\app\bin [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_zh_cn.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_zh_cn.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_nl.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_nl.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_an.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_an.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_no_nb.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_no_nb.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ro.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ro.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ru.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ru.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_fa.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_fa.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_gl.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_gl.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_mr.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_mr.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_pl.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_pl.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_sl.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_sl.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_hu.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_hu.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_pt_pt.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_pt_pt.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ko.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ko.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ja.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ja.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_lt.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_lt.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_zh_tw.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_zh_tw.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_fr.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_fr.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_de.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_de.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_es.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_es.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_tl.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_tl.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_pt_br.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_pt_br.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ta.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ta.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_en.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_en.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ar.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ar.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_ca.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_ca.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_et.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_et.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_id.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_id.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_lv.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_lv.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_da.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_da.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_el.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_el.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_hi.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_hi.properties [copy] Copying C:\linux\rt-thread\ART\ide\app\src\processing\app\Resources_it.properties to C:\linux\rt-thread\ART\ide\app\bin\processing\app\Resources_it.properties build: [jar] Building jar: C:\linux\rt-thread\ART\ide\app\pde.jar windows-build: [copy] Copying 1 file to C:\linux\rt-thread\ART\ide\build\windows\work\lib [unzip] Expanding: C:\linux\rt-thread\ART\ide\build\windows\arm_tools.zip into C:\linux\rt-thread\ART\ide\build\windows\work\hardware\tools [unzip] Expanding: C:\linux\rt-thread\ART\ide\build\windows\stm32-dfu.zip into C:\linux\rt-thread\ART\ide\build\windows\work\hardware\tools [unzip] Expanding: C:\linux\rt-thread\ART\ide\build\windows\bin.zip into C:\linux\rt-thread\ART\ide\build\windows\work\hardware\tools [unzip] Expanding: C:\linux\rt-thread\ART\ide\build\shared\firmware.zip into C:\linux\rt-thread\ART\ide\build\windows\work\hardware [copy] Copying 1 file to C:\linux\rt-thread\ART\ide\build\windows\work\hardware\ART [copy] Copying 1 file to C:\linux\rt-thread\ART\ide\build\windows\work\hardware\ART [copy] Copying 1 file to C:\linux\rt-thread\ART\ide\build\windows\work\hardware\ART assemble: [unzip] Expanding: C:\linux\rt-thread\ART\ide\build\shared\reference.zip into C:\linux\rt-thread\ART\ide\build\windows\work [launch4j] Compiling resources [launch4j] Generated resource file... [launch4j] [launch4j] LANGUAGE 0, 1 [launch4j] 1 RCDATA BEGIN "java\0" END [launch4j] 2 RCDATA BEGIN "1.5.0\0" END [launch4j] 18 RCDATA BEGIN "1\0" END [launch4j] 12 RCDATA BEGIN "-Xms128m -Xmx128m\0" END [launch4j] 1 ICON DISCARDABLE "C:\\linux\\rt-thread\\ART\\ide\\build\\windows\\work\\application.ico" [launch4j] 21 RCDATA BEGIN "http://java.sun.com/javase/downloads/\0" END [launch4j] 8 RCDATA BEGIN ".\0" END [launch4j] 20 RCDATA BEGIN "32\0" END [launch4j] 4 RCDATA BEGIN "true\0" END [launch4j] 5 RCDATA BEGIN "true\0" END [launch4j] 6 RCDATA BEGIN "60\0" END [launch4j] 7 RCDATA BEGIN "true\0" END [launch4j] 1 BITMAP "C:\\linux\\rt-thread\\ART\\ide\\build\\windows\\work\\about.bmp" [launch4j] 101 RCDATA BEGIN "An error occurred while starting the application.\0" END [launch4j] 102 RCDATA BEGIN "This application was configured to use a bundled Java Runtime Environment but the runtime is missing or corrupted.\0" END [launch4j] 103 RCDATA BEGIN "This application requires at least Java Development Kit\0" END [launch4j] 104 RCDATA BEGIN "The registry refers to a nonexistent Java Development Kit installation or the runtime is corrupted.\0" END [launch4j] 15 RCDATA BEGIN "processing.app.Base\0" END [launch4j] 16 RCDATA BEGIN "lib\\pde.jar;lib\\core.jar;lib\\jna.jar;lib\\ecj.jar;lib\\RXTXcomm.jar\0" END [launch4j] 14 RCDATA BEGIN "lib\0" END [launch4j] BUILD FAILED C:\linux\rt-thread\ART\ide\build\build.xml:35: The following error occurred while executing this line: C:\linux\rt-thread\ART\ide\build\build.xml:522: net.sf.launch4j.BuilderException: net.sf.launch4j.ExecException: java.io.IOException: Cannot run program "C:\linux\rt-thread\ART\ide\build\windows\launcher\launch4j\bin\windres.exe": CreateProcess error=5, Access is denied Total time: 13 seconds
bbstr
2013-01-07
可以了,把chmod 777 -fR windows/launcher/launch4j/bin/ 了一下 好了,结贴
2013-01-07
chmod? 你用的是Linux?但是不是啊
bbstr
2013-01-07
我用的是cygwin 从git上拿下来的那两个exe似乎权限不够,不知道是不是因为我是win7的原因
5.7k
bbstr
29
[项目]搞个开源的硬件项目
硬件计划贴,及时更新,欢迎提意见
MMS协议
定点的wma解压库-libwma
QQ群记录 [20090821]
STM32网络收音机PCB报名征集
第一版调试记录
第二版硬件讨论
【学习分享】初探RT-Thread系统调度
NXP MCXN947测评之 I2C (硬件) 实践
