RT-Thread English
[ANN] RT-Thread 1.2.0 RC release
发布于 2013-10-10 10:31:23 浏览:5170
This release brings ARM Cortex-A8 porting based on BeagleBone, UNITY-2 porting based on SEP6200, and supports Ymodem protocol. Kernel: * fix the spelling wrong in rtdef.h(_MSC_VER_ -> _MSC_VER) * fix debug output of scheduler * ipc - add a check on the option flag in rt_event_recv() * kservice - export vsnprintf as rt_vsnprintf * memheap - fix the memory block splitting issue * memheap - optimize rt_memheap_realloc(don't alloc/memcpy when there is next node is enough for realloc) * device - add ref_count support Components: * dfs - fix the variable definition bug in copy(dfs_file.c) * dfs - add mount table * dfs - add ramfs into building script * dfs - fix O_APPEND write issue in ramfs * dfs/elm - add device_open/close in mkfs * dfs/jffs2 - fix file mode init bug in jffs2_open/opendir * dfs/jffs2 - fix bug when umount jffs2 * pthread - remove compiling warning * drivers/pipe - add rt_pipe_init/rt_pipe_detach * drivers/pipe - add nonblocking read/write and force write mode * drivers/pipe - call rx_indicate the time we resume reader * drivers/pipe - make pipe a type of device * drivers/portal - implement portal device * drivers/portal - add checks on oflag * drivers/portal - fix bug in portal callback forwarding * drivers/ringbuffer - fix the ambiguous name * drivers/ringbuffer - add put_force and putchar_force API * finsh - add device checking when set_device * finsh - add shell device automatically setting for rx_ind * finsh - add description for new pipe and portal device * finsh - use alias in the variable definition * finsh - unregister rx_indicate when closing the device * finsh - fix the command line too long issue * finsh/msh - only export cd/pwd when DFS_USING_WORKDIR is enabled * init - remove initialization feature for MS VC++ compiler * init - update linker script for components auto initialization * init - add initialization debug code * logtrace - cleanup * logtrace - change the compiling macro before DFS option * logtrace - cleanup code and fix compiling warnings * logtrace - add LOG_TRACE_VERBOSE log level * logtrace - adjust the log values * logtrace - only export cmd when finsh is enabled * libc/minilibc - add gettimeofday declaration in sys/time.h * utilities - add ymodem Tools: * building.py - add clang static analyzer support * building.py - add buildlib for Keil MDK * building.py - run 'clang -Wall -fsyntas-only' in clang-analyze * clang-analyze.py - add a custom tool to do clang static analyze BSP: * import beaglebone porting * SEP6200 Support * add K60Fxxxx bsp for TWR-K60F120M board * fix compiling error in Linux(lm4f232, stm32f40x, xplorer4330) * cortex-m3 - enhancement hard fault exception handler * at91sam9260 - update usart driver, using serial driver component * at91sam9260 - update the project directory structure * at91sam9260 - fix compiling error * at91sam9260 - embedded GPLv2 license * stm32f10x - cleanup code * stm32f10x - remove unused file * stm32f10x - update the project directory structure * stm32f10x - update the project files * stm32f10x - update link script for components auto initialization * stm32f10x - update SD card driver for auto initialization * stm32f10x - update DM9000 ethernet driver for auto initialization * stm32f10x - use serial driver component * stm32f10x - fix the rtgui initialization * simulator - update code for new component initialization support on mingw * simulator - update to support simulator for Linux * simulator - fix SDL initialization under Linux * simulator - init SDL after rt_components_init * simulator - move rt_hw_context_switch_interrupt after it's definition * simulator - move SDL setting staff into drivers/SConstruct * simulator - get CORSS_TOOL and EXEC_PATH from env * simulator - add clang-analyze tool support * simulator - add tap netif driver Download: [RT-Thread 1.2.0 RC](https://rt-thread.googlecode.com/files/RT-Thread_1.2.0RC.7z)
5.2k
lgnq
28
57
Welcome to RT-Thread RTOS English discussion
good!
The speed of external SRAM of STM32
RT-Thread on ST Forum
Splay Tree
More RTGUI screenshot
STM32 pimer2
mini2440 support
Howto Run RT-Thread 0.4.0 on QEMU/mini2440
RT-Gui : how can use it?
【学习分享】初探RT-Thread系统调度
NXP MCXN947测评之 I2C (硬件) 实践
