关于用scons 编译RT_USING_MODULE的工程是出错
发布于 2014-03-22 19:00:34 浏览:2726
以前一直使用mdk编译 打开RT_USING_MODULE也不会报错,但是今天是用在scons使用GCC编译工程时提示 ```#ifdef __GNUC__ extern int __rtmsymtab_start; extern int __rtmsymtab_end;``` 这两个没有定义 请问这是我编译环境有问题,吗?还是其他原因 系统1.2.07稳定版 scons2.0
2014-03-22
需要在链接脚本中加入相关的KEEP
fighter
2014-03-23
谢谢bernard的解答 问题已经解决了参考 realtouch 的工程修改了stm32_rom.ld文件红色部分 ``` /* * linker script for realtouch-STM32F4 with GNU ld * bernard.xiong 2009-10-14 */ /* Program Entry, set to mark it as "used" and avoid gc */ MEMORY { CODE (rx) : ORIGIN = 0x08000000, LENGTH = 1M /* 1M flash */ DATA (rw) : ORIGIN = 0x20000000, LENGTH = 128k /* 128K sram */ } ENTRY(Reset_Handler) _system_stack_size = 0x200; SECTIONS { .text : { . = ALIGN(4); KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(4); *(.text) /* remaining code */ *(.text.*) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) *(.gnu.linkonce.t*) /* section information for module symbol */ . = ALIGN(4); __rtmsymtab_start = .; KEEP(*(RTMSymTab)) __rtmsymtab_end = .; /* section information for finsh shell */ . = ALIGN(4); __fsymtab_start = .; KEEP(*(FSymTab)) __fsymtab_end = .; . = ALIGN(4); __vsymtab_start = .; KEEP(*(VSymTab)) __vsymtab_end = .; . = ALIGN(4); . = ALIGN(4); _etext = .; } > CODE = 0 /* .ARM.exidx is sorted, so has to go in its own output section. */ __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) /* This is used by the startup in order to initialize the .data secion */ _sidata = .; } > CODE __exidx_end = .; /* .data section which is used for initialized data */ .data : AT (_sidata) { . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _sdata = . ; *(.data) *(.data.*) *(.gnu.linkonce.d*) . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _edata = . ; } >DATA .stack : { . = . + _system_stack_size; . = ALIGN(4); _estack = .; } >DATA __bss_start = .; .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(.bss.*) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; *(.bss.init) } > DATA __bss_end = .; _end = .; /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. * Symbols in the DWARF debugging sections are relative to the beginning * of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } } ``` 应用模块在windows下编译总结: 1.在打开RT_USING_MODULE宏定义 2.更新工程 3.修改stm32_rom.ld文件 添加如下内容 /* section information for module symbol */ . = ALIGN(4); __rtmsymtab_start = .; KEEP(*(RTMSymTab)) __rtmsymtab_end = .; 即添加 __rtmsymtab_start __rtmsymtab_end 这两个是在gcc编译是用的 否则编译报错没有定义这两个宏 4.编译 scons -j32 5.假如编译BSP SZKFBstm32f107vc 下的一个test模块目录结构如下 └─test └─build └─SZKFBstm32f107vc >ls SConstruct rtconfig.py rtconfig.pyc test 参考RT-Thread_1.2.0examplesmodule下的文件 其中修改BSP = 'SZKFBstm32f107vc' 代码发到test下面 6.ls 目录下执行scons --app=test 编译成test.so文件 以上是在此次编译应用模块遇到的问题与解决方法分享出来希望能给一些初学者提供一些参考。^_^
2014-03-23
很赞的总结!这个确实也是RT-Thread带的独立应用执行模式,很有特色,也是RealBoard 4088上主推的开发方式。 在RT-Thread的后续版本中,应用模块在继续进化,并且一分为三(三种方式的应用模块): 1. 在Flash上执行,速度快,内存少; 2. 在RAM里执行,应用灵活; 3. 安全模式,在内核中限制应用模块的访问空间,应用也仅运行在用户态。 另外,lz的机器很强大,都可以-j32进行并行编译
2.7k
fighter
60
