求助:stm32f207 usb host 接U盘
发布于 2014-06-12 16:54:11 浏览:4568
使用RT-THREAD1.21的usb host协议,由于对USB不熟悉,所以代码都是到处乱拼的:从ART把stm32f4xx_hcd.c移植过来,又参考adk.c来编写U盘的驱动,现在算是编译通过了,前面的枚举都成功,而且可以跑到rt_usb_mass_run();这rt_usb_mass_run()中对u盘进行挂载,然后跑到rt_udisk_read(),现在就卡在第二个 rt_usb_hcd_bulk_xfer()函数里面。单步进去,看到是state = HCD_GetURB_State(&USB_OTG_Core , channel),state一直等于URB_IDLE,导致一直死在这里。这个问题有没有人遇到过? 我看其他人仅用ST的库来做也遇到过state = HCD_GetURB_State(&USB_OTG_Core , channel),state一直返回URB_IDLE的,有的人说调整USB的中断优先级就可以解决了,但是我调整了还是不可以。 ``` static rt_size_t rt_udisk_read(rt_device_t dev, rt_off_t pos, void* buffer, rt_size_t size) { uint8_t i; uint16_t nbOfPages; uifinst_t ifinst = (uifinst_t)dev->user_data; umassinst_t udisk = (umassinst_t)ifinst->user_data; struct ustorage_cbw read_cbw; rt_size_t res; if (NULL == dev || !size) return -RT_ERROR; if (Stat & STA_NOINIT) return -RT_EBUSY; size *= USBH_MSC_PAGE_LENGTH; read_cbw.signature = USBH_MSC_BOT_CBW_SIGNATURE; read_cbw.tag = USBH_MSC_BOT_CBW_TAG; read_cbw.lun = 0; /*Only one LUN is supported*/ read_cbw.xfer_len = XFER_LEN_READ_CAPACITY10; read_cbw.dflags = USB_EP_DIR_IN; read_cbw.cb_len = CBW_LENGTH; for(i = CBW_CB_LENGTH; i != 0; i--) { read_cbw.cb* = 0x00; } read_cbw.cb[0] = SCSI_READ_10; /*logical block address*/ read_cbw.cb[2] = (((uint8_t*)&pos)[3]); read_cbw.cb[3] = (((uint8_t*)&pos)[2]); read_cbw.cb[4] = (((uint8_t*)&pos)[1]); read_cbw.cb[5] = (((uint8_t*)&pos)[0]); /*USBH_MSC_PAGE_LENGTH = 512*/ nbOfPages = size/ USBH_MSC_PAGE_LENGTH; /*Tranfer length */ read_cbw.cb[7] = (((uint8_t *)&nbOfPages)[1]) ; read_cbw.cb[8] = (((uint8_t *)&nbOfPages)[0]) ; res = rt_usb_hcd_bulk_xfer(ifinst->uinst->hcd,udisk->pipe_out,&read_cbw,31,300); if(res < 0) { return res; } res = rt_usb_hcd_bulk_xfer(ifinst->uinst->hcd,udisk->pipe_in,buffer,size,300); return res; } static rt_err_t rt_usb_mass_run(void* arg) { int i = 0; umassinst_t adkinst; uifinst_t ifinst = (uifinst_t)arg; uintf_desc_t intf_desc; rt_err_t ret; /* parameter check */ if(ifinst == RT_NULL) { rt_kprintf("the interface is not available "); return -RT_EIO; } RT_DEBUG_LOG(RT_DEBUG_USB, ("rt_usb_adk_run ")); intf_desc = ifinst->intf_desc; if(intf_desc->bInterfaceClass != USB_CLASS_MASS_STORAGE) { RT_DEBUG_LOG(RT_DEBUG_USB, ("mass type err=%u ",intf_desc->bInterfaceClass)); return -RT_EIO; } if(intf_desc->bInterfaceSubClass != USB_SUB_CLASS_MASS_STORE) { RT_DEBUG_LOG(RT_DEBUG_USB, ("mass_sub type err=%u ",intf_desc->bInterfaceSubClass)); return -RT_EIO; } if(intf_desc->bInterfaceProtocol != MSC_PROTOCOL) { RT_DEBUG_LOG(RT_DEBUG_USB, ("protocal type err=%u ",intf_desc->bInterfaceProtocol)); return -RT_EIO; } adkinst = rt_malloc(sizeof(struct umassinst)); RT_ASSERT(adkinst != RT_NULL); /* initilize the data structure */ rt_memset(adkinst, 0, sizeof(struct umassinst)); ifinst->user_data = (void*)adkinst; for(i=0; i
intf_desc->bNumEndpoints; i++) { uep_desc_t ep_desc; /* get endpoint descriptor from interface descriptor */ rt_usb_get_endpoint_descriptor(ifinst->intf_desc, i, &ep_desc); if(ep_desc == RT_NULL) { rt_kprintf("rt_usb_get_endpoint_descriptor error "); return -RT_ERROR; } /* the endpoint type of adk class should be BULK */ if((ep_desc->bmAttributes & USB_EP_ATTR_TYPE_MASK) != USB_EP_ATTR_BULK) continue; /* allocate pipes according to the endpoint type */ if(ep_desc->bEndpointAddress & USB_DIR_IN) { /* allocate an in pipe for the adk instance */ ret = rt_usb_hcd_alloc_pipe(ifinst->uinst->hcd, &adkinst->pipe_in, ifinst, ep_desc, RT_NULL); if(ret != RT_EOK) return ret; } else { /* allocate an output pipe for the adk instance */ ret = rt_usb_hcd_alloc_pipe(ifinst->uinst->hcd, &adkinst->pipe_out, ifinst, ep_desc, RT_NULL); if(ret != RT_EOK) return ret; } } /* check pipes infomation */ if(adkinst->pipe_in == RT_NULL || adkinst->pipe_out == RT_NULL) { rt_kprintf("pipe error, unsupported device "); return -RT_ERROR; } /* set configuration */ ret = rt_usb_set_configure(ifinst->uinst, 1); if(ret != RT_EOK) return ret; /* register adk device */ adkinst->device.type = RT_Device_Class_Block; adkinst->device.init = rt_udisk_init; adkinst->device.open = rt_udisk_open; adkinst->device.close = rt_udisk_close; adkinst->device.read = rt_udisk_read; adkinst->device.write = rt_udisk_write; adkinst->device.control = rt_udisk_ioctl; adkinst->device.user_data = (void*)ifinst; rt_device_register(&adkinst->device, "udisk", RT_DEVICE_FLAG_RDWR); #ifdef RT_USING_DFS_ELMFAT /* mount sd card fat partition 1 as root directory */ if (dfs_mount("udisk", "/", "elm", 0, 0) == 0) { rt_kprintf("File System initialized! "); } else rt_kprintf("File System initialzation failed! "); #endif return RT_EOK; } ```
feifan570
2014-07-09
现在出现了新的问题,读第一次可以正常地返回数据,但是读第二次的时候,总是返回URB_NOTREADY。怎么读U盘会出现URB_NOTREADY呢?出现URB_NOTREADY又应该怎么处理呢?
feifan570
2014-07-09
出现URB_NOTREADY解决了,因为每次读写都要给CBW,读写数据,读取CSW;如果不读就会出现URB_NOTREADY; 但是现在又出现新的问题:经常出现URB_ERROR;特别是U盘插拔之后再插进去,就肯定出现。
joe3501
2014-08-27
Mark
杨庆涛NB
2018-12-18
>现在出现了新的问题,读第一次可以正常地返回数据,但是读第二次的时候,总是返回URB_NOTREADY。怎么读U盘 ... --- rt_usb_mass_run这个函数直接挂载上了?
4.6k
feifan570
