RT-Thread English
RT-Thread GCC Compiler Error
发布于 2014-07-25 09:21:26 浏览:8909
Hi All, I'm trying to compile RT-Tread with Eclip-se + GCC 4.8 and the compiller is giving me an error inside the include file "rtservice.h" at macro define ```#define rt_list_entry(node, type, member) ((type *)((char *)(node) - (unsigned long)(&((type *)0)->member)))``` Error: dereferencing pointer to incomplete type Can anyone help me with this problem? Best Regards.
2014-07-25
Which bsp did you use? And do you use scons command line to compile it? If you use eclipse, it's better to use scons to replace make & Makefile. Otherwise, you should properly prepare your development environment.
WGR7
2014-07-25
I'm using LPC176x bsp and using eclipse with your default make build tool, but this error is not a build error and a compile error. The compiler don't acepts this macro because it found a sintax error. Did you compile the RT-Thread 1.2.0 with GCC?
WGR7
2014-07-30
The error is that GCC don't accepts a null pointer like this ((type *)0) I need to include stdio.h and change to this ((type *)NULL) Tnks
2014-07-30
Could you please provide version information of GCC? For example, the out put of `arm-none-eabi-gcc -v`
grissiom
2014-07-30
>The error is that GCC don't accepts a null pointer like this >((type *)0) >I need to include stdio.h and change to this >((type *)NULL) > >Tnks --- Although we don't use the __builtin_offsetof in GCC but I think ((type*)0) should not be a problem. I highly suspect that you didn't get the include path right and included a wrong header.
WGR7
2014-07-30
Hi, Thanks for the support. I already has a code that a conversion of a null pointer like this one generated an error. The pointer was like this (void *)0 THis type of conversion was not allowed. Bellow follows the result of arm-none-eabi-gcc -v command ``` C:Program Files (x86)GNU Tools ARM Embedded4.8 2014q2in>arm-none-eabi-gcc - v Using built-in specs. COLLECT_GCC=arm-none-eabi-gcc COLLECT_LTO_WRAPPER=c:/program files (x86)/gnu tools arm embedded/4.8 2014 q2/bin/../lib/gcc/arm-none-eabi/4.8.4/lto-wrapper.exe Target: arm-none-eabi Configured with: /home/build/work/GCC-4-8-build/src/gcc/configure --build=i686-l inux-gnu --host=i686-w64-mingw32 --target=arm-none-eabi --prefix=/home/build/wor k/GCC-4-8-build/install-mingw --libexecdir=/home/build/work/GCC-4-8-build/instal l-mingw/lib --infodir=/home/build/work/GCC-4-8-build/install-mingw/share/doc/gcc -arm-none-eabi/info --mandir=/home/build/work/GCC-4-8-build/install-mingw/share/ doc/gcc-arm-none-eabi/man --htmldir=/home/build/work/GCC-4-8-build/install-mingw /share/doc/gcc-arm-none-eabi/html --pdfdir=/home/build/work/GCC-4-8-build/instal l-mingw/share/doc/gcc-arm-none-eabi/pdf --enable-languages=c,c++ --disable-decim al-float --disable-libffi --disable-libgomp --disable-libmudflap --disable-libqu admath --disable-libssp --disable-libstdcxx-pch --disable-nls --disable-shared - -disable-threads --disable-tls --with-gnu-as --with-gnu-ld --with-headers=yes -- with-newlib --with-python-dir=share/gcc-arm-none-eabi --with-sysroot=/home/build /work/GCC-4-8-build/install-mingw/arm-none-eabi --with-libiconv-prefix=/home/bui ld/work/GCC-4-8-build/build-mingw/host-libs/usr --with-gmp=/home/build/work/GCC- 4-8-build/build-mingw/host-libs/usr --with-mpfr=/home/build/work/GCC-4-8-build/b uild-mingw/host-libs/usr --with-mpc=/home/build/work/GCC-4-8-build/build-mingw/h ost-libs/usr --with-isl=/home/build/work/GCC-4-8-build/build-mingw/host-libs/usr --with-cloog=/home/build/work/GCC-4-8-build/build-mingw/host-libs/usr --with-li belf=/home/build/work/GCC-4-8-build/build-mingw/host-libs/usr --with-host-libstd cxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-pkgversion='GNU Tools for ARM Embedded Processors' --with-multilib-list=armv6-m,armv7-m,armv7e-m ,armv7-r Thread model: single gcc version 4.8.4 20140526 (release) [ARM/embedded-4_8-branch revision 211358] ( GNU Tools for ARM Embedded Processors) C:Program Files (x86)GNU Tools ARM Embedded4.8 2014q2in> ```
grissiom
2014-07-31
>Hi, > >Thanks for the support. I already has a code that a conversion of a null pointer like this one generated an error. The pointer was like this > >(void *)0 --- Noop. You can type cast any thing to any type in C. So this should be legal.
8.9k
WGR7
Welcome to RT-Thread RTOS English discussion
good!
The speed of external SRAM of STM32
RT-Thread on ST Forum
Splay Tree
More RTGUI screenshot
STM32 pimer2
mini2440 support
Howto Run RT-Thread 0.4.0 on QEMU/mini2440
RT-Gui : how can use it?
