NXP 微控制器
RealBoard4088 scons 方式编译错误
发布于 2014-08-22 07:13:24 浏览:4054
`RealBoard4088\software tthread_examples\examples ealboard`下面的例子编译错误,错误信息如下(使用最新的RT-thread、RTGUI), ``` > Start build > scons: Reading SConscript files ... > scons: done reading SConscript files. > scons: Building targets ... > scons: building associated VariantDir targets: build\bsp > CC build\bsp\applications\application.o > CC build\bsp\applications\libc.o > CC build\bsp\applications\mnt.o > CC build\bsp\applications\mnt_nfs.o > CC build\bsp\applications\startup.o > CC build\bsp\drivers\board.o > CC build\bsp\drivers\drv_emac.o > "D:\RealBoard4088\software tthread_examples\drivers\drv_emac.c", line 127: Warning: #177-D: function "read_PHY" was declared but never referenced > static rt_uint16_t read_PHY(rt_uint8_t PhyReg) > ^ > D:\RealBoard4088\software tthread_examples\drivers\drv_emac.c: 1 warning, 0 errors > CC build\bsp\drivers\drv_gd5f1g.o > CC build\bsp\drivers\drv_hy27uf081g.o > CC build\bsp\drivers\drv_i2c.o > CC build\bsp\drivers\drv_key.o > CC build\bsp\drivers\drv_lcd.o > CC build\bsp\drivers\drv_led.o > CC build\bsp\drivers\drv_mpu.o > CC build\bsp\drivers\drv_rtc.o > CC build\bsp\drivers\drv_sd.o > CC build\bsp\drivers\drv_sdram.o > CC build\bsp\drivers\drv_spi.o > CC build\bsp\drivers\drv_sram.o > CC build\bsp\drivers\drv_touch.o > CC build\bsp\drivers\drv_uart.o > CC build\bsp\drivers\drv_uda1380.o > CC build\bsp\ui\appmgr.o > CC build\bsp\ui\apps_list.o > CC build\bsp\ui\block_panel.o > CC build\bsp\ui\ex_app.o > CC build\bsp\ui\picture.o > CC build\bsp\ui\program.o > CC build\bsp\ui ealtouch_ui.o > CC build\bsp\ui\statusbar.o > CC build\kernel\components\dfs\filesystems\devfs\console.o > CC build\kernel\components\dfs\filesystems\devfs\devfs.o > CC build\kernel\components\dfs\filesystems\elmfat\dfs_elm.o > CC build\kernel\components\dfs\filesystems\elmfat\ff.o > CC build\kernel\components\dfs\filesystems\elmfat\option\ccfile.o > CC build\kernel\components\dfs\filesystems
fs\dfs_nfs.o > CC build\kernel\components\dfs\filesystems
fs\mount_clnt.o > CC build\kernel\components\dfs\filesystems
fs\mount_xdr.o > CC build\kernel\components\dfs\filesystems
fs
fs_clnt.o > CC build\kernel\components\dfs\filesystems
fs
fs_xdr.o > CC build\kernel\components\dfs\filesystems
fs pc\auth_none.o > CC build\kernel\components\dfs\filesystems
fs pc\clnt_generic.o > CC build\kernel\components\dfs\filesystems
fs pc\clnt_udp.o > CC build\kernel\components\dfs\filesystems
fs pc\pmap.o > CC build\kernel\components\dfs\filesystems
fs pc pc_prot.o > CC build\kernel\components\dfs\filesystems
fs pc\xdr.o > CC build\kernel\components\dfs\filesystems
fs pc\xdr_mem.o > CC build\kernel\components\dfs\src\dfs.o > CC build\kernel\components\dfs\src\dfs_file.o > CC build\kernel\components\dfs\src\dfs_fs.o > CC build\kernel\components\dfs\src\dfs_posix.o > CC build\kernel\components\drivers\i2c\i2c_core.o > CC build\kernel\components\drivers\i2c\i2c_dev.o > CC build\kernel\components\drivers\mtd\mtd_nand.o > CC build\kernel\components\drivers tc tc.o > CC build\kernel\components\drivers\serial\serial.o > CC build\kernel\components\drivers\spi\spi_core.o > CC build\kernel\components\drivers\spi\spi_dev.o > CC build\kernel\components\drivers\src\completion.o > CC build\kernel\components\drivers\src\dataqueue.o > CC build\kernel\components\drivers\src\pipe.o > CC build\kernel\components\drivers\src\portal.o > CC build\kernel\components\drivers\src ingbuffer.o > CC build\kernel\components\drivers\src\workqueue.o > CC build\kernel\components\external\tjpgd1a\tjpgd.o > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 489: Warning: #188-D: enumerated type mixed with another type > if (b < 0) return 0 - b; /* Err: invalid code or input */ > ^ > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 493: Warning: #188-D: enumerated type mixed with another type > if (e < 0) return 0 - e; /* Err: input */ > ^ > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 511: Warning: #188-D: enumerated type mixed with another type > if (b < 0) return 0 - b; /* Err: invalid code or input error */ > ^ > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 519: Warning: #188-D: enumerated type mixed with another type > if (d < 0) return 0 - d; /* Err: input device */ > ^ > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 833: Warning: #188-D: enumerated type mixed with another type > rc = create_huffman_tbl(jd, seg, len); > ^ > "C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c", line 843: Warning: #188-D: enumerated type mixed with another type > rc = create_qt_tbl(jd, seg, len); > ^> C:\Users\Administrator t-thread\components\external\tjpgd1a\tjpgd.c: 6 warnings, 0 errors > CC build\kernel\components\finsh\cmd.o > CC build\kernel\components\finsh\finsh_compiler.o > CC build\kernel\components\finsh\finsh_error.o > CC build\kernel\components\finsh\finsh_heap.o > CC build\kernel\components\finsh\finsh_init.o > CC build\kernel\components\finsh\finsh_node.o > CC build\kernel\components\finsh\finsh_ops.o > CC build\kernel\components\finsh\finsh_parser.o > CC build\kernel\components\finsh\finsh_token.o > CC build\kernel\components\finsh\finsh_var.o > CC build\kernel\components\finsh\finsh_vm.o > CC build\kernel\components\finsh\msh.o > CC build\kernel\components\finsh\msh_cmd.o > CC build\kernel\components\finsh\shell.o > CC build\kernel\components\finsh\symbol.o > CC build\kernel\components\init\components.o > CC build\kernel\components
et\lwip-1.4.1\src\api\api_lib.o > CC build\kernel\components
et\lwip-1.4.1\src\api\api_msg.o > CC build\kernel\components
et\lwip-1.4.1\src\api\err.o > CC build\kernel\components
etbuf.o > CC build\kernel\components
etdb.o > CC build\kernel\components
etifapi.o > CC build\kernel\components
et\lwip-1.4.1\src\api\sockets.o > CC build\kernel\components
et\lwip-1.4.1\src\api\tcpip.o > CC build\kernel\components
et\lwip-1.4.1\src\arch\sys_arch.o > CC build\kernel\components
et\lwip-1.4.1\src\core\def.o > CC build\kernel\components
et\lwip-1.4.1\src\core\dhcp.o > CC build\kernel\components
et\lwip-1.4.1\src\core\dns.o > CC build\kernel\components
et\lwip-1.4.1\src\core\init.o > "C:\Users\Administrator t-thread\components
et\lwip-1.4.1\src\core\init.c", line 262: Error: #35: #error directive: "lwip_sanity_check: WARNING: MEMP_NUM_TCP_SEG should be at least as big as TCP_SND_QUEUELEN. If you know what you are doing, define LWIP_DISABLE_TCP_SANITY_CHECKS to 1 to disable this error." > #error "lwip_sanity_check: WARNING: MEMP_NUM_TCP_SEG should be at least as big as TCP_SND_QUEUELEN. If you know what you are doing, define LWIP_DISABLE_TCP_SANITY_CHECKS to 1 to disable this error." > scons: building terminated because of errors. > ^> C:\Users\Administrator t-thread\components
et\lwip-1.4.1\src\core\init.c: 0 warnings, 1 error > scons: *** [build\kernel\components
et\lwip-1.4.1\src\core\init.o] Error 1 > Finish. ```
2014-08-23
你可以再更新RB4088的代码,这个编译问题应该修复了 另外,RB4088的在线编译结果可以从下面的链接获得: [https://travis-ci.org/RT-Thread/RealBoard4088](https://travis-ci.org/RT-Thread/RealBoard4088)
yjwpm
2014-08-24
可以正确编译了,还有几处警告。。有时间研究一下,移植到STM32F429上。
4.1k
yjwpm
试贴-消灭0主题
LPC M4的一些资料
LPC4088的临时分支
lpc1788 ad 不稳定
1788 LCD控制器缓冲区字节问题
一起来学习LPC4088吧
上传LPC4088的realtouch主工程
RealBoard 4088预定帖 [第一批板子不多,预定提前结束]
晒RealBoard LPC4088开箱照啦,速带小板凳前来围观
4088主程序需要的SD卡资源
