mo动态模块_Module
应用模块的rt_module_unload函数的bug
发布于 2015-01-29 10:13:58 浏览:3501
从1431行开始: ``` list = &module->module_object[RT_Object_Class_Thread].object_list; while (list->next != list) { object = rt_list_entry(list->next, struct rt_object, list); if (rt_object_is_systemobject(object) == RT_TRUE) { /* detach static object */ rt_thread_detach((rt_thread_t)object); } else { /* delete dynamic object */ rt_thread_delete((rt_thread_t)object); } } ``` 由于list在循环里面从来没有更新过值,如果存在子线程的话,就直接死循环了。可以改为: ``` list = &module->module_object[RT_Object_Class_Thread].object_list; while (list->next != &module->module_object[RT_Object_Class_Thread].object_list) { object = rt_list_entry(list->next, struct rt_object, list); if (rt_object_is_systemobject(object) == RT_TRUE) { /* detach static object */ rt_thread_detach((rt_thread_t)object); } else { /* delete dynamic object */ rt_thread_delete((rt_thread_t)object); } list = list->next; } ``` 当然,我比较常规的写法倒是: ``` struct rt_list_node *node; list = &module->module_object[RT_Object_Class_Thread].object_list; node = list->next; while (node != list) { object = rt_list_entry(node, struct rt_object, list); if (rt_object_is_systemobject(object) == RT_TRUE) { /* detach static object */ rt_thread_detach((rt_thread_t)object); } else { /* delete dynamic object */ rt_thread_delete((rt_thread_t)object); } node = node->next; } ```
2015-01-29
你试过了吗?好像有些问题
eddy0317
2015-01-29
细看一下,module释放对象都是用下面这种结构: ``` list = &module->module_object[对象类型].object_list; while (list->next != list) { object = rt_list_entry(list->next, struct rt_object, list); if (rt_object_is_systemobject(object) == RT_EOK) { /* detach static object */ detach(object); } else { /* delete dynamic object */ delete(object); } } ``` 仔细想一下,按道理的确是正确的。那为什么有问题呢? 仔细看了一下代码,rt_thread_delete里面没有调用rt_object_delete,而rt_thread_detach里面有调用rt_object_detach。估计就是这个问题了。没有rt_object_delete,导致对象链表没有remove这个object。导致死循环了。 而且,细看一下也发现另一个问题: 1227行应该将RT_Object_Class_Thread改为RT_Object_Class_Semaphore。估计是复制过来时候的疏忽? 至于原来的问题,是否在rt_thread_delete里面加上rt_object_delete解决?这个因为对内核还不是很熟悉,不敢加这里。麻烦高手们提供一下建议,我先在module里面加上调试……
eddy0317
2015-01-29
刚试了一下,这里不能直接rt_object_delete。看来是要用我原来那个方法了?原来的方法如果有静态对象,好像也会有问题。
3.5k
eddy0317
貌似stm32f10x的应用模块在1.2.x版本不能正常编译
应用模块打开之后unload之后还在内存中
关于module.c的_load_shared_object的疑问
rtt 如何实现动态加载app
使用zmodem传输文件,应用模块文件传输完成,访问失败
RTT下应用模块编译具体方法
RTT应用模块编译出错
RTT应用模块编译问题
求问动态模块是什么意思呢
应用模块编译出问题
