Kconfig:1: can't open file "/src/Kconfig"
发布于 2019-08-06 17:03:10 浏览:2669
我用> menuconfig 这个指令的时候提示 “> Kconfig:1: can't open file "/src/Kconfig" ” 看了官方文档,试了一下也不行
kuailedeluojie
2019-08-06
>F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\bsp\stm32f40x >> menuconfig >Kconfig:1: can't open file "/src/Kconfig" --- 我把kconfig文件弄到bsp下的stm32f40x目录里面了还是不行
songjie_he
2019-08-06
路径 有问题吧,当时路径不正确碰到过这问题
kuailedeluojie
2019-08-06
>路径 有问题吧,当时路径不正确碰到过这问题 --- >*** End of the configuration. >*** You can execute 'scons' to start the build or try 'scons -h' >*** If you want to generate the IDE's project file, you can use command: >*** 'scons --target=mdk/mdk4/mdk5/iar/cb -s'. >*** If you want to install rt-thread component online,try 'pkgs'. > >GJSUN@DESKTOP-1LORB34 F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\bsp\stm32f40x >> menuconfig >Kconfig:1: can't open file "/src/Kconfig" > >当前路径下没有发现 .config 文件,请确保当前目录为 BSP 根目录。 >如果确定当前目录为 BSP 根目录,请先使用
命令来生成 .config 文件。 > >No system configuration file : .config. >You should use < menuconfig > command to config bsp first. >==============================>The packages have been updated completely. > >scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly >File "F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\bsp\stm32f40x\SConstruct", line 32, in
>IOError: [Errno 2] No such file or directory: 'template.ewp': > File "F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\bsp\stm32f40x\SConstruct", line 39: > DoBuilding(TARGET, objs) > File "F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\tools\building.py", line 669: > EndBuilding(target, program) > File "F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\tools\building.py", line 705: > IARProject('project.ewp', Projects) > File "F:\BaiduNetdiskDownload\2019.8.6\src\rt-thread\tools\iar.py", line 80: > tree = etree.parse('template.ewp') > File "D:\env\tools\Python27\lib\xml\etree\ElementTree.py", line 1182: > tree.parse(source, parser) > File "D:\env\tools\Python27\lib\xml\etree\ElementTree.py", line 647: > source = open(source, "rb") >Create iar project done --- 我用 menuconfig -s 指令后提示的信息
songjie_he
2019-08-06
要不我给你发个我用着的包吧,我用的也是STM32,别再纠结这个问题了,一会给你发网盘地址
songjie_he
2019-08-06
用这个吧,你那个路径明显不对,新手吧 链接:[https://pan.baidu.com/s/1s4DYmPylzK12TOt2T3bUaQ](https://pan.baidu.com/s/1s4DYmPylzK12TOt2T3bUaQ) 提取码:oyoh 复制这段内容后打开百度网盘手机App,操作更方便哦
kuailedeluojie
2019-08-07
>用这个吧,你那个路径明显不对,新手吧 >链接:https://pan.baidu.com/s/1s4DYmPylzK12TOt2T3bUaQ >提取码: ... --- >.config - RootMenu > → Env config ──────────────────────────────────────────────────────────────────────────────────────────────────── > ┌──────────────────────────────────────────────── Env config ────────────────────────────────────────────────┐ > │ Arrow keys navigate the menu.
selects submenus ---> (or empty submenus ----). Highlighted │ > │ letters are hotkeys. Pressing
includes,
excludes,
modularizes features. Press
to │ > │ exit, > for Help, > for Search. Legend: [*] built-in [ ] excluded
module < > module capable │ > │ │ > │ ┌────────────────────────────────────────────────────────────────────────────────────────────────────────┐ │ > │ │ [*] Auto update pkgs config │ │ > │ │ [*] Auto create a mdk/iar project │ │ > │ │ Project type (IAR) ---> │ │ > │ │ [*] pkgs download using mirror server │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ │ │ │ > │ └────────────────────────────────────────────────────────────────────────────────────────────────────────┘ │ > ├────────────────────────────────────────────────────────────────────────────────────────────────────────────┤ > │
< Exit > < Help > < Save > < Load > --- 收到,谢谢你,我是一个新手,我刚上的配置是这个,没有官网说的那个选项,我想把python加到我的板子里面去
kuailedeluojie
2019-08-07
>你要是用stm32 的BSP,现在推荐使用的都是bsp/stm32文件夹下的BSP了 --- 我就在bsp目录下的stm文件夹下用这个指令才会提示上面的问题
kuailedeluojie
2019-08-07
>我就在bsp目录下的stm文件夹下用这个指令才会提示上面的问题 --- 应该是我的rt-thread版本不支持的问题。
kuailedeluojie
2019-08-07
>要不我给你发个我用着的包吧,我用的也是STM32,别再纠结这个问题了,一会给你发网盘地址 ... --- 你好,请问stm32f427应该使用那个bsp包呢
songjie_he
2019-08-08
>你好,请问stm32f427应该使用那个bsp包呢 --- 可以,找对应的型号就行
2.7k
kuailedeluojie
44
135
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
MCXN947测评系列(二)串口设备测评
猪的行独
