Network
STM32F407VET6 + IP101GRI网络移植后ping不成功
发布于 2019-08-16 23:31:14 浏览:3241
硬件: 主控:SMT32F407VET6 PHY: IP101GRI 软件: 系统:已经参考教程移植系统成功 网络:已经根据教程修改了寄存器的地址,使用静态IP调试 目前的现象: 1.接上路由器后,路由器的RJ45灯亮,但闪烁较慢 2.使用wireshark抓不到任何终端发送出来的数据包 3.网络驱动的调试日志如下:会出现receive frame faild的错误 ``` \ | / - RT - Thread Operating System / | \ 4.0.2 build Aug 16 2019 2006 - 2019 Copyright by rt-thread team lwIP-2.0.2 initialized! [53] D/drv.emac: eth hardware init success [60] D/drv.emac: emac hardware start [64] D/drv.emac: emac device init success [68] I/sal.skt: Socket Abstraction Layer initialize success. [75] D/main: start msh />[78] D/drv.emac: PHY ID1:0x0243 [1081] D/drv.emac: Found a phy, address:0x01 [1085] D/drv.emac: RESET PHY! [3088] D/drv.emac: PHY BASIC STATUS REG:0x7849 [4092] D/drv.emac: PHY BASIC STATUS REG:0x7849 [5096] D/drv.emac: PHY BASIC STATUS REG:0x7849 [6100] D/drv.emac: PHY BASIC STATUS REG:0x7849 [7104] D/drv.emac: PHY BASIC STATUS REG:0x7849 [8108] D/drv.emac: PHY BASIC STATUS REG:0x7849 [9112] D/drv.emac: PHY BASIC STATUS REG:0x786D [9116] D/drv.emac: PHY Control/Status REG:0x0105 [9121] D/drv.emac: link up [9124] D/drv.emac: 10Mbps [9127] D/drv.emac: full-duplex 00000000: FF FF FF FF FF FF 00 80 E1 08 34 54 08 06 00 01 ..........4T.... 00000010: 08 00 06 04 00 01 00 80 E1 08 34 54 C0 A8 1F FD ..........4T.... 00000020: 00 00 00 00 00 00 C0 A8 1F FD .......... [9152] D/drv.emac: transmit frame lenth :42 [9156] D/drv.emac: receive frame faild [10160] D/drv.emac: PHY BASIC STATUS REG:0x786D [10164] D/drv.emac: PHY Control/Status REG:0x0105 ``` 4.LWIP的调试日志如下: ``` \ | / - RT - Thread Operating System / | \ 4.0.2 build Aug 16 2019 2006 - 2019 Copyright by rt-thread team igmp_init: initializing dns_init: initializing lwIP-2.0.2 initialized! netif: netmask of interface e0 set to 255.255.255.0 netif: GW address of interface e0 set to 192.168.31.1 netif_set_ipaddr: netif address being changed netif: IP address of interface e0 set to 192.168.31.253 netif: setting default interface e0 igmp_start: starting IGMP processing on if 2000fab4 igmp_lookup_group: allocated a new group with address 224.0.0.1 on if 2000fab4 netif: added interface e0 IP addr 192.168.31.253 netmask 255.255.255.0 gw 192.168.31.1 [106] I/sal.skt: Socket Abstraction Layer initialize success. [113] D/main: start msh />etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_timer dns_tmr: dns_check_entries etharp_request: sending ARP request. pbuf_alloc(length=28) pbuf_alloc(length=28) == 200114a4 etharp_raw: sending raw ARP packet. pbuf_header: old 200114c4 new 200114b6 (14) ethernet_output: sending packet 200114a4 pbuf_free(200114a4) pbuf_free: deallocating 200114a4 igmp_report_groups: sending IGMP reports on if 2000fab4 etharp_timer dns_tmr: dns_check_entries tcpip_thread: CALLBACK 20002f94 lwip_gethostbyname(link.rt-thread.org) failed, err=-6 etharp_timer dns_tmr: dns_check_entries etharp_timer``` 5.使用list_thread查看,接收和发送线程有运行 ```msh />list_thread thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- tshell 20 running 0x00000200 0x00000800 25% 0x0000000a 000 sys_work 23 suspend 0x0000005c 0x00000800 21% 0x0000000a 000 phy 30 suspend 0x00000088 0x00000400 18% 0x00000002 000 tcpip 10 suspend 0x000000c4 0x00000400 19% 0x00000014 000 etx 12 suspend 0x00000094 0x00000400 14% 0x00000010 000 erx 12 suspend 0x00000094 0x00000400 42% 0x00000010 000 tidle0 31 ready 0x00000048 0x00000400 08% 0x00000008 000 main 10 suspend 0x0000008c 0x00000400 53% 0x00000005 000``` 6.使用ifconfig查看,因为使用静态IP所以可以显示预设的IP和网关及子掩码 7.Ping路由器的话会全部超时 自我分析: 1.网口灯会亮且能协商速率成功,PHY芯片应该配置成功了。 2.但无法发送和接收数据是否LWIP有问题? 问题需求: 1. 已经排查一天,因对RT-Thread不是很了解,暂时不知道从哪些方面去排查问题。 2. 麻烦大家给我指明可能存在的问题
2019-08-16
日志只看到发包没看到收包,速度识别为10M,感觉硬件有问题,一般都是100M全双工的。
suhuangjian
2019-08-20
>日志只看到发包没看到收包,速度识别为10M,感觉硬件有问题,一般都是100M全双工的。 ... --- 我修改了drv_eth.c中的rt_stm32_eth_init(rt_device_t dev)函数的中的EthHandle.Init.AutoNegotiation = ETH_AUTONEGOTIATION_ENABLE; 现在ping能够ping通,但会丢包,调试日志发现很多接收失败的报文 ``` [140734] D/drv.emac: PHY Control/Status REG:0x0105 [141209] D/drv.emac: receive frame len : 74 [141214] D/drv.emac: receive frame faild [141218] D/drv.emac: transmit frame lenth :74 [141740] D/drv.emac: PHY BASIC STATUS REG:0x786D [141744] D/drv.emac: PHY Control/Status REG:0x0105 [142216] D/drv.emac: receive frame len : 74 [142220] D/drv.emac: receive frame faild [142224] D/drv.emac: transmit frame lenth :74 [142750] D/drv.emac: PHY BASIC STATUS REG:0x786D [142754] D/drv.emac: PHY Control/Status REG:0x0105 [143223] D/drv.emac: receive frame len : 74 [143227] D/drv.emac: receive frame faild [143231] D/drv.emac: transmit frame lenth :74 [143760] D/drv.emac: PHY BASIC STATUS REG:0x786D [143764] D/drv.emac: PHY Control/Status REG:0x0105 [144230] D/drv.emac: receive frame len : 74 [144234] D/drv.emac: receive frame faild [144238] D/drv.emac: transmit frame lenth :74 [144770] D/drv.emac: PHY BASIC STATUS REG:0x786D [144774] D/drv.emac: PHY Control/Status REG:0x0105 [145236] D/drv.emac: receive frame len : 74 [145241] D/drv.emac: receive frame faild [145245] D/drv.emac: transmit frame lenth :74 [145780] D/drv.emac: PHY BASIC STATUS REG:0x786D [145784] D/drv.emac: PHY Control/Status REG:0x0105 [146243] D/drv.emac: receive frame len : 74 [146247] D/drv.emac: receive frame faild [146251] D/drv.emac: transmit frame lenth :74 [146790] D/drv.emac: PHY BASIC STATUS REG:0x786D [146794] D/drv.emac: PHY Control/Status REG:0x0105 ```
summerxyh
2019-08-20
有同样的问题,ping的时候,对方计算机上可以抓到接收的包,但板子收不到对方发过来的数据包
suhuangjian
2019-08-22
已解决,MCO1的时钟使用了HSI,设置成PLLCLK后网络就稳定了。
2019-08-22
>已解决,MCO1的时钟使用了HSI,设置成PLLCLK后网络就稳定了。 --- 哈哈,HSI竟然还通了,也是神奇。 肯定是协商为10Mbps了,100Mbps时要求时钟好像是50ppm,必须石英晶振。
07lhluo
2021-09-10
这个问题我碰到过,log也是显示[D/drv.emac] phy basic status reg is 0x7849。这个需要改写phy_linkchange()。我之前用的是Marvell 88E6060。phy_linkchange原检测的是BSR寄存器,我改成SSR寄存器,或者交换机的寄存器,就可以了,插拔能正常识别linkstatus以及全双工和speed检测都正常。 receive frame failed可能是网卡硬件的问题。ping不同跟此无关,不是同一个层面的问题。我这边也是这么用,这个log直接忽略掉,完全不影响。ping不通我建议检查一下网卡初始化。
3.2k
suhuangjian
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
【学习分享】初探RT-Thread系统调度
