[已解决]Env生成工程错误
发布于 2019-08-25 15:41:50 浏览:1189
* 本帖最后由 来日方长 于 2019-8-25 19:01 编辑 * 前几天还挺好的,今早打开CubeMX重新配置并修改board目录下的Kconfig后再生成工程后就是这样了: ```*** End of the configuration. *** You can execute 'scons' to start the build or try 'scons -h' *** If you want to generate the IDE's project file, you can use command: *** 'scons --target=mdk/mdk4/mdk5/iar/cb -s'. *** If you want to install rt-thread component online,try 'pkgs'. ==============================> button update done Operation completed successfully. ==============================>The packages have been updated completely. UnicodeDecodeError: 'gbk' codec can't decode bytes in position 21683-21684: illegal multibyte sequence: File "G:\1 Code\STM32\RT_Thread t-thread\bsp\stm32\FogLightMaster\SConstruct", line 63: DoBuilding(TARGET, objs) File "G:\1 Code\STM32\RT_Thread t-thread\tools\building.py", line 786: EndBuilding(target, program) File "G:\1 Code\STM32\RT_Thread t-thread\tools\building.py", line 879: GenTargetProject(program) File "G:\1 Code\STM32\RT_Thread t-thread\tools\building.py", line 815: MDK5Project('project.uvprojx', Projects) File "G:\1 Code\STM32\RT_Thread t-thread\tools\keil.py", line 290: MDK45Project(template_tree, target, script) File "G:\1 Code\STM32\RT_Thread t-thread\tools\keil.py", line 268: out.write(etree.tostring(root, encoding='utf-8').decode()) Create mdk5 project done```工程路径为: G:\1 Code\STM32\RT_Thread t-thread\bsp\stm32\FogLightMaster 其中已经自己修改了工程目录下的SConstruct文件增加了以下几句(在能生成工程前就加上了): ```#encoding=utf8 reload(sys) sys.setdefaultencoding('gbk')```Env工具版本为1.1.1。经过测试重启后问题依旧。将工程目录和rtthread的源码全部移动到G: t-thread\bsp\stm32\FogLightMaster下,测试结果仍然不变: ```*** End of the configuration. *** You can execute 'scons' to start the build or try 'scons -h' *** If you want to generate the IDE's project file, you can use command: *** 'scons --target=mdk/mdk4/mdk5/iar/cb -s'. *** If you want to install rt-thread component online,try 'pkgs'. ==============================> button update done Operation completed successfully. ==============================>The packages have been updated completely. UnicodeDecodeError: 'gbk' codec can't decode bytes in position 21683-21684: illegal multibyte sequence: File "G: t-thread\bsp\stm32\FogLightMaster\SConstruct", line 63: DoBuilding(TARGET, objs) File "G: t-thread\tools\building.py", line 786: EndBuilding(target, program) File "G: t-thread\tools\building.py", line 879: GenTargetProject(program) File "G: t-thread\tools\building.py", line 815: MDK5Project('project.uvprojx', Projects) File "G: t-thread\tools\keil.py", line 290: MDK45Project(template_tree, target, script) File "G: t-thread\tools\keil.py", line 268: out.write(etree.tostring(root, encoding='utf-8').decode()) Create mdk5 project done``` ============================================================================================问题已经解决,感谢群内的老哥帮助,大概问题出在了一些之前编辑留下的废弃不用的.c文件采取了中文命名,删除这些文件后重新编译后就一切正常
我夏了夏天
2019-08-25
确实,现在不能加有中文名的 c 文件。
1.2k
来日方长
35
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
