; r7 N, L( z2 e) X7 K! R- |" k5 S3 [" ]. `
rt-thread 中支持的 rt-thread_mdelay 函数,是一个绝对延时函数。如果周期执行某一个动作,这个函数就不太适合。并且之前有帖子提到相对延时的问题。想必这个功能还是比较常用的。下面就贴一段代码供大家参考。" i3 c0 Z- `% l) g& {. @- C/ `
基本实现原理就是定时器进行周期定时,时间到了发送信号量。线程里面等待信号量,等到信号量了,代表定时时间到了。就去执行相应的动作。并且执行动作区间,定时器仍在运行,所以周期是准确的。% G" c0 V( i2 b' F2 R
" m$ x+ e+ i2 Q2 \
9 T `! b! g$ n4 n& A
0 f, J5 I% {' X; g" z' e
下面是相对延时的实现代码:
/ C8 r" C5 E* W3 z t5 ~7 X3 o6 o( g
- #include <rtthread.h>9 b/ h; A8 U: }' M" T2 a
- 3 h2 S- D& D }( u" S0 s0 s
- struct d_until( \! O3 R/ S) e8 E' P: S% K$ A% Y
4 R9 d; O0 @3 Z0 {7 g# M - struct rt_timer time;
. P7 x Q3 C3 i/ t% \ - struct rt_semaphore sem;* X, o3 N' ?: b% F
- rt_tick_t tick;8 _7 n1 K& U4 g$ l4 G
- };1 Y; H' o. R+ \, Y
- typedef struct d_until * d_until_t;
4 y: m) y4 k& T/ W+ c/ h: L* z; H
/ @& W. k( \& j- static void thread_delay_until_handle(void *param)' K- v: [" }3 `1 s. j
. Q) a [; Z' b7 v3 c% j0 Z) f - d_until_t _obj = param;: u( p8 B4 Q8 }0 r+ P2 X% y# g6 a
- ) k/ B4 _1 ^& W1 U) w4 t
- rt_sem_release(&_obj->sem);- g% r5 B- F. [8 E7 \# @8 U( {% z
- }% t9 H! A I) E. V/ s7 z" J
; K3 Q% a; l- o- d_until_t delay_until_create(const char *name)
3 S9 [+ H) W0 y! M( B - {
c. x5 k% E& q& N6 A2 |: w - d_until_t _obj;* r& N/ H# [4 L" k" y( b4 G
- ( x$ e, c2 [. n! n8 g0 y3 m- z' Y
- _obj = rt_calloc(1, sizeof(struct d_until));6 h4 P ]( e3 G; |7 W% V( l
- if (_obj == RT_NULL)$ { k1 T6 R% n0 d- d$ f
% z/ c( |+ a1 I) `$ A. d g - return RT_NULL;% e. d1 y! I% g/ ] ]$ T
- }+ a% Q& k Z: z1 g+ X# L5 O2 C0 ~6 H: m# G
- rt_timer_init(&_obj->time, name, thread_delay_until_handle,: A/ t! C4 {2 E9 o8 h
- _obj, 0, RT_TIMER_FLAG_PERIODIC);
9 Y7 n3 y# F b) A$ v5 a - rt_sem_init(&_obj->sem, name, 0, RT_IPC_FLAG_FIFO);
# [9 H7 b+ z; O1 t/ T* U( m - return _obj;
! [9 y& s) e' _7 [# Y- |- d& J - }' T. w" u8 l, @: |# l1 {2 a
2 {; x% I2 H: g/ g- rt_err_t delay_until_run(d_until_t obj, rt_tick_t tick)9 c. ?( ?: z3 |& K; x- s
! ]' X, I! d# N d' E U( ` - if (obj->tick != tick): d) u3 J) }$ C2 g
* B1 m/ X, |- L9 `+ l% S/ d - rt_timer_control(&obj->time, RT_TIMER_CTRL_SET_TIME, &tick);
" _$ k# I, ]) m: r# P* T - obj->tick = tick;7 z8 m; \# Z# q: G2 b; b8 K( e4 N
- rt_timer_start(&obj->time);* w" ]6 w8 Z7 x7 N0 J/ ?
/ Q& a' v! N# l - return rt_sem_take(&obj->sem, RT_WAITING_FOREVER);
: q2 J/ c# d, j& D5 X - }
7 k; m6 B$ s3 Q - . I+ ]1 b, y8 e n
- void delay_until_stop(d_until_t obj)
- R9 c. P1 y7 T3 G) Q6 u; t, ]# ~ - {! H' @/ E; l r& C/ {
- rt_timer_stop(&obj->time);' }6 b$ ~ g' i: P% R
- while (rt_sem_take(&obj->sem, 0) == RT_EOK);
! |) }/ c, s* J) G% s: L1 c - obj->tick = 0;" b4 v M* V- F1 r @: N9 r2 F" l
+ K7 C8 K+ l6 u% K! @# B* S7 j - 8 t2 X& H2 E/ }5 o+ P' ?! g1 ` J
- void delay_until_delete(d_until_t obj)6 D- B5 ^( w( l5 } ]
- {. J, y3 g( s' ^; y# H
- delay_until_stop(obj);
" E# N$ z6 i7 t - rt_timer_detach(&obj->time);) i* X9 D. a4 |8 T3 P6 d& ^
- rt_sem_detach(&obj->sem); M- {6 @/ A. S
复制代码
8 W% G( e5 m# } k5 A; |7 C7 F7 Z9 i6 J$ v4 h
上面代码中提供了 4 个 API
/ F3 I, f* C) M% T+ W& c
. u/ e1 s# z( l- d_until_t delay_until_create(const char *name) 创建相对延时
复制代码- rt_err_t delay_until_run(d_until_t obj, rt_tick_t tick) 相对延时
复制代码- void delay_until_stop(d_until_t obj) 停止延时
复制代码- void delay_until_delete(d_until_t obj) 删除相对延时
复制代码
# w3 R5 d9 h _+ i( D7 K5 R
2 e, t8 o5 @8 p& h使用示例 :
8 A, Q8 E# S3 [% R6 s- int main(void)1 n* _2 h$ ]- _- b) r+ X
! n) t& V* O" c, {# ] - void *delay;0 R) T' w6 b: \3 u( p. x* Y
- rt_bool_t isrun = RT_TRUE;6 F2 W8 r. i2 y( n" N
- 2 p5 q) {* G/ o2 U
- delay = delay_until_create("delay"); // 创建相对延时
% S# D+ t8 y, p - while (isrun)
, _% c, t( _: Z) I - {
/ u9 b4 U' Y3 G# V - printf("delay...\n");* u& B6 z) L0 N& G4 X
- delay_until_run(delay, 500); // 延时 500 个 tick
. n- p' E0 E- l2 a7 q1 g# x - }
! t( Z% [4 ~% T# H. Q - delay_until_delete(delay); // 删除相对延时
, g R. x+ o! x w# _ - 3 t, M! n9 G3 g6 _# b5 ?% z& M; C
- return 0;
- ]; ^3 @3 E* e! q# N" K( U$ d' | - }
复制代码 * m3 I" X" j" |% v3 i6 ^- r
6 Z9 L1 {' b" W5 j( ^8 p
) k5 R9 e; Z0 _% {# y; e0 G$ g8 _
