潘多拉用TIM CHI 做PWM输出,程序编译无错误,但没输出
发布于 2019-08-27 22:15:00 浏览:1162
**1、cube配置,生成代码** ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10422&size=300x300&key=c1865573b9195db2&nocache=yes&type=fixnone) **2、修改kconfig文件**** ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10423&size=300x300&key=a9b50057910bacb8&nocache=yes&type=fixnone) ** **3、env配置PWM1 CH1**** ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10424&size=300x300&key=202395f133a6272d&nocache=yes&type=fixnone) ** **4、修改驱动** ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10425&size=300x300&key=73c2c31cfafbad44&nocache=yes&type=fixnone) ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10426&size=300x300&key=d385ec298fd084d0&nocache=yes&type=fixnone) ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10427&size=300x300&key=de50beb2de3d325b&nocache=yes&type=fixnone) 5、线程例程 ```c #include
#define PWM_DEV_NAME "pwm1" /* PWM设备名称 */ #define PWM_DEV_CHANNEL 1 /* PWM通道 */ #define THREAD_PRIORITY 25 /* 线程优先级 */ #define THREAD_STACK_SIZE 512 /* 线程栈大小 */ #define THREAD_TIMESLICE 5 /* 线程时间片大小 */ static rt_thread_t tid1 = RT_NULL; /* 线程句柄 */ struct rt_device_pwm *pwm_dev; /* PWM设备句柄 */ static rt_uint32_t period = 500000; /* 周期为0.5ms,单位为纳秒ns */ static rt_uint32_t pulse = 250000; /* PWM脉冲宽度值的增减方向 */ /* 线程 pwm_entry 的入口函数 */ static void pwm_entry(void *parameter) { rt_uint32_t count = 0; while (1) { rt_thread_mdelay(50); rt_kprintf("pwm out pulse=%d
", pulse); /* step 2、设置 PWM 周期和脉冲宽度,输出特定的波形 */ rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); } /* step 3、如果不再使用该通道,可以关闭 PWM 通道的输出 */ // rt_pwm_disable(pwm_dev, PWM_DEV_CHANNEL); } static int pwm_test(int argc, char *argv[]) { rt_err_t sate1; /* step 1.1、查找 PWM 设备 */ pwm_dev = (struct rt_device_pwm *)rt_device_find(PWM_DEV_NAME); if (pwm_dev == RT_NULL) { rt_kprintf("pwm sample run failed! can't find %s device!
", PWM_DEV_NAME); return RT_ERROR; } rt_kprintf("pwm sample run success! find %s device!
", PWM_DEV_NAME); /* step 1.2、设置 PWM 周期和脉冲宽度默认值 */ sate1=rt_pwm_set(pwm_dev, PWM_DEV_CHANNEL, period, pulse); rt_kprintf("sate1=%d
", sate1); /* step 1.3、使能 PWM 设备的输出通道 */ sate1=rt_pwm_enable(pwm_dev, PWM_DEV_CHANNEL); rt_kprintf("sate2=%d
", sate1); /* 创建线程,名称是 pwm_thread ,入口是 pwm_entry*/ tid1 = rt_thread_create("pwm_thread", pwm_entry, RT_NULL, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); /* 如果获得线程控制块,启动这个线程 */ if (tid1 != RT_NULL) rt_thread_startup(tid1); return RT_EOK; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pwm_test, pwm sample); ``` 6、现象 发送 pwm_test命令 ,返回 ![110,0](https://www.rt-thread.org/qa/forum.php?mod=image&aid=10428&size=300x300&key=7d0d17937baff484&nocache=yes&type=fixnone) 但是板子上的灯没有反应 各位大佬,求找找问题!万分感谢!!!!
tyustli
2019-08-28
楼主仔细看一下这篇文章吧 [https://www.rt-thread.org/document/site/application-note/driver/pwm/an0037-rtthread-driver-pwm/](https://www.rt-thread.org/document/site/application-note/driver/pwm/an0037-rtthread-driver-pwm/)
1.2k
君墨竹
玩iot camera笔记之3测试试用3路pwm
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
