[第二期 空气质量分析仪]第1周作业
发布于 2019-08-29 22:26:15 浏览:877
* 本帖最后由 大李ll28 于 2019-8-29 22:26 编辑 * 想学习一个RTOS已经很久了,关注RT-Thread也有一段时间了,这次正好有训练营活动,果断参与。[align=center] [align=center]第一周实验:通用STM32F103C8+温湿度模块AM2320[align=center] 任务1:创建BSP 根据文档**STM32系列BSP制作教程.md一步一步照做,顺利完成。** **任务2:实现按键模块** **顺利实现,需要注意的一点是外部按键需要增加上拉(我的板上是按键按下为低),否则释放时中断响应很慢(中断为双沿触发)。** //#include
#include "led_alert.h" #include "key.h" /* defined the LED0 pin: PB1 */ #define KEY_PIN GET_PIN(A, 8) void key_init(void) { rt_pin_mode(KEY_PIN, PIN_MODE_INPUT_PULLUP); rt_pin_attach_irq(KEY_PIN, PIN_IRQ_MODE_RISING_FALLING, key_cb, RT_NULL); rt_pin_irq_enable(KEY_PIN, PIN_IRQ_ENABLE); } void key_cb(void *args) { rt_pin_irq_enable(KEY_PIN, PIN_IRQ_DISABLE); if (!rt_pin_read(KEY_PIN)) { rt_kprintf("key pressed down!...
"); led_on(0); } else { rt_kprintf("key released up!...
"); led_off(0); } rt_pin_irq_enable(KEY_PIN, PIN_IRQ_ENABLE); } **任务3:实现报警模块** **就是点LED灯,无他按照PIN设备处理即可。** #include
#include "led_alert.h" /* defined the LED0 pin: PB1 */ #define LED0_PIN GET_PIN(A, 1) #define LED1_PIN GET_PIN(C, 14) void led_init(void) { rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT); rt_pin_write(LED0_PIN, PIN_HIGH); rt_pin_write(LED1_PIN, PIN_HIGH); } void led_on(int num) { switch (num) { case 0 : rt_pin_write(LED0_PIN, PIN_LOW); break; case 1 : rt_pin_write(LED1_PIN, PIN_HIGH); break; default: rt_pin_write(LED0_PIN, PIN_LOW); rt_pin_write(LED1_PIN, PIN_HIGH); break; } } void led_off(int num) { switch (num) { case 0 : rt_pin_write(LED0_PIN, PIN_HIGH); break; case 1 : rt_pin_write(LED1_PIN, PIN_LOW); break; default: rt_pin_write(LED0_PIN, PIN_HIGH); rt_pin_write(LED1_PIN, PIN_LOW); break; } } void led_blink(int num, int delay) { led_on(num); rt_thread_mdelay(delay); led_off(num); rt_thread_mdelay(delay); } **任务4:温湿度传感器驱动** **我的温湿度传感器RT没有现成驱动,于是自己动手实现驱动,几经周折,后经Yang老师指点,发现错误指定了管脚号,修改正确后,IIC通讯正常。** ![无命名.png](/uploads/201908/29/222024kpbs0h0bphginhmj.png) **经验所得:** **1.本人不喜欢冗余庞大的东西,所以解压了RT4.0.1后首先删除了bsp下stm32/libraries****以外的所有目录,然后删除了****stm32/libraries中与stm32f10x无关的文件,整个系统马上瘦身600M。** **2. CubeMX其实仅用来连接串口、配置时钟、下载方式,别的不用配置。** **3. ****template.uvprojx是Keil项目的模板文件,所以如果要更改芯片、更改debug方式等,只需要更改该模板文件,scons --target=mdk5后更改直接反映到实际的工程中。** **4. RT menuconfig中的IIC管脚号不是硬件MCU的管脚编号,而是文件drv_gpio.c中的编号,这一点需要特别注意。** 下载附件 [key.c](https://oss-club.rt-thread.org/uploads/201908/29/222123avrzcvgjcneaeogd.attach)
大李ll28
2019-08-31
>第一条经验不实用 >scons --dist 这个命令,你可以看看是干什么用的~~ >https://www.rt-thread.org/documen ... --- 之所以没有使用--dist主要是dist后的目录结构和原始git clone下来的目录结构是有差异的。直接删除不需要的bsp、库,一方面即减小了整个工程的大小也保证目录结构不变,另外一方面当你有新的bsp时,直接在裁减后的基础上增加相关文件即可(如果器件一样,就是新创建个bsp目录,不用另外拷贝其他文件),而不需要重新打包,重新复制一份RT kernel、component等公共文件。
877
大李ll28
MCXN947测评系列(二)串口设备测评
测试DFS+elm的删除命令rm,有点搞笑的经历
vision board 开箱
猪的行独
