[实战入门学习营] [第二期 空气质量分析仪]第1周作业
发布于 2019-08-30 01:41:15 浏览:860
目标: 任务 1、BSP 跑起来 任务 2、实现按键模块/* 引脚编号,通过查看设备驱动文件drv_gpio.c确定 */ #define KER_USER_PIN_NUM (45)//GET_PIN(C, 13) int key_value; static void key_scan(void) { key_value ++; key_value = key_value % 3; } static void pin_key_sample(void) { /* 按键0引脚为输入模式 */ rt_pin_mode(KER_USER_PIN_NUM, PIN_MODE_INPUT_PULLUP); /* 绑定中断,下降沿模式,回调函数名为beep_on */ rt_pin_attach_irq(KER_USER_PIN_NUM, PIN_IRQ_MODE_FALLING, key_scan, RT_NULL); /* 使能中断 */ rt_pin_irq_enable(KER_USER_PIN_NUM, PIN_IRQ_ENABLE); } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(pin_key_sample, pin key sample); 任务 3、实现报警模块 #include
#include "key.h" /* 指向线程控制块的指针 */ static rt_thread_t tid = RT_NULL; /* 指向信号量的指针 */ static rt_sem_t sem_led_blink = RT_NULL; static rt_sem_t sem_led_on = RT_NULL; #define THREAD_STACK_SIZE (1024) #define THREAD_PRIORITY (10) #define THREAD_TIMESLICE (20) /* defined the LED0 pin: PA5 */ #define LED0_PIN GET_PIN(A, 5) #define LED_B GET_PIN(A, 6) void led_init(void) { rt_kprintf("init led!
"); /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); } void led_on(void) { rt_kprintf("turn on led!
"); /* 拉 高 LED引 脚 */ rt_pin_write(LED0_PIN, PIN_HIGH); } void led_off(void) { rt_kprintf("turn off led!
"); /* 拉 低 LED引 脚 */ rt_pin_write(LED0_PIN, PIN_LOW); } void led_blink(void) { static rt_bool_t state = PIN_HIGH; rt_kprintf("blink led!
"); state = ~state; rt_pin_write(LED0_PIN, state); } void thread_sem_entry(void *pra) { while(1) { if(key_value == 1) {/* 释放一次信号量 */ rt_thread_mdelay(500); rt_sem_release(sem_led_blink); } else if(key_value == 2) { rt_sem_release(sem_led_on); } else { /*do_nothing*/ } } } void thread_led_entry(void *pra) { led_init(); while(1) { if (rt_sem_take(sem_led_blink, RT_WAITING_FOREVER) == RT_EOK) { led_blink(); } else if(rt_sem_take(sem_led_on, RT_WAITING_FOREVER) == RT_EOK) { led_on(); } else { led_off(); } rt_thread_mdelay(100); } } int led_alert_sample() { /* 创建2个信号量,初始值是0 */ sem_led_blink = rt_sem_create("sem_led_blink", 0, RT_IPC_FLAG_PRIO); if (sem_led_blink == RT_NULL) { rt_kprintf("create sem thread failed
"); return RT_ERROR; } sem_led_on = rt_sem_create("sem_led_on", 0, RT_IPC_FLAG_PRIO); if (sem_led_on == RT_NULL) { rt_kprintf("create sem thread failed
"); return RT_ERROR; } /* 创建线程 */ tid = rt_thread_create("thread_sem", thread_sem_entry, RT_NULL, /* thread_sem_entry, 入口参数是RT_NULL */ THREAD_STACK_SIZE, THREAD_PRIORITY-1, THREAD_TIMESLICE); if (tid != RT_NULL) rt_thread_startup(tid); else { rt_kprintf("create sem thread failed
"); return RT_ERROR; } /* 创建线程 */ tid = rt_thread_create("thread_led", thread_led_entry, RT_NULL, /* thread_sem_entry, 入口参数是RT_NULL */ THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); if (tid != RT_NULL) rt_thread_startup(tid); else { rt_kprintf("create led thread failed
"); return RT_ERROR; } return RT_EOK; } MSH_CMD_EXPORT(led_alert_sample,led_alert sample); 任务 4、实现温湿度传感器驱动(To be continue) \ | / - RT - Thread Operating System / | \ 4.0.1 build Aug 30 2019 2006 - 2019 Copyright by rt-thread team [I/SAL_SKT] Socket Abstraction Layer initialize success. [I/at.clnt] AT client(V1.2.0) on device uart6 initialize success. [I/at.rw007] AT network initialize success! [E/sensor.bosch.bme280] can not find device msh />pin_key_sample msh />ps thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- tshell 20 running 0x00000140 0x00001000 12% 0x00000009 000 at_clnt 9 suspend 0x000000ac 0x00000600 11% 0x00000001 000 tidle0 31 ready 0x00000048 0x00000100 35% 0x00000017 000 msh />led_alert_sample init led! msh />blink led! blink led! blink led! blink led! blink led! blink led! blink led!
beidou
2019-09-01
>好的 继续加油哦~ >以后交作业,可以把代码放在代码格式中,就不会看起来乱乱的了 >发帖时候菜单有个按钮,类 ... --- 好! 这个可以重新编辑么?
beidou
2019-09-01
[i=s] 本帖最后由 beidou 于 2019-9-1 16:21 编辑 [/i] **CS:高电平有效。 SDO:作为device address的LSB** [attach]10608[/attach] **重新连接后,调试通过**: [attach]10609[/attach]
860
beidou
NXP MCXN947测评之 adc
