menuconfig似乎没添加成功IIC
发布于 2019-09-01 10:06:38 浏览:1215
版本: tr thread 4.0.2,参考 AN0003 I2C设备应用指南 在 bsp\stm32\stm32f103-mini-system 中env 启动menuconfig ,选中IIC,然后保存 然后执行: ```$ pkgs --update Operation completed successfully.``` 再执行: ```$ scons --target=mdk5 scons: Reading SConscript files ... scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build CC build\applications\main.o CC build\board\board.o CC build\board\CubeMX_Config\Src\stm32f1xx_hal_msp.o CC build\kernel\components\drivers\i2c\i2c-bit-ops.o CC build\kernel\components\drivers\i2c\i2c_core.o CC build\kernel\components\drivers\i2c\i2c_dev.o CC build\kernel\components\drivers\misc\pin.o CC build\kernel\components\drivers\serial\serial.o CC build\kernel\components\drivers\src\completion.o CC build\kernel\components\drivers\src\dataqueue.o CC build\kernel\components\drivers\src\pipe.o CC build\kernel\components\drivers\src ingblk_buf.o CC build\kernel\components\drivers\src ingbuffer.o CC build\kernel\components\drivers\src\waitqueue.o CC build\kernel\components\drivers\src\workqueue.o CC build\kernel\components\finsh\cmd.o CC build\kernel\components\finsh\msh.o CC build\kernel\components\finsh\msh_cmd.o CC build\kernel\components\finsh\msh_file.o CC build\kernel\components\finsh\shell.o CC build\kernel\components\finsh\symbol.o CC build\kernel\components\libc\compilers\common\time.o CC build\kernel\libcpu\arm\common\backtrace.o CC build\kernel\libcpu\arm\common\div0.o CC build\kernel\libcpu\arm\common\showmem.o AS build\kernel\libcpu\arm\cortex-m3\context_rvds.o CC build\kernel\libcpu\arm\cortex-m3\cpuport.o CC build\kernel\src\clock.o CC build\kernel\src\components.o CC build\kernel\src\cpu.o CC build\kernel\src\device.o CC build\kernel\src\idle.o CC build\kernel\src\ipc.o CC build\kernel\src\irq.o CC build\kernel\src\kservice.o CC build\kernel\src\mem.o CC build\kernel\src\mempool.o CC build\kernel\src\object.o CC build\kernel\src\scheduler.o CC build\kernel\src\signal.o CC build\kernel\src\thread.o CC build\kernel\src\timer.o AS F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\CMSIS\Device\ST\STM32F1xx\Source\Templates\arm\startup_stm32f103xb.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\CMSIS\Device\ST\STM32F1xx\Source\Templates\system_stm32f1xx.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_dma.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_cortex.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_crc.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_pwr.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_rcc.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_rcc_ex.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_cec.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_sram.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_gpio.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_gpio_ex.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_uart.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_usart.o CC F: t-thread\bsp\stm32\libraries\STM32F1xx_HAL\STM32F1xx_HAL_Driver\Src\stm32f1xx_hal_i2c.o CC F: t-thread\bsp\stm32\libraries\HAL_Drivers\drv_gpio.o CC F: t-thread\bsp\stm32\libraries\HAL_Drivers\drv_usart.o CC F: t-thread\bsp\stm32\libraries\HAL_Drivers\drv_common.o LINK rt-thread.elf fromelf --bin rt-thread.elf --output rtthread.bin fromelf -z rt-thread.elf scons: done building targets. ``` 打开项目,并没有drv_i2c的相关文件,仍然只有默认的drv_gpio, drv_usart,问题在哪里呢? ![1.png](https://oss-club.rt-thread.org/uploads/201909/01/095709in8ux1lr8j6adxwg.png) ![2.png](https://oss-club.rt-thread.org/uploads/201909/01/095757t0mzwkzfw0bjwjj0.png) ![3.png](https://oss-club.rt-thread.org/uploads/201909/01/100631yxybmyyfxxffqmrx.png)
pkokoc
2019-09-01
查看 .config 文件,已经使能I2C了。但项目中为啥找不到驱动文件drv_i2c呢? # # Device Drivers # CONFIG_RT_USING_DEVICE_IPC=y CONFIG_RT_PIPE_BUFSZ=512 # CONFIG_RT_USING_SYSTEM_WORKQUEUE is not set CONFIG_RT_USING_SERIAL=y CONFIG_RT_SERIAL_USING_DMA=y CONFIG_RT_SERIAL_RB_BUFSZ=64 # CONFIG_RT_USING_CAN is not set # CONFIG_RT_USING_HWTIMER is not set # CONFIG_RT_USING_CPUTIME is not set **CONFIG_RT_USING_I2C=y CONFIG_RT_USING_I2C_BITOPS=y** CONFIG_RT_USING_PIN=y
tyustli
2019-09-02
>查看 .config 文件,已经使能I2C了。但项目中为啥找不到驱动文件drv_i2c呢? ># ># Device Drivers --- 你打开的只是 I2C 框架,BSP 的 I2C 还没有打开,一般框架是不需要自己去打开的,具体 BSP I2C 驱动选中之后会 select 框架的代码[attach]10617[/attach] 打开 BSP 的 I2C 可以看一下下面这张图 [attach]10618[/attach]
pkokoc
2019-09-03
经过摸索发现:由于stm32f103-mini-system的BSP目前不支持I2C,因此需要先在BSP中增加I2C,然后才能做后续的配置和操作。把摸索的经过写了个文档,大家可以参考 : 《STM32F103C8T6最小系统RT Thread BSP增加I2C外设读取MPU6050模块数据》 [https://blog.csdn.net/pkokocl/article/details/100521737](https://blog.csdn.net/pkokocl/article/details/100521737)
1.2k
pkokoc
120
NXP的I2C应该比ST的好用吧
Use of I2C device driver
关于I2C 驱动问题请教
我如何知道这个iic的io配置和我电路设计的是一致的?
I2C模拟读操作失败,不知道问什么进不去读函数
RTT的I2C有官方文档资料没有
求 STM32F103 IIC 自定义IO初始化 代码
报一个LPC4008代码中I2C的bug
RTOS IIC总线使用
关于在RTT中使用STM32 I2C的疑问
