关于DMA串口运行卡死的疑问真的有点不太懂所以问下各位...
发布于 2019-09-03 18:07:09 浏览:1986
话不多说先贴程序 #include
#define uart_name "uart3" /* 串口设备名称 */ char weight=0; //设置重量接收位 char str[] ={0xA3,0x00,0xA2,0xA4,0xA5}; //发送指令 static rt_thread_t thread; //定义一个线程的结构体 char rx_buffer[RT_SERIAL_RB_BUFSZ + 1]; struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; static char msg_pool[512]; /* 串口接收消息结构*/ struct rx_msg { rt_device_t dev; rt_size_t size; }; /* 串口设备句柄 */ static rt_device_t serial; /* 消息队列控制块 */ static struct rt_messagequeue rx_mq; /* 接收数据回调函数 */ static rt_err_t uart_input(rt_device_t dev, rt_size_t size) { struct rx_msg msg; rt_err_t result; msg.dev = dev; msg.size = size; result = rt_mq_send(&rx_mq, &msg, sizeof(msg)); if ( result == -RT_EFULL) { /* 消息队列满 */ rt_kprintf("message queue full!
"); } return result; } void uart_config() //配置串口波特率、数据位、停止位、奇偶校验位 { config.baud_rate = BAUD_RATE_9600; config.data_bits = DATA_BITS_8; config.stop_bits = STOP_BITS_1; config.parity = PARITY_NONE; } static void uart_thread_entry(void *parameter) { struct rx_msg msg; rt_err_t result; rt_uint32_t rx_length; while (1) { rt_device_write(serial, 0, str, sizeof(str)); rt_memset(&msg, 0, sizeof(msg)); /* 从消息队列中读取消息*/ result = rt_mq_recv(&rx_mq, &msg, sizeof(msg), RT_WAITING_FOREVER); if (result == RT_EOK) { /* 从串口读取数据*/ rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size); rx_buffer[rx_length] = '\0'; /* 直接通过这个函数来判断发送过来的数据 */ if(rx_buffer[6]>0x13&&rx_buffer[6]<0x18) { rt_kprintf("ok!
"); weight=rx_buffer[6]; } else { rt_kprintf("NO!@#$"); rt_kprintf("%c
",rx_buffer[6]); } rt_kprintf("abcdefg
"); } // rt_err_t rt_thread_yield(void); } } int main() { /* 查找串口设备 */ serial = rt_device_find(uart_name); if (!serial) { rt_kprintf("find %s failed!
", uart_name); return RT_ERROR; } /* 初始化消息队列 */ rt_mq_init(&rx_mq, "rx_mq", msg_pool, /* 存放消息的缓冲区 */ sizeof(struct rx_msg), /* 一条消息的最大长度 */ sizeof(msg_pool), /* 存放消息的缓冲区大小 */ RT_IPC_FLAG_FIFO); /* 如果有多个线程等待,按照先来先得到的方法分配消息 */ /* 以 DMA 接收及轮询发送方式打开串口设备 */ rt_device_open(serial, RT_DEVICE_FLAG_DMA_RX); /*串口波特率优先级配置*/ uart_config(); /* 打开设备后才可修改串口配置参数 */ if(rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &config)==RT_EOK) { rt_kprintf("ok"); } /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial, uart_input); /* 创建 serial 线程 */ thread = rt_thread_create("serial", uart_thread_entry, RT_NULL, 1024, 25, 10); /* 创建成功则启动线程 */ rt_thread_startup(thread); // thread = rt_thread_create("serial1", serial_thread_entry, RT_NULL, 1024, 25, 10); // /* 创建成功则启动线程 */ // rt_thread_startup(thread); } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(main, uart device dma sample); 这是基于他给的例程所改的程序 发送一次接收一次 通过串口一打印字符来判断这个称重传感器是否有接收到我们想要的数据 但是现在的问题来了如果加了rt_kprintf("abcdefg
");(当然内容随便什么都行)程序可以一直while循环一直进行如果不加只能运行一部分就卡死了 所以不懂是哪里没写好,还请各位帮帮忙谢谢。 ![卡死的程序.bmp](https://oss-club.rt-thread.org/uploads/201909/03/180554w7gj175gqgabpfp9.bmp) ![不卡死程序.bmp](https://oss-club.rt-thread.org/uploads/201909/03/180600uwbwb3mj2j0av3fc.bmp)
还没想好
2019-09-03
从目前给的信息分析,卡死的原因未知。但是读取数据时,建议判断下读取到的长度,防止访问到脏数据。 rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size); if (rx_length > 0) { }
绿的森林
2019-09-03
>从目前给的信息分析,卡死的原因未知。但是读取数据时,建议判断下读取到的长度,防止访问到脏数据。 > >rx_l ... --- 好的我试试
绿的森林
2019-09-03
>从目前给的信息分析,卡死的原因未知。但是读取数据时,建议判断下读取到的长度,防止访问到脏数据。 > >rx_l ... --- 大佬好像不是这个问题的感觉
2019-09-03
可以先看看文档里说的, [https://www.rt-thread.org/document/site/programming-manual/device/uart/uart/#dma](https://www.rt-thread.org/document/site/programming-manual/device/uart/uart/#dma) 然后也确认下底层驱动是否支持DMA模式。
绿的森林
2019-09-03
>大佬好像不是这个问题的感觉 --- 欧克欧克 谢谢大佬警报解除 延时要加
绿的森林
2019-09-03
不行前面底下那句话没删延时也不行
绿的森林
2019-09-03
>可以先看看文档里说的, > >https://www.rt-thread.org/document/site/programming-manual/device/uart/uart/ ... --- 我就是跟着例程来的 用的是F103VET6
2k
绿的森林
rt thread 2.0.2 usart 接收缓存问题
关于STM32串口通信的问题
STM32F1+RTT串口接收终端数据丢失问题
UART TX丢数据?
RTT打开串口的时候如何自定义波特率呢?
STM32F4的USART数据接收问题
串口1234使用问题
串口接收回调函数
LPC18xx UART问题讨论
x1000串口配置的失败问题
