总线错误地址52370036
发布于 2019-09-11 10:03:16 浏览:2195
cm_backtrace里面出现 ```[40140112] E/cmb mqtt0: The bus fault occurred address is 52370036```这里的“52370036”是十六进制地址吗,如果是的话,根据stm32f103ze的芯片手册,0x40024400-0x5FFFFFFF是Reserved,错误信息为什么会定位到这里呢? 感觉cm_backtrace玩不转,想问下还有别的办法定位错误信息吗,调试经验少,请高手指教下。 下面附一下cm_backtrace的log ```msh />ls Directory /: recvdata_p1.csv 0 msh />[40129704] E/at.clnt at_clnt: AT Client receive failed, uart device get data error(-2) [40129713] E/at.skt at_clnt: esp8266 device(esp0) receive size(2) data failed. [40134702] E/mqtt mqtt0: [40134702] wait Ping Response res: 0 [40134800] D/onenet.mqtt mqtt0: Enter mqtt_offline_callback! [40139906] D/mqtt mqtt0: restart! [40139909] D/onenet.mqtt mqtt0: Enter mqtt_connect_callback! [40139915] D/mqtt mqtt0: ipv4 address port: 6002 [40139920] D/mqtt mqtt0: HOST = '183.230.40.39' [40140043] I/mqtt mqtt0: MQTT server connect success. [40140049] D/onenet.mqtt mqtt0: Enter mqtt_online_callback! thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- mqtt0 10 running 0x0000017c 0x00001000 16% 0x00000002 000 DFSP1 15 suspend 0x000000a4 0x00000800 42% 0x00000014 000 DFSP0 15 suspend 0x000000a4 0x00000800 08% 0x00000014 000 Ds18b20 16 suspend 0x000000ec 0x00000280 78% 0x0000000d 000 nRF24L01 16 suspend 0x000000b4 0x00000400 52% 0x00000007 000 onenet 14 suspend 0x00000090 0x00000800 35% 0x00000003 000 LED1 16 suspend 0x0000007c 0x00000100 48% 0x00000004 000 tshell 20 suspend 0x00000138 0x00001000 20% 0x0000000a 000 at_clnt 9 suspend 0x000000b8 0x00000600 29% 0x00000001 000 sys_work 23 suspend 0x0000005c 0x00000800 33% 0x00000003 000 tidle0 31 ready 0x00000044 0x00000100 35% 0x0000000a 000 [40140112] E/cmb mqtt0: [40140112] E/cmb mqtt0: Firmware name: rtthread, hardware version: 1.0, software version: 1.0 [40140112] E/cmb mqtt0: Fault on interrupt or bare metal(no OS) environment [40140112] E/cmb mqtt0: ===== Thread stack information ===== [40140112] E/cmb mqtt0: addr: 20004ae0 data: 08000410 [40140112] E/cmb mqtt0: addr: 20004ae4 data: 21000000 [40140112] E/cmb mqtt0: ==================================== [40140112] E/cmb mqtt0: =================== Registers information ==================== [40140112] E/cmb mqtt0: R0 : 0800043d R1 : fffffffd R2 : 20004ae8 R3 : 10000000 [40140112] E/cmb mqtt0: R12: 00000000 LR : 2000077c PC : 0000000a PSR: 08026e7f [40140112] E/cmb mqtt0: ============================================================== [40140112] E/cmb mqtt0: Bus fault is caused by precise data access violation [40140112] E/cmb mqtt0: The bus fault occurred address is 52370036 [40140112] E/cmb mqtt0: Show more call stack info by run: addr2line -e rtthread.axf -a -f 0000000a```这个是addr2line ```0x0000000a ?? ??:0```还有我的输出文件是rt-thread.axf,但给的信息总是addr2line -e rtthread.axf这样的,我在keil中把输出文件改为rtthread.axf,然后信息就会变成addr2line -e rt-thread.axf这样的,不知道我是哪里做错了?:'(
Tonny
2019-09-17
>编译的文件如果是 rt-thread.axf 重命名成 rtthread.axf 就可以了,你看看 > > addr2line -e rtthread.axf ... --- 我已经这么做了,然鹅,就是上面展示的那些信息:shutup:,开了AT的RAW能运行时间长点,开了AT的log输出,也抓不到错误信息,因为出错的时候直接就出错了,出错前一刻AT的收发还都正常,不知道是不是mqtt的问题,或者onenet的问题,开了CMbacktrace也得不到有效信息,有点懵。
wuhanstudio
2019-09-16
上面 log 报错 AT 串口连接失败了,是不是串口没有配置好
Tonny
2019-09-16
>上面 log 报错 AT 串口连接失败了,是不是串口没有配置好 --- 第4行和第5行吗,如果是的话,我暂时无能为力,查过相关的代码函数,uart device get data error(-2)对应的函数是没有小于0的返回值的,所以-2按函数是不应该出现的返回值。
wuhanstudio
2019-09-16
>第4行和第5行吗,如果是的话,我暂时无能为力,查过相关的代码函数,uart device get data error(-2)对应 ... --- 如果是串口初始化错误,可以先单独调试下串口,确认收发没有问题了再连上模块,一步步调试好定位错误
Tonny
2019-09-17
>如果是串口初始化错误,可以先单独调试下串口,确认收发没有问题了再连上模块,一步步调试好定位错误 ... --- 这个是运行了一段时间后出现的错误,串口的初始化应该是没问题的,这种情况下也需要单独调试串口吗{:2_36:}
wuhanstudio
2019-09-17
>这个是运行了一段时间后出现的错误,串口的初始化应该是没问题的,这种情况下也需要单独调试串口吗{:2_36 ... --- 编译的文件如果是 rt-thread.axf 重命名成 rtthread.axf 就可以了,你看看 addr2line -e rtthread.axf -a -f 0000000a 能不能提供什么信息
2.2k
Tonny
45
131
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
