list_device看不到看门狗
发布于 2019-09-12 13:55:11 浏览:1457
* 本帖最后由 aozima 于 2019-9-20 12:10 编辑 * ```/* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2019-03-08 obito0 first version */ #include
void serial_usart1_inital(void); /* defined the LED0 pin: PC13 */ #define LED0_PIN GET_PIN(A, 8) #define IWDG_DEVICE_NAME "wdt" static rt_device_t wdg_dev;/*看门狗设备句柄*/ //static rt_device_t serial; /* 串 口 设 备 句 柄 */ //char str[] = "hello RT-Thread!
"; static void idle_hook(void) { rt_device_control(wdg_dev,RT_DEVICE_CTRL_WDT_KEEPALIVE,NULL); rt_kprintf("feed the dog
"); } int main(void) { int count = 1; /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); while (count++) { rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); } } static int iwdg_sample(int argc,char *argv[]) { rt_err_t result = RT_EOK; rt_uint32_t timeout = 30; /* 超时时间为1000ms*/ char device_name[RT_NAME_MAX]; /* 判断命令行参数是否给定了设备名称 */ if (argc == 2) { rt_strncpy(device_name, argv[1], RT_NAME_MAX); } else { rt_strncpy(device_name, IWDG_DEVICE_NAME, RT_NAME_MAX); } /* 根据设备名称查找看门狗设备,获取设备句柄 */ result = rt_hw_watchdog_register((rt_watchdog_t *)wdg_dev,device_name, RT_DEVICE_FLAG_RDWR,NULL); wdg_dev = rt_device_find(device_name); if (!wdg_dev) { rt_kprintf("find %s failed!
",device_name); return RT_ERROR; } /* 初始化设备 */ result = rt_device_init(wdg_dev); if (result != RT_EOK) { rt_kprintf("initialize %s failed!
",device_name); return RT_ERROR; } /* 设置看门狗溢出时间 */ result = rt_device_control(wdg_dev, RT_DEVICE_CTRL_WDT_SET_TIMEOUT, (void*)timeout); if (result != RT_EOK) { rt_kprintf("set %s timeout failed!
",device_name); return RT_ERROR; } /* 设置空闲线程回调函数 */ rt_thread_idle_sethook(idle_hook); return result; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(iwdg_sample, iwdg sample); #if 0 void serial_usart1_inital(void) { #define SAMPLE_UART_NAME "uart1" /* 串 口 设 备 名 称 */ struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; /* 配 置 参 数 */ serial = rt_device_find(SAMPLE_UART_NAME);/* 查 找 串 口 设 备 */ rt_device_open(serial, RT_DEVICE_FLAG_INT_RX);/* 以 中 断 接 收 及 轮 询 发 送 模 式 打 开 串 口 设 备 */ config.baud_rate = BAUD_RATE_9600; config.data_bits = DATA_BITS_8; config.stop_bits = STOP_BITS_2; config.parity = PARITY_NONE; rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, &config); } #endif #if 0 static int rt_hw_spi_flash_init(void) { __HAL_RCC_GPIOB_CLK_ENABLE(); rt_hw_spi_device_attach("spi1","spi10", GPIOB, GPIO_PIN_14); return RT_EOK; } /* 导 出 到 自 动 初 始 化 */ INIT_COMPONENT_EXPORT(rt_hw_spi_flash_init); #endif ``` 帮忙看看怎么把看门狗 搞起来
tyustli
2019-09-12
[attach]10939[/attach] 如上图,你的看门狗打开了吗
xiaosa
2019-09-12
开了这个
xiaosa
2019-09-12
只有这个,没有watchdog timer
xiaosa
2019-09-12
[i=s] 本帖最后由 xiaosa 于 2019-9-12 15:32 编辑 [/i] 屏蔽了注册的函数 find这里出错 注册的这个应该也有问题
wuhanstudio
2019-09-12
上面只是定义了使用驱动,还需要需要定义 BSP_USING_WDT,具体需要什么定义可以在 bsp/stm32/libraries/HAL_Drivers/SConscript 看到,例如看门狗的是: ``` if GetDepend(['BSP_USING_WDT']): src += ['drv_wdt.c'] ``` 如果 menuconfig 没有这个选项可以手动修改 board/Kconfig 加上,或者直接在 rtconfig.h 里面添加 #define 也是一样的
xiaosa
2019-09-20
能看到设备,但是运行的时候还是find dwt failed
2019-09-20
dwt != wdt 看下代码是否有误
xiaosa
2019-09-20
你 说对了 我写错了
1.5k
xiaosa
