程序异常退出
发布于 2019-09-23 12:09:25 浏览:1594
* 本帖最后由 aozima 于 2019-9-23 12:24 编辑 * > psr: 0x60000000 r00: 0x00000000 r01: 0x20003354 r02: 0x40003000 r03: 0x00000004 r04: 0xdeadbeef r05: 0xdeadbeef r06: 0x0803e3d5 r07: 0x23232323 r08: 0x08030f69 r09: 0x00000000 r10: 0x00000000 r11: 0x00000000 r12: 0x00000000 lr: 0x0803e483 pc: 0x6c640076 hard fault on thread: tidle0 thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- serial 25 suspend 0x0000007c 0x00000600 32% 0x00000009 000 sensor 15 suspend 0x000000a8 0x00000ffc 07% 0x00000009 000 main_log 15 suspend 0x00000078 0x00000ffc 27% 0x00000003 000 tshell 20 suspend 0x00000104 0x00001000 09% 0x00000002 000 log 15 suspend 0x000000d0 0x00000400 22% 0x0000000a 000 ulog_asy 30 suspend 0x00000080 0x00000400 14% 0x00000013 000 tidle0 31 running 0x00000054 0x00000200 38% 0x00000015 000 usage fault: SCB_CFSR_UFSR:0x02 INVSTATE 这是什么原因导致的? 空闲线程,我只加了一个喂狗 ```#define IWDG_DEVICE_NAME "wdt" /* 看门狗设备名称 */ #define IWDG_FEED_TIME 2343 // 40K/IWDG_PRESCALER_256 15s #define IWDG_ENABLE 1 /** * @brief 声明内部结构体 */ /** * @brief 定义内部局部变量 前缀加static */ static rt_device_t wdg_dev; /* 看门狗设备句柄 */ /** * @brief 代码实现区 */ #if (IWDG_ENABLE==1) static void idle_hook(void) { /* 在空闲线程的回调函数里喂狗 */ rt_device_control(wdg_dev, RT_DEVICE_CTRL_WDT_KEEPALIVE, NULL); } #endif /** *@brief 看门狗初始化 *@Note 看门狗频率为32K,分频为32;频率1K,周期1ms。最大值为0xfff。 */ int hal_watchdog_init(void) { rt_err_t ret = RT_EOK; #if (IWDG_ENABLE==1) rt_uint32_t timeout = IWDG_FEED_TIME; /* 溢出时间 10 秒 */ /* 根据设备名称查找看门狗设备,获取设备句柄 */ wdg_dev = rt_device_find(IWDG_DEVICE_NAME); if (!wdg_dev) { rt_kprintf("find %s failed!
", IWDG_DEVICE_NAME); return -RT_ERROR; } /* 初始化设备 */ ret = rt_device_init(wdg_dev); if (ret != RT_EOK) { rt_kprintf("initialize %s failed!
", IWDG_DEVICE_NAME); return -RT_ERROR; } /* 设置看门狗溢出时间 */ ret = rt_device_control(wdg_dev, RT_DEVICE_CTRL_WDT_SET_TIMEOUT, &timeout); if (ret != RT_EOK) { rt_kprintf("set %s timeout failed!
", IWDG_DEVICE_NAME); return -RT_ERROR; } ret = rt_device_control(wdg_dev, RT_DEVICE_CTRL_WDT_START, RT_NULL); if (ret != RT_EOK) { rt_kprintf("start %s failed!
", IWDG_DEVICE_NAME); return -RT_ERROR; } // /* 设置空闲线程回调函数 */ rt_thread_idle_sethook(idle_hook); #endif return ret; } ```
还没想好
2019-09-23
1. 把空闲线程栈增大一倍试试? 2. 在 main 中调用喂狗函数,看看有没有问题。
cyycyh
2019-09-24
>1. 把空闲线程栈增大一倍试试? >2. 在 main 中调用喂狗函数,看看有没有问题。 ... --- 取消在空闲线程喂狗了;依然出现异常; map文件: rt_pin_irq_enable 0x0803e0f9 Thumb Code 50 pin.o(i.rt_pin_irq_enable) rt_pin_mode 0x0803e14d Thumb Code 38 pin.o(i.rt_pin_mode) [u] rt_pin_read 0x0803e195 Thumb Code 34 pin.o(i.rt_pin_read)[/u] rt_pin_write 0x0803e1d9 Thumb Code 38 pin.o(i.rt_pin_write) rt_pwm_disable 0x0803e221 Thumb Code 42 rt_drv_pwm.o(i.rt_pwm_disable) 出现的PC指针 psr: 0x81000000 r00: 0x35325708 r01: 0x00000040 r02: 0x40011800 r03: 0x00000001 r04: 0x00000040 r05: 0x000012ab r06: 0x200015a4 r07: 0x00000001 r08: 0x00000001 r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0x00000000 lr: 0x08030793 pc: 0x0803e1ae hard fault on thread: sensor thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- serial 25 ready 0x0000011c 0x00000600 53% 0x00000005 000 sensor 15 running 0x000000a4 0x00000ffc 08% 0x00000003 000 main_log 15 suspend 0x00000078 0x00000ffc 26% 0x00000001 000 tshell 20 ready 0x00000104 0x00001000 09% 0x00000009 000 log 15 suspend 0x000000d0 0x00000400 22% 0x0000000a 000 ulog_asy 30 suspend 0x00000080 0x00000400 14% 0x00000014 000 tidle0 31 ready 0x00000044 0x00000200 38% 0x0000000b 000 bus fault: SCB_CFSR_BFSR:0x82 PRECISERR SCB->BFAR:35325710
tyustli
2019-09-24
日志有打印 hardfault 在 sensor 线程,楼主可以检查一下
cyycyh
2019-09-25
>日志有打印 hardfault 在 sensor 线程,楼主可以检查一下 --- 从map查看的话,是指向rt_pin_read(); RTThread的版本是v4.0.1
1.6k
cyycyh
STM32 407 串口接收数据 系统卡死
RTT nrf24l01 设备驱动程序
stm32f10x串口只能发送数据,无法接收
rt-thread线程调度异常在stm32f103芯片上
RTT是否支持STM32F429
rt-thread在stm32f411下的移植问题
