连接阿里云时,tls连接失败
发布于 2019-09-27 18:01:55 浏览:2045
rtthread版本:v4.0.1 at_device版本:v1.6.0 通信模块:sim800c ali-iotkit软件包版本:v2.0.4 跑mqtt-example.c,不使能SSL是能连接上阿里云的,而使能了SSL后,日志如下: msh />ali_mqtt_test start iotkit-embedded sdk version: V2.10 [dbg] iotx_device_info_init(32): device_info already created, return! [dbg] iotx_device_info_set(50): start to set device info! [dbg] iotx_device_info_set(64): device_info set successfully! [dbg] guider_print_dev_guider_info(271): .................................................... [dbg] guider_print_dev_guider_info(272): ProductKey : a1byIDawBzA [dbg] guider_print_dev_guider_info(273): DeviceName : dbw01 [dbg] guider_print_dev_guider_info(274): DeviceID : a1byIDawBzA.dbw01 [dbg] guider_print_dev_guider_info(276): .................................................... [dbg] guider_print_dev_guider_info(277): PartnerID Buf : ,partner_id=example.demo.partner-id [dbg] guider_print_dev_guider_info(278): ModuleID Buf : ,module_id=example.demo.module-id [dbg] guider_print_dev_guider_info(279): Guider URL : [dbg] guider_print_dev_guider_info(281): Guider SecMode : 2 (TLS + Direct) [dbg] guider_print_dev_guider_info(283): Guider Timestamp : 2524608000000 [dbg] guider_print_dev_guider_info(284): .................................................... [dbg] guider_print_dev_guider_info(290): .................................................... [dbg] guider_print_conn_info(248): ----------------------------------------- [dbg] guider_print_conn_info(249): Host : a1byIDawBzA.iot-as-mqtt.cn-shanghai.aliyuncs.com [dbg] guider_print_conn_info(250): Port : 1883 [dbg] guider_print_conn_info(253): ClientID : a1byIDawBzA.dbw01|securemode=2,timestamp=2524608000000,signmethod=hmacsha1,gw=0,ext=0,partner_id=example.demo.partner-id,module_id=example.demo.module-id| [dbg] guider_print_conn_info(255): TLS PubKey : 0x803b411 ('-----BEGIN CERTI ...') [dbg] guider_print_conn_info(258): ----------------------------------------- host: a1byidawbza.iot-as-mqtt.cn-shanghai.aliyuncs.com [inf] iotx_mc_init(1704): MQTT init success! [inf] _ssl_client_init(175): Loading the CA root certificate ... cert. version : 3 serial number : 04:00:00:00:00:01:15:4B:5A:C3:94 issuer name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA subject name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA issued on : 1998-09-01 12:00:00 expires on : 2028-01-28 12:00:00 signed using : RSA with SHA1 RSA key size : 2048 bits basic constraints : CA=true key usage : Key Cert Sign, CRL Sign [inf] _ssl_parse_crt(143): crt content:451 [inf] _ssl_client_init(183): ok (0 skipped) [inf] _TLSConnectNetwork(345): Connecting to /a1byidawbza.iot-as-mqtt.cn-shanghai.aliyuncs.com/1883... msh />[inf] _TLSConnectNetwork(359): ok [inf] _TLSConnectNetwork(364): . Setting up the SSL/TLS structure... [inf] _TLSConnectNetwork(374): ok [inf] _TLSConnectNetwork(409): Performing the SSL/TLS handshake... [inf] _TLSConnectNetwork(413): failed ! mbedtls_ssl_handshake returned -0x2880 [D/at.clnt] execute command (AT+CIPCLOSE=0) timeout (100 ticks)! [inf] _network_ssl_disconnect(520): ssl_disconnect [inf] HAL_SSL_Destroy(536): handle is NULL [err] iotx_mc_connect(2002): TCP or TLS Connection failed [inf] HAL_SSL_Destroy(536): handle is NULL [inf] iotx_mc_disconnect(2130): mqtt disconnect! [inf] iotx_mc_release(2176): mqtt release! mqtt_client|274 :: MQTT construct failed [err] LITE_dump_malloc_free_stats(594): WITH_MEM_STATS = 0 mqtt_client|345 :: out of sample! 这可能是啥原因?
Cheney_Chen
2019-09-29
#define MBEDTLS_ERR_X509_ALLOC_FAILED -0x2880 /**< Allocation of memory failed. */ 看错误提示是内存不足了吧,free 命令检查一下
sync
2019-09-29
楼主我使用的f407+lwip 环境,实测发现tls很占内存 内存不够的情况下,就会发送tls连接失败 一定尽可能的留够内存空间 系统开机后 free total memory: 120596 used memory : 24760 maximum allocated memory: 24760 执行ali_mqtt_test命令后 free total memory: 120596 used memory : 63036 maximum allocated memory: 68816 如果还要跑ota则 执行命令ali_ota_test 后 maximum allocated memory: 112588 内存如果小,根本就跑不起来了
wenbodong
2019-09-29
谢谢楼上两位,确实是内存不够。我用的是stm32f401re,本来配置的是stm32f401rc,内存是64K,引发上述问题。改回stm32f401re,内存96k,可以连接上阿里云了。不过,使用OTA升级又超了,这有点抗不住啊。。。。。。
Tonny
2019-10-10
>谢谢楼上两位,确实是内存不够。我用的是stm32f401re,本来配置的是stm32f401rc,内存是64K,引发上述问题 ... --- 啊?这么耗内存的吗,stm32f103ze岂不是肯定上不了了?除非外加SDRAM{:2_29:}
wenbodong
2019-10-15
>啊?这么耗内存的吗,stm32f103ze岂不是肯定上不了了?除非外加SDRAM --- 稍微砍砍功能,还是能用滴。我现在用的是stm32f401rc,64k ram和256k rom,不用ssl,所以用不了阿里云的OTA。用自己的服务器提供固件下载,使用webclient软件包,通过http下载固件。
2k
wenbodong
44
MCXN947测评系列(二)串口设备测评
