[第3期 空气质量分析仪] 第1周作业
发布于 2019-10-15 20:19:28 浏览:960
* 本帖最后由 core571 于 2019-10-15 20:28 编辑 * **任务 1:** 开发板采用官方推荐的正点原子 IoT_Board pandora 开发板,BSP 在 rt-thread\bsp\stm32\stm32l475-atk-pandora文件中已经提供。 IoT_Board 还提供了官方例程可参考: [IOT_board 官方例程](https://github.com/RT-Thread/IoT_Board) **任务 2:** led_alert.c```#include
#include "led_alert.h" void led_init() { uint16_t i = LED0_PIN; rt_pin_mode(i, PIN_MODE_OUTPUT); rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT); rt_pin_mode(LED2_PIN, PIN_MODE_OUTPUT); } void led_on(uint8_t led) { switch(led){ case 0: rt_pin_write(LED0_PIN, PIN_LOW); break; case 1: rt_pin_write(LED1_PIN, PIN_LOW); break; case 2: rt_pin_write(LED2_PIN, PIN_LOW); break; default: rt_pin_write(LED0_PIN, PIN_LOW); rt_pin_write(LED1_PIN, PIN_LOW); rt_pin_write(LED2_PIN, PIN_LOW); } } void led_off(uint8_t led) { switch(led){ case 0: rt_pin_write(LED0_PIN, PIN_HIGH); break; case 1: rt_pin_write(LED1_PIN, PIN_HIGH); break; case 2: rt_pin_write(LED2_PIN, PIN_HIGH); break; default: rt_pin_write(LED0_PIN, PIN_HIGH); rt_pin_write(LED1_PIN, PIN_HIGH); rt_pin_write(LED2_PIN, PIN_HIGH); } } void led_blink() { led_on(3); rt_thread_mdelay(200); led_off(3); rt_thread_mdelay(200); }``` led_alert.h ```#ifndef __LED_ALERT_H__ #define __LED_ALERT_H__ #define LED0_PIN GET_PIN(E, 7) #define LED1_PIN GET_PIN(E, 8) #define LED2_PIN GET_PIN(E, 9) void led_init(); void led_on(uint8_t led); void led_off(uint8_t led); void led_blink(); #endif``` **任务3:** key.c ```#include
#include "led_alert.h" #include "key.h" void key_cb0(void *args) { if(rt_pin_read(PIN_KEY0)){ led_off(0); } else{ led_on(0); } } void key_cb1(void *args) { if(rt_pin_read(PIN_KEY1)){ led_off(1); } else{ led_on(1); } } void key_cb2(void *args) { if(rt_pin_read(PIN_KEY2)){ led_off(2); } else{ led_on(2); } } void key_init() { rt_pin_mode(PIN_KEY0, PIN_MODE_INPUT); rt_pin_mode(PIN_KEY1, PIN_MODE_INPUT); rt_pin_mode(PIN_KEY2, PIN_MODE_INPUT); rt_pin_attach_irq(PIN_KEY0, PIN_IRQ_MODE_RISING_FALLING, key_cb0, RT_NULL); rt_pin_attach_irq(PIN_KEY1, PIN_IRQ_MODE_RISING_FALLING, key_cb1, RT_NULL); rt_pin_attach_irq(PIN_KEY2, PIN_IRQ_MODE_RISING_FALLING, key_cb2, RT_NULL); rt_pin_irq_enable(PIN_KEY0, PIN_IRQ_ENABLE); rt_pin_irq_enable(PIN_KEY1, PIN_IRQ_ENABLE); rt_pin_irq_enable(PIN_KEY2, PIN_IRQ_ENABLE); } ``` key.h ```#ifndef __KEY_H__ #define __KEY_H__ #define PIN_KEY2 GET_PIN(D, 8) // PD8 : KEY2 --> KEY #define PIN_KEY1 GET_PIN(D, 9) // PD9 : KEY1 --> KEY #define PIN_KEY0 GET_PIN(D, 10) // PD10: KEY0 --> KEY void key_init(); #endif``` **任务4:** temp_humi.c ```#include
#include "temp_humi.h" struct rt_i2c_bus_device *i2c_bus; /* I2C总线设备句柄 */ static rt_bool_t initialized = RT_FALSE; /* 传感器初始化状态 */ /* 写传感器寄存器 */ static rt_err_t write_reg(struct rt_i2c_bus_device *bus, rt_uint8_t reg, rt_uint8_t *data) { rt_uint8_t buf[3]; struct rt_i2c_msg msgs; buf[0] = reg; //cmd buf[1] = data[0]; buf[2] = data[1]; msgs.addr = AHT10_ADDR; msgs.flags = RT_I2C_WR; msgs.buf = buf; msgs.len = 3; /* 调用I2C设备接口传输数据 */ if (rt_i2c_transfer(bus, &msgs, 1) == 1) { return RT_EOK; } else { return -RT_ERROR; } } /* 读传感器寄存器数据 */ static rt_err_t read_regs(struct rt_i2c_bus_device *bus, rt_uint8_t len, rt_uint8_t *buf) { struct rt_i2c_msg msgs; msgs.addr = AHT10_ADDR; /* 从机地址 */ msgs.flags = RT_I2C_RD; /* 读标志 */ msgs.buf = buf; /* 读写数据缓冲区指针 */ msgs.len = len; /* 读写数据字节数 */ /* 调用I2C设备接口传输数据 */ if (rt_i2c_transfer(bus, &msgs, 1) == 1) { return RT_EOK; } else { return -RT_ERROR; } } void aht10_read_temp(float *cur_temp) { rt_uint8_t temp[6]; write_reg(i2c_bus, AHT10_GET_DATA, 0); /* 发送命令 */ rt_thread_mdelay(400); read_regs(i2c_bus, 6, temp); /* 获取传感器数据 */ /* 温度数据转换 */ *cur_temp = ((temp[3] & 0xf) << 16 | temp[4] << 8 | temp[5]) * 200.0 / (1 << 20) - 50; } void aht10_read_humi(float *cur_humi) { rt_uint8_t temp[6]; write_reg(i2c_bus, AHT10_GET_DATA, 0); /* 发送命令 */ rt_thread_mdelay(400); read_regs(i2c_bus, 6, temp); /* 获取传感器数据 */ /* 湿度数据转换 */ *cur_humi = (temp[1] << 12 | temp[2] << 4 | (temp[3] & 0xf0) >> 4) * 100.0 / (1 << 20); } void aht10_hw_init(const char *name) { rt_uint8_t temp[2] = {0, 0}; /* 查找I2C总线设备,获取I2C总线设备句柄 */ i2c_bus = (struct rt_i2c_bus_device *)rt_device_find(name); if (i2c_bus == RT_NULL) { rt_kprintf("can't find %s device!
", name); } else { write_reg(i2c_bus, AHT10_NORMAL_CMD, temp); rt_thread_mdelay(400); temp[0] = 0x08; temp[1] = 0x00; write_reg(i2c_bus, AHT10_CALIBRATION_CMD, temp); rt_thread_mdelay(400); initialized = RT_TRUE; } }``` temp_humi.h ```#ifndef __TEMP_HUMI_H__ #define __TEMP_HUMI_H__ #define AHT10_ADDR 0x38 /* 从机地址 */ #define AHT10_CALIBRATION_CMD 0xE1 /* 校准命令 */ #define AHT10_NORMAL_CMD 0xA8 /* 一般命令 */ #define AHT10_GET_DATA 0xAC /* 获取数据命令 */ void aht10_hw_init(const char *name); void aht10_read_humi(float *cur_humi); void aht10_read_temp(float *cur_temp); #endif``` main.c ```/* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-11-06 SummerGift first version */ #include
#include "led_alert.h" #include "key.h" #include "rtconfig.h" #define AHT10_I2C_BUS_NAME "i2c4" /* 传感器连接的I2C总线设备名称 */ int main(void) { float humidity, temperature; const char *i2c_bus_name = AHT10_I2C_BUS_NAME; aht10_hw_init(i2c_bus_name); led_init(); led_off(3); key_init(); while(1){ aht10_read_humi(&humidity); aht10_read_temp(&temperature); rt_kprintf("read aht10 sensor humidity : %d.%d %%
", (int)humidity, (int)(humidity * 10) % 10); if( temperature >= 0 ) { rt_kprintf("read aht10 sensor temperature: %d.%d°C
", (int)temperature, (int)(temperature * 10) % 10); } else { rt_kprintf("read aht10 sensor temperature: %d.%d°C
", (int)temperature, (int)(-temperature * 10) % 10); } rt_thread_mdelay(1000); } return RT_EOK; } ```
core571
2019-10-15
**知识点总结及疑问:** **1. ENV 工具 **[https://www.rt-thread.org/document/site/programming-manual/env/env/](参考文档) 用途 1:产生 iar/keil 项目工程,可自动产生项目需要包含的宏定义及头文件路径。 用途 2:软件包管理 用途 3:产生文件 rtconfig.h。 命令 scons --target=iar 用途1 命令 menuconfig & pkgs --update 用途 2 及用途 3 menuconfig 依据 Kconfig 来产生 GUI 界面,在 GUI 界面勾选后,产生 rtconfig.h 。BSP 中的 Kconfig 似乎会去包含上层目录的 Kconfig? Kconfig 文档说明较为模糊,希望开发组能提供详细的配置 Kconfig 教程,及 Kconfig 在软件包中的架构说明。 pkgs --update 依据 GUI 中勾选的软件包来 clone 相关文件到项目中。 scons --target=iar 依据文件中的 SConscript 及 SConstruct 这些 python 代码段来产生 iar 及 keil 工程,[https://www.rt-thread.org/document/site/programming-manual/scons/scons/](参考资料)。SConscript 用于具体产生工程的 group 及 头文件包含路径。工程中的宏定义在哪里产生好像没有看到? **2. PIN 设备** [https://www.rt-thread.org/document/site/programming-manual/device/pin/pin/](参考文档) rt_pin_mode() 设置引脚模式 rt_pin_write() 设置引脚电平 rt_pin_read() 读取引脚电平 rt_pin_attach_irq() 绑定引脚中断回调函数 rt_pin_irq_enable() 使能引脚中断 rt_pin_detach_irq() 脱离引脚中断回调函数 底层代码很值得学习研究,研究后再来提问。 **3. I2C 总线设备 **[https://www.rt-thread.org/document/site/programming-manual/device/i2c/i2c/](参考文档) 项目i2c API 为 GPIO 模拟,这个有些意外,也是看了原理图才发现的,也就是说只能做主机,并且只能查询方式工作了,不能中断或者dma方式传输数据。但是底层代码依然很值得学习。 rt_device_find() 根据 I2C 总线设备名称查找设备获取设备句柄 rt_i2c_transfer() 传输数据 跟了下代码,大致初始化为 rt_hw_i2c_init() 剩下的明天写 有个问题,如下图drv_soft_i2c.h 中 rt_device_find() 的形参 I2C 设备名称 已经定死了为 i2c1 i2c2 i2c3 i2c4 ? [attach]11371[/attach]
core571
2019-10-16
初始化过程有专门文档,参考 [https://blog.csdn.net/yang1111111112/article/details/93982354](参考文档) PIN 的初始化为 rt_hw_pin_init() i2c 的初始化为 rt_hw_i2c_init(void) 都在rt_hw_board_init()中被调用。
960
core571
