Network
使用阿里云例程连接不上阿里云的问题
发布于 2019-10-17 17:13:19 浏览:1479
1使用ESP8266模块采用ENV工具里的例程连接阿里云时遇到以下问题,请求支援!!!! ![0001.png](/uploads/201910/17/171202eyu325b8zmeyrsij.png) ![err2.png](/uploads/201910/17/171236lve9xo5ww595nl9v.png) 2.之前使用虚拟工具是可以正常连接的,一脸懵
coulson
2019-10-17
[i=s] 本帖最后由 coulson 于 2019-10-17 17:15 编辑 [/i] 以下是终端打印的信息 [D/at.dev.esp] AT version:1.7.1.0(Jul 15 2019 16:58:04) [D/at.dev.esp] SDK version:3.0.1(78a3e33) [D/at.dev.esp] compile time:Sep 10 2019 14:35:30 [I/at.dev.esp] esp0 device wifi is connected. [I/at.dev.esp] esp0 device network initialize successfully. [D/at.dev.esp] network interface device(esp0) set up status msh />ali_mqtt_test start [inf] iotx_device_info_init(40): device_info created successfully! [dbg] iotx_device_info_set(50): start to set device info! [dbg] iotx_device_info_set(64): device_info set successfully! [dbg] guider_print_dev_guider_info(271): .................................................... [dbg] guider_print_dev_guider_info(272): ProductKey : a1yrnP9QqNZ [dbg] guider_print_dev_guider_info(273): DeviceName : AZZEKmfQrQ171zJPeE8o [dbg] guider_print_dev_guider_info(274): DeviceID : a1yrnP9QqNZ.AZZEKmfQrQ171zJPeE8o [dbg] guider_print_dev_guider_info(276): .................................................... [dbg] guider_print_dev_guider_info(277): PartnerID Buf : ,partner_id=example.demo.partner-id [dbg] guider_print_dev_guider_info(278): ModuleID Buf : ,module_id=example.demo.module-id [dbg] guider_print_dev_guider_info(279): Guider URL : [dbg] guider_print_dev_guider_info(281): Guider SecMode : 2 (TLS + Direct) [dbg] guider_print_dev_guider_info(283): Guider Timestamp : 2524608000000 [dbg] guider_print_dev_guider_info(284): .................................................... [dbg] guider_print_dev_guider_info(290): .................................................... [dbg] guider_print_conn_info(248): ----------------------------------------- [dbg] guider_print_conn_info(249): Host : a1yrnP9QqNZ.iot-as-mqtt.cn-shanghai.aliyuncs.com [dbg] guider_print_conn_info(250): Port : 1883 [dbg] guider_print_conn_info(253): ClientID : a1yrnP9QqNZ.AZZEKmfQrQ171zJPeE8o|securemode=2,timestamp=2524608000000,signmethod=hmacsha1,gw=0,ext=0,partner_id=example.id,module_id=example.demo.module-id| [dbg] guider_print_conn_info(255): TLS PubKey : 0805ef18 ('-----BEGIN CERTI ...') [dbg] guider_print_conn_info(258): ----------------------------------------- host: a1yrnp9qqnz.iot-as-mqtt.cn-shanghai.aliyuncs.com [inf] iotx_mc_init(1704): MQTT init success! [inf] _ssl_client_init(175): Loading the CA root certificate ... cert. version : 3 serial number : 04:00:00:00:00:01:15:4B:5A:C3:94 issuer name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA subject name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA issued on : 1998-09-01 12:00:00 expires on : 2028-01-28 12:00:00 signed using : RSA with SHA1 RSA key size : 2048 bits basic constraints : CA=true key usage : Key Cert Sign, CRL Sign [inf] _ssl_parse_crt(143): crt content:451 [inf] _ssl_client_init(183): ok (0 skipped) [inf] _TLSConnectNetwork(345): Connecting to /a1yrnp9qqnz.iot-as-mqtt.cn-shanghai.aliyuncs.com/1883... msh />[inf] _TLSConnectNetwork(359): ok [inf] _TLSConnectNetwork(364): . Setting up the SSL/TLS structure... [inf] _TLSConnectNetwork(374): ok [inf] _TLSConnectNetwork(409): Performing the SSL/TLS handshake... [inf] _TLSConnectNetwork(413): failed ! mbedtls_ssl_handshake returned -0x4290 [inf] _network_ssl_disconnect(520): ssl_disconnect [inf] HAL_SSL_Destroy(536): handle is NULL [err] iotx_mc_connect(2002): TCP or TLS Connection failed [inf] HAL_SSL_Destroy(536): handle is NULL [inf] iotx_mc_disconnect(2130): mqtt disconnect! [inf] iotx_mc_release(2176): mqtt release! mqtt_client|274 :: MQTT construct failed [err] LITE_dump_malloc_free_stats(594): WITH_MEM_STATS = 0 mqtt_client|345 :: out of sample!
Cheney_Chen
2019-10-18
查看一下是不是内存不足了,或者是不是 mbedtls 设置的帧大小过小
coulson
2019-10-18
>查看一下是不是内存不足了,或者是不是 mbedtls 设置的帧大小过小 --- mbedtls 帧大小设置成8192了,不是这个问题,我把RTT的版本换成4.0.1然后把mbedtls 的版本设置成1.6.0可以正常连接到阿里云上
1.5k
coulson
36
106
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
