空气质量分析仪]第1周作业
发布于 2019-10-18 00:55:06 浏览:824
* 本帖最后由 韧明 于 2019-10-18 01:02 编辑 * 一,制作BSP 采用STM32F407 Discovery Board, 自带BSP,无需制作。 ![bsp.png](/uploads/201910/18/004356r43xzkk4b9891m04.png) 二,LED配置: 查询了原理图上的LED管脚,根据RTT的API配置了LED,代码如下: led_alert.c: ```#include "led_alert.h" void led_init(void){ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); rt_pin_write(LED0_PIN, PIN_LOW); // LED off by default rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT); rt_pin_write(LED1_PIN, PIN_LOW); // LED off by default } void led_on(rt_int32_t pin){ rt_pin_write(pin, PIN_HIGH); } void led_off(rt_int32_t pin){ rt_pin_write(pin, PIN_LOW); } void led_blink(rt_int32_t pin){ led_on(pin); rt_thread_mdelay(200); led_off(pin); rt_thread_mdelay(200); }``` led_alert.h: ```#ifndef LED_ALERT_H #define LED_ALERT_H #include "rtthread.h" #include "drv_gpio.h" #define LED1_PIN GET_PIN(D, 12) // Green LED /* defined the LED0 pin: PD14 */ #define LED0_PIN GET_PIN(D, 14) void led_init(void); void led_on(rt_int32_t pin); void led_off(rt_int32_t pin); void led_blink(rt_int32_t pin); #endif ```三,按键 根据BSP自带的drv_gpio.c和头文件简单写了下: ```#ifndef KEY_H #define KEY_H #include "rtthread.h" #include "drv_gpio.h" #include "led_alert.h" void key_init(void); void key_cb(void * args); #endif``` ```#include "key.h" #define KEY0_PIN GET_PIN(A, 0) void key_cb(void * args){ if( rt_pin_read(KEY0_PIN) == PIN_LOW ){ led_on(LED1_PIN); }else{ led_off(LED1_PIN); } } void key_init(void){ rt_pin_mode(KEY0_PIN, PIN_MODE_INPUT_PULLUP); rt_pin_attach_irq(KEY0_PIN, PIN_IRQ_MODE_RISING_FALLING, key_cb, RT_NULL); rt_pin_irq_enable(KEY0_PIN, PIN_IRQ_ENABLE); }```四,温湿度传感器SHT31 这个我买错了,不过也就将错就错了。用env工具配置了SHT2x的驱动,I2C地址改为0x44,然后改了I2C的通信字节和计算公式,然后就可以了。当然,现在做得比较简单,也没有加CRC校验,如果要做成正式可用的驱动,还得多改改。温度应该没问题,相对湿度一直是100%,难道是上海这边比较潮湿? 修改sht20.c代码如下: ```static float read_hw_humidity(sht20_device_t dev) { rt_uint8_t temp[6] = {0x24, 0x0B} ; float current_humi = 0.0; //The data is error with missing measurement. rt_err_t result; RT_ASSERT(dev); result = rt_mutex_take(dev->lock, RT_WAITING_FOREVER); if (result == RT_EOK) { rt_i2c_master_send(dev->i2c, SHT20_ADDR, RT_I2C_WR, temp, 2); rt_i2c_master_recv(dev->i2c, SHT20_ADDR, RT_I2C_RD, temp, 6); rt_kprintf("%x, %x, %x, %x, %x, %x
", temp[0], temp[1], temp[2], temp[3], temp[4], temp[5]); current_humi = (temp[4] | temp[3] << 8) * 0.0015259022 ; ; //sensor humidity convert to reality } else { LOG_E("The sht20 could not respond relative humidity measurement at this time. Please try again"); } rt_mutex_release(dev->lock); return current_humi; } static float read_hw_temperature(sht20_device_t dev) { rt_uint8_t temp[6] = {0x24, 0x0B} ; float current_temp = -46.85; //The data is error with missing measurement. rt_err_t result; RT_ASSERT(dev); result = rt_mutex_take(dev->lock, RT_WAITING_FOREVER); if (result == RT_EOK) { rt_i2c_master_send(dev->i2c, SHT20_ADDR, RT_I2C_WR, temp, 2); rt_i2c_master_recv(dev->i2c, SHT20_ADDR, RT_I2C_RD, temp, 6); rt_kprintf("%x, %x, %x, %x, %x, %x
", temp[0], temp[1], temp[2], temp[3], temp[4], temp[5]); current_temp = -45.0 + (temp[1] | temp[0] << 8) * 175.0 / (0xFFFF - 1) ; //sensor temperature convert to reality } else { LOG_E("The sht20 could not respond temperature measurement at this time. Please try again"); } rt_mutex_release(dev->lock); return current_temp; }```![sht31.png](/uploads/201910/18/005346kkfuncwnfzk9snne.png) 好,作业已完成,睡觉!
824
韧明
NXP MCXN947测评之 adc
