Network
tcpclient使用finsh的方式可以成功,放到开机创建里就无法成功
发布于 2019-10-21 17:01:50 浏览:1548
tcpclient使用finsh的方式可以成功,放到开机创建里就无法成功。使用的是静态ip 以下是程序: int main(void) { int count = 1; StartTcpClient(); /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); while (count++) { rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); } return RT_EOK; } //TEST create a rt thread #define THREAD_PRIORITY 25 #define THREAD_STACK_SIZE 512 #define THREAD_TIMESLICE 5 static rt_thread_t tid1 = RT_NULL; /* 线程 1 的入口函数 */ static void thread1_entry(void *parameter) { rt_uint32_t count = 0; while (1) { /* 线程 1 采用低优先级运行,一直打印计数值 */ rt_kprintf("thread1 count: %d
", count ++); rt_thread_mdelay(500); } } #define BUFSZ 1024 static rt_thread_t tid_TcpClient = RT_NULL; /* 线程 tcpclient 的入口函数 */ void thread_tcpclient_entry(void *parameter) { int ret; char *recv_data; struct hostent *host; int sock, bytes_received; struct sockaddr_in server_addr; const char *url="192.168.0.166"; int port=8087; /* 通过函数入口参数url获得host地址(如果是域名,会做域名解析) */ host = gethostbyname(url); /* 分配用于存放接收数据的缓冲 */ recv_data = rt_malloc(BUFSZ); if (recv_data == RT_NULL) { rt_kprintf("No memory
"); return; } /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *)host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */ if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1) { /* 创建socket失败 */ rt_kprintf("Socket error
"); /* 释放接收缓冲 */ rt_free(recv_data); return; } /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *)host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* 连接到服务端 */ if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) { /* 连接失败 */ rt_kprintf("Connect fail!
"); closesocket(sock); /*释放接收缓冲 */ rt_free(recv_data); return; } else { /* 连接成功 */ rt_kprintf("Connect successful
"); } // int res=-1; // rt_uint32_t count = 0; // do // { // res= socket(AF_INET, SOCK_STREAM, 0); // if(res==-1) // { // rt_kprintf("Socket error
"); // } // // res=connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)); // if(res==-1) // { // closesocket(sock); // rt_kprintf("thread count: %d
", count ++); // } // // rt_thread_mdelay(500); // // // }while(res==-1); while (1) { /* 从sock连接中接收最大BUFSZ - 1字节数据 */ bytes_received = recv(sock, recv_data, BUFSZ - 1, 0); if (bytes_received < 0) { /* 接收失败,关闭这个连接 */ closesocket(sock); rt_kprintf("
"); /* 释放接收缓冲 */ rt_free(recv_data); break; } else if (bytes_received == 0) { /* 默认 recv 为阻塞模式,此时收到0认为连接出错,关闭这个连接 */ closesocket(sock); rt_kprintf("
"); /* 释放接收缓冲 */ rt_free(recv_data); break; } /* 有接收到数据,把末端清零 */ recv_data[bytes_received] = '\0'; /* 在控制终端显示收到的数据 */ rt_kprintf("
Received data = %s ", recv_data); /* 发送数据到sock连接 */ ret = send(sock, send_data, strlen(send_data), 0); if (ret < 0) { /* 接收失败,关闭这个连接 */ closesocket(sock); rt_kprintf("
send error,close the socket.
"); rt_free(recv_data); break; } else if (ret == 0) { /* 打印send函数返回值为0的警告信息 */ rt_kprintf("
"); } } } static void StartTcpClient(void) { /* 创建线程 1,名称是 thread1,入口是 thread1_entry*/ tid1 = rt_thread_create("thread1", thread_tcpclient_entry, RT_NULL, THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); /* 如果获得线程控制块,启动这个线程 */ if (tid1 != RT_NULL) rt_thread_startup(tid1); } MSH_CMD_EXPORT(thread_tcpclient_entry, a tcp client sample test); 有没有人遇到这种情况呢。以下是控制台输出 Connect fail! msh /> msh /> msh />ping 192.168.0.166 60 bytes from 192.168.0.166 icmp_seq=0 ttl=64 time=2 ms 60 bytes from 192.168.0.166 icmp_seq=1 ttl=64 time=1 ms 60 bytes from 192.168.0.166 icmp_seq=2 ttl=64 time=1 ms 60 bytes from 192.168.0.166 icmp_seq=3 ttl=64 time=1 ms msh />th thread_tcpclient_entry msh />thread_tcpclient_entry Connect successful 是不是创建任务之前要等待什么网络状态之类的呢?
storm
2019-10-21
debug一天终于找到问题了,有个叫phy_monitor_thread_entry的线程,他不起来,就无法创建tcpclient成功,他起来之后就可以了,可以通过以下代码确定网络连接状态: struct netdev *myNetdev; myNetdev =(netdev_get_by_family(AF_INET)); int resNetDev=(netdev_is_link_up(myNetdev)); resNetDev为1时候网络就起来了,就可以创建tcpclient了 最后 希望官方的大神们,创建例程时候,多考虑以下,不要通过finsh可以跑了,就认为ok了。别挖坑,让后面的萌新怎么入门呢,注社区原来越好
hualongguang
2020-06-29
>debug一天终于找到问题了,有个叫phy_monitor_thread_entry的线程,他不起来,就无法创建tcpclient成功,他 ... --- 您好,我也遇到这个问题了,而且我用了你的方法resNetDev的值一直为0,你说的这个phy_monitor_thread_entry没运行起来是个什么意思,这个不是在初始化的时候运行的吗,能具体说说您的解决方法吗,万分感谢!
1.5k
storm
23
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
