[第3期 空气质量分析仪]第2周作业
发布于 2019-10-23 14:40:28 浏览:741
**任务1:** temp_humi_th.c ```#include
#include "temp_humi.h" #include "temp_humi_th.h" static rt_thread_t temp_humi_tid = RT_NULL; static void temp_humi_entry(void *parameter) { float humidity, temperature; while(1){ aht10_read_humi(&humidity); aht10_read_temp(&temperature); rt_kprintf("read aht10 sensor humidity : %d.%d %%
", (int)humidity, (int)(humidity * 10) % 10); if( temperature >= 0 ) { rt_kprintf("read aht10 sensor temperature: %d.%d°C
", (int)temperature, (int)(temperature * 10) % 10); } else { rt_kprintf("read aht10 sensor temperature: %d.%d°C
", (int)temperature, (int)(-temperature * 10) % 10); } rt_thread_mdelay(1000); } } static void hook_of_scheduler(struct rt_thread* from, struct rt_thread* to) { rt_kprintf("from: %s --> to: %s
", from->name , to->name); } void temp_humi_init(void) { const char *i2c_bus_name = "i2c4"; aht10_hw_init(i2c_bus_name); // rt_scheduler_sethook(hook_of_scheduler); temp_humi_tid = rt_thread_create("temp_humi_tid", temp_humi_entry, RT_NULL, 1024, RT_MAIN_THREAD_PRIORITY - 1, 10 ); if(temp_humi_tid != RT_NULL) rt_thread_startup(temp_humi_tid); }``` **任务2:** GP2Y原理图: ILED 接 MCU PB8(GPIO),K_LED 接 MCU PC2(ADC1_CH3)。 GP2Y 模块上的 滑动电阻器用于调节放大电路的灵敏度,ADC 采不到数据可以调节滑动电阻试试。 pm25.c ```#include
#include "pm25.h" #define ADC_DEV_NAME "adc1" /* ADC 设备名称 */ #define ADC_DEV_CHANNEL 3 /* ADC 通道 */ #define REFER_VOLTAGE 330 /* 参考电压 3.3V,数据精度乘以100保留2位小数*/ #define CONVERT_BITS (1 << 12) /* 转换位数为12位 */ #define RATIO 0.2 #define NO_DUST_VOLTAGE 400 #define ILED_PIN GET_PIN(B, 8) rt_adc_device_t adc_dev; /* ADC 设备句柄 */ void gp2y_hw_init() { rt_pin_mode(ILED_PIN, PIN_MODE_OUTPUT); rt_pin_write(ILED_PIN, PIN_LOW); /* 查找设备 */ adc_dev = (rt_adc_device_t)rt_device_find(ADC_DEV_NAME); if (adc_dev == RT_NULL) { rt_kprintf("adc sample run failed! can't find %s device!
", ADC_DEV_NAME); } /* 使能设备 */ rt_adc_enable(adc_dev, ADC_DEV_CHANNEL); } float gp2y_read_pm25() { rt_uint32_t value, vol; float voltage,dens; rt_pin_write(ILED_PIN, PIN_HIGH); rt_hw_us_delay(500); /* 读取采样值 */ value = rt_adc_read(adc_dev, ADC_DEV_CHANNEL); rt_pin_write(ILED_PIN, PIN_LOW); // rt_thread_mdelay(5); /* 转换为对应电压值 */ voltage = value * (3300 / 4096.0) * 11; vol = value * REFER_VOLTAGE / CONVERT_BITS * 11; rt_kprintf("the voltage is :%d.%02d
", vol / 100, vol % 100); if(voltage >= NO_DUST_VOLTAGE){ dens = (voltage - NO_DUST_VOLTAGE) * RATIO; return dens; } else{ return 0; } } ``` pm25_th.c ```#include
#include "pm25.h" #include "pm25_th.h" static rt_thread_t pm25_tid = RT_NULL; void pm25_entry(void *parameter) { float dens = 0; while(1){ dens = gp2y_read_pm25(); rt_kprintf("dens: %d.%d ug/m3
", (int)dens, (int)(dens * 10) % 10); rt_thread_mdelay(1000); } } void pm25_init() { gp2y_hw_init(); pm25_tid = rt_thread_create("pm25_tid", pm25_entry, RT_NULL, 1024, RT_MAIN_THREAD_PRIORITY - 1, 20 ); if(pm25_tid != RT_NULL) rt_thread_startup(pm25_tid); }``` 本周主要学习线程的创建,具体原理应该是 arm 的 PendSV 软中断吧,还不是很懂,准备把 Cortex 权威指南读一读,读完再来写。 ** **rt_thread_create() 用于创建线程,线程的优先级和轮转时间应该是比较重要的参数,关系到线程的运行。 ![Annotation 2019-10-23 142808.png](https://oss-club.rt-thread.org/uploads/201910/23/142818d0264bgji9jj9ss4.png)
741
core571
MCXN947测评系列(二)串口设备测评
