[第3期 空气质量分析仪]第二周作业。提交学习营每周的作业~
发布于 2019-10-24 23:54:18 浏览:856
0、写在前面的话: 最近公司项目真是太忙了,每周真是抽时间外的时间,在搞这个项目,可能有很多地方并不是按照RT-Thread的思维在做开发,但是,也算初步完成了吧,做完后再细细雕琢吧,附上一张工程截图。 ![1.png](/uploads/201910/24/234038t8jj8asdic9jmcyj.png) 1、任务一 温湿度 这个任务是上星期的,借用了RT-Thread的软件包。 temp_humi_th.c ```/* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2019-08-01 LuoGong the first version. * 2019-08-15 MurphyZhao add lock and modify code style */ #include
#include "sensor.h" #include "sensor_dallas_dht11.h" #include "drv_gpio.h" /* Modify this pin according to the actual wiring situation */ #define DHT11_DATA_PIN GET_PIN(A, 8) void read_temp_entry(void *parameter) { rt_device_t dev = RT_NULL; struct rt_sensor_data sensor_data; rt_size_t res; rt_uint8_t get_data_freq = 1; /* 1Hz */ dev = rt_device_find("temp_dht11"); if (dev == RT_NULL) { return; } if (rt_device_open(dev, RT_DEVICE_FLAG_RDWR) != RT_EOK) { rt_kprintf("open device failed!
"); return; } rt_device_control(dev, RT_SENSOR_CTRL_SET_ODR, (void *)(&get_data_freq)); while (1) { res = rt_device_read(dev, 0, &sensor_data, 1); if (res != 1) { rt_kprintf("read data failed! result is %d
", res); rt_device_close(dev); return; } else { if (sensor_data.data.temp >= 0) { uint8_t temp = (sensor_data.data.temp & 0xffff) >> 0; // get temp uint8_t humi = (sensor_data.data.temp & 0xffff0000) >> 16; // get humi rt_kprintf("temp:%d, humi:%d
" ,temp, humi); } } rt_thread_delay(1000); } } int dht11_read_temp_sample(void) { rt_thread_t dht11_thread; dht11_thread = rt_thread_create("dht_tem", read_temp_entry, RT_NULL, 1024, RT_THREAD_PRIORITY_MAX / 2, 20); if (dht11_thread != RT_NULL) { rt_thread_startup(dht11_thread); } return RT_EOK; } INIT_APP_EXPORT(dht11_read_temp_sample); int rt_hw_dht11_port(void) { struct rt_sensor_config cfg; cfg.intf.user_data = (void *)DHT11_DATA_PIN; rt_hw_dht11_init("dht11", &cfg); return RT_EOK; } INIT_COMPONENT_EXPORT(rt_hw_dht11_port); ``` 2、任务二 PM2.5检测 这个模块因为硬件电路的问题,完成的比较曲折,程序中基本包含:PWM输出、ADC检测、以及线程的注册,和线程接口的写入。代码如下 pm25_th.c ```/* 包含头文件 ----------------------------------------------------------------*/ #include "pm25_th.h" #include
#include "stm32f1xx_hal.h" /* 私有类型定义 --------------------------------------------------------------*/ /* 私有宏定义 ----------------------------------------------------------------*/ /* 私有变量 ------------------------------------------------------------------*/ /* 扩展变量 ------------------------------------------------------------------*/ /* 私有函数原型 --------------------------------------------------------------*/ /* 函数体 --------------------------------------------------------------------*/ ADC_HandleTypeDef hadc1; TIM_HandleTypeDef htim3; #define ADC_DEV_NAME "adc1" /* ADC 设备名称 */ #define ADC_DEV_CHANNEL 14 /* ADC 通道 */ rt_adc_device_t adc_dev; /* ADC 设备句柄 */ /** * 函数功能: ADC初始化函数 * 输入参数: 无 * 返 回 值: 无 * 说 明:无 */ static void ADC_Init(void) { ADC_ChannelConfTypeDef sConfig = {0}; /** Common config */ hadc1.Instance = ADC1; hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE; hadc1.Init.ContinuousConvMode = DISABLE; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.NbrOfConversion = 1; if (HAL_ADC_Init(&hadc1) != HAL_OK) { Error_Handler(); } /** Configure Regular Channel */ sConfig.Channel = ADC_CHANNEL_14; sConfig.Rank = ADC_REGULAR_RANK_1; sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5; if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK) { Error_Handler(); } } /** * 函数功能: PWM 定时器3初始化函数 * 输入参数: 无 * 返 回 值: 无 * 说 明:无 */ static void MX_TIM3_Init(void) { /* 定时器初句柄声明 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; TIM_OC_InitTypeDef sConfigOC = {0}; /* 配置相关寄存器 */ htim3.Instance = TIM3; htim3.Init.Prescaler = 72-1; htim3.Init.CounterMode = TIM_COUNTERMODE_UP; htim3.Init.Period = 1000-1; htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim3.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim3) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } if (HAL_TIM_PWM_Init(&htim3) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigOC.OCMode = TIM_OCMODE_PWM1; sConfigOC.Pulse = 0; sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH; sConfigOC.OCFastMode = TIM_OCFAST_DISABLE; if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(); } HAL_TIM_MspPostInit(&htim3); } /** * 函数功能: ADC读取函数 * 输入参数: 无 * 返 回 值: 无 * 说 明:无 */ static uint16_t ADC_Read(void) { uint16_t value; HAL_ADC_Start(&hadc1); HAL_ADC_PollForConversion(&hadc1, 10); /* 等待转换完成,第二个参数表示超时时间,单位ms */ if(HAL_IS_BIT_SET(HAL_ADC_GetState(&hadc1), HAL_ADC_STATE_REG_EOC)) { value=HAL_ADC_GetValue(&hadc1); } return value; } /** * 函数功能: ADC读取函数 * 输入参数: 无 * 返 回 值: 无 * 说 明:无 */ void read_pm25_entry(void *parameter) { uint16_t Val; float pm2_5; uint16_t pm2_5_h,pm2_5_l; while(1) { /* 读取ADC值 */ Val = ADC_Read(); /* 换算PM2.5数值 */ pm2_5 = ((((float)Val * 3.3f /4096)*0.17)-0.1f)*1000; pm2_5_h=(uint16_t)pm2_5; /* 输出PM2.5值 */ rt_kprintf("pm25 : %d
" ,pm2_5_h); rt_thread_delay(1000); } } int pm25_init(void) { rt_thread_t pm25_thread; /* 初始化ADC外设 */ ADC_Init(); /* 初始化PWM输出外设 */ MX_TIM3_Init(); /* 启动TIM3定时器输出 */ HAL_TIM_PWM_Start(&htim3,TIM_CHANNEL_1); /* 装载脉冲宽度值 */ TIM1->CCR1 = 320; /* 创建PM2.5读取线程 */ pm25_thread = rt_thread_create("gp2y_pm25", read_pm25_entry, RT_NULL, 1024, RT_THREAD_PRIORITY_MAX / 2, 20); if (pm25_thread != RT_NULL) { rt_thread_startup(pm25_thread); } return RT_EOK; } /***************************** END OF FILE *********************************/ ```pm25_th.h ```#ifndef __BSP_PM25_TH_H__ #define __BSP_PM25_TH_H__ /* 包含头文件 ----------------------------------------------------------------*/ #include "main.h" /* 类型定义 ------------------------------------------------------------------*/ /* 宏定义 --------------------------------------------------------------------*/ /* 扩展变量 ------------------------------------------------------------------*/ /* 函数声明 ------------------------------------------------------------------*/ int pm25_init(void); #endif /* __BSP_PM25_TH_H__ */ ```3、运行截图 ![3.png](/uploads/201910/24/235403uxwo8yxowmyk1bz6.png)
856
AaronZhang
