[第3期 空气质量分析仪]第3周作业
发布于 2019-11-01 18:17:21 浏览:711
* 本帖最后由 Carry 于 2019-11-1 18:21 编辑 * 1,建立mylog ```struct msg /* 创建消息类型结构体 */ { char *tag; rt_uint32_t dat; }; struct rt_mailbox mb; /* 用于放邮件的内存池 */ char mb_pool[128]; static void mylog_entry(void *parameter) { struct msg *msg_ptr; while(1) { if (rt_mb_recv(&mb, (rt_ubase_t *)&msg_ptr, RT_WAITING_FOREVER) == RT_EOK) { rt_kprintf("[%s] data is:%d
",msg_ptr -> tag, msg_ptr -> dat); /* 发送日志数据 */ } rt_thread_delay(100); } }```2,系统跑起来,利用事件来改变LED的不同状态(我的板子上只有一个按键和LED),所以只有温度事件,来改变LED状态 ```int led_alert_init(void) { rt_err_t ret; static rt_thread_t led_event_tid = RT_NULL; rt_pin_mode(LED_ALERT_PIN, PIN_MODE_OUTPUT); led_alert_off(); ret = rt_event_init(&led_event, "LED_ALARM", RT_IPC_FLAG_FIFO); if (ret != RT_EOK) { rt_kprintf("event init failed.
"); return -1; } led_event_tid = rt_thread_create("Led_Event", led_entry, RT_NULL, 512, 10, 20); if (led_event_tid != RT_NULL) { rt_thread_startup(led_event_tid); } return RT_EOK; } void led_entry(void *parameter) { rt_err_t ret; rt_uint32_t event_now; while (1) { ret = rt_event_recv(&led_event, (EVENT_LED_ON | EVENT_LED_OFF | EVENT_LED_BLINK), /* 接收事件 */ RT_EVENT_FLAG_OR | RT_EVENT_FLAG_CLEAR, /* 接收选项 */ RT_WAITING_FOREVER, /* 超时时间 */ &event_now); if (ret == RT_EOK) { if (event_now & EVENT_LED_ON) { led_alert_on(); } if (event_now & EVENT_LED_OFF) { led_alert_off(); } if (event_now & EVENT_LED_BLINK) { set_alert_hz_blink(); set_alert_hz_blink(); } } } }```2.1,温湿度线程的事件判断,对应LED的不同事件状态,key_status%2 != 0判断按键奇数 ``` rt_device_control(dev, RT_SENSOR_CTRL_SET_ODR, (void *)(&get_data_freq)); while (1) { if (key_status%2 != 0) { res = rt_device_read(dev, 0, &sensor_data, 1); if (res != 1) { rt_kprintf("read data failed! result is %d
", res); rt_device_close(dev); return; } else { if (sensor_data.data.temp >= 0) { uint8_t temp = (sensor_data.data.temp & 0xffff) >> 0; // get temp uint8_t humi = (sensor_data.data.temp & 0xffff0000) >> 16; // get humi if(temp > UPPER_TEMP)rt_event_send(&led_event, EVENT_LED_ON); else rt_event_send(&led_event, EVENT_LED_BLINK); // rt_kprintf("temp:%d, humi:%d
" ,temp, humi); mylog("temp :",temp); mylog("humi :",humi); } } } else rt_event_send(&led_event, EVENT_LED_OFF); rt_thread_mdelay(1000); }```2.2,按键中断中累加按键次数```rt_uint8_t key_status = 0; void key_callback1(void *args) { if (rt_pin_read(KEY_PIN) == PIN_LOW) { rt_pin_write(KEY_PIN, PIN_LOW); if(key_status == 255)key_status = 0; // rt_kprintf("key_status = %d", key_status); key_status++; // rt_kprintf("turn on led!
"); } else if (rt_pin_read(KEY_PIN) == PIN_HIGH) { // rt_pin_write(LED_ALERT_PIN, PIN_HIGH); // rt_kprintf("turn off led!
"); } }``` 3,一点小坑,我的芯片flash只有64K但是各模块的甲醛+pm2.5+led+key+温湿度组合起来就超过64K了。 在MDK把代码优化跳到了level-1,我之后删了几个模块又调回了level-0这时候编译完串口打印会各种乱码!!! 搞了我一下午!!! 4,成果图 ![QQ图片20191101181639.png](https://oss-club.rt-thread.org/uploads/201911/01/181657xwwbeb6g1af2fk8w.png)
711
Carry
50
21
rvcore
