w601 添加ali-iotkit软件包编译不过,疯狂报错
发布于 2019-11-11 11:10:03 浏览:1348
w601 添加3.0以后版本的** ali-iotkit 软件包开启配网功能后工程编译无法通过,疯狂报错,有没有大神遇到过解决过** ** ** ** ** ![FastAdmin](https://user-images.githubusercontent.com/34259861/68455897-68077f00-0237-11ea-9ff3-bdf96e745560.png) ![FastAdmin](https://user-images.githubusercontent.com/34259861/68456046-c3397180-0237-11ea-9462-5a5cce9214ae.png) 我已经在github上留下issues了
Jelly
2019-11-13
有没有大神解决一下啊
我夏了夏天
2019-11-13
报的啥错你得贴出来呀
Jelly
2019-11-13
packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(23): warning: #1295-D: Deprecated declaration awss_devinfo_notify - give arg types int awss_devinfo_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(24): warning: #1295-D: Deprecated declaration awss_suc_notify_stop - give arg types int awss_suc_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(25): warning: #1295-D: Deprecated declaration awss_devinfo_notify_stop - give arg types int awss_devinfo_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(28): warning: #1295-D: Deprecated declaration awss_dev_bind_notify - give arg types int awss_dev_bind_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(29): warning: #1295-D: Deprecated declaration awss_dev_bind_notify_stop - give arg types int awss_dev_bind_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(43): warning: #1295-D: Deprecated declaration awss_cmp_online_init - give arg types int awss_cmp_online_init(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(44): warning: #1295-D: Deprecated declaration awss_cmp_online_deinit - give arg types int awss_cmp_online_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(45): warning: #1295-D: Deprecated declaration awss_token_remain_time - give arg types int awss_token_remain_time(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(46): warning: #1295-D: Deprecated declaration awss_token_timeout - give arg types int awss_token_timeout(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(47): warning: #1295-D: Deprecated declaration awss_update_token - give arg types int awss_update_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(48): warning: #1295-D: Deprecated declaration awss_report_token - give arg types int awss_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(49): warning: #1295-D: Deprecated declaration awss_stop_report_token - give arg types int awss_stop_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(56): warning: #1295-D: Deprecated declaration awss_cmp_coap_deinit - give arg types int awss_cmp_coap_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\dev_bind_internal.h(17): error: #5: cannot open source input file "awss_dev_reset.h": No such file or directory #include "awss_dev_reset.h" packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_report.c: 14 warnings, 1 error compiling awss_timer.c... packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(22): warning: #1295-D: Deprecated declaration awss_suc_notify - give arg types int awss_suc_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(23): warning: #1295-D: Deprecated declaration awss_devinfo_notify - give arg types int awss_devinfo_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(24): warning: #1295-D: Deprecated declaration awss_suc_notify_stop - give arg types int awss_suc_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(25): warning: #1295-D: Deprecated declaration awss_devinfo_notify_stop - give arg types int awss_devinfo_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(28): warning: #1295-D: Deprecated declaration awss_dev_bind_notify - give arg types int awss_dev_bind_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(29): warning: #1295-D: Deprecated declaration awss_dev_bind_notify_stop - give arg types int awss_dev_bind_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(43): warning: #1295-D: Deprecated declaration awss_cmp_online_init - give arg types int awss_cmp_online_init(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(44): warning: #1295-D: Deprecated declaration awss_cmp_online_deinit - give arg types int awss_cmp_online_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(45): warning: #1295-D: Deprecated declaration awss_token_remain_time - give arg types int awss_token_remain_time(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(46): warning: #1295-D: Deprecated declaration awss_token_timeout - give arg types int awss_token_timeout(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(47): warning: #1295-D: Deprecated declaration awss_update_token - give arg types int awss_update_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(48): warning: #1295-D: Deprecated declaration awss_report_token - give arg types int awss_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(49): warning: #1295-D: Deprecated declaration awss_stop_report_token - give arg types int awss_stop_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(56): warning: #1295-D: Deprecated declaration awss_cmp_coap_deinit - give arg types int awss_cmp_coap_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\dev_bind_internal.h(17): error: #5: cannot open source input file "awss_dev_reset.h": No such file or directory #include "awss_dev_reset.h" packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_timer.c: 14 warnings, 1 error compiling passwd.c... packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(22): warning: #1295-D: Deprecated declaration awss_suc_notify - give arg types int awss_suc_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(23): warning: #1295-D: Deprecated declaration awss_devinfo_notify - give arg types int awss_devinfo_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(24): warning: #1295-D: Deprecated declaration awss_suc_notify_stop - give arg types int awss_suc_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(25): warning: #1295-D: Deprecated declaration awss_devinfo_notify_stop - give arg types int awss_devinfo_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(28): warning: #1295-D: Deprecated declaration awss_dev_bind_notify - give arg types int awss_dev_bind_notify(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_notify.h(29): warning: #1295-D: Deprecated declaration awss_dev_bind_notify_stop - give arg types int awss_dev_bind_notify_stop(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(43): warning: #1295-D: Deprecated declaration awss_cmp_online_init - give arg types int awss_cmp_online_init(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(44): warning: #1295-D: Deprecated declaration awss_cmp_online_deinit - give arg types int awss_cmp_online_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(45): warning: #1295-D: Deprecated declaration awss_token_remain_time - give arg types int awss_token_remain_time(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(46): warning: #1295-D: Deprecated declaration awss_token_timeout - give arg types int awss_token_timeout(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(47): warning: #1295-D: Deprecated declaration awss_update_token - give arg types int awss_update_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(48): warning: #1295-D: Deprecated declaration awss_report_token - give arg types int awss_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(49): warning: #1295-D: Deprecated declaration awss_stop_report_token - give arg types int awss_stop_report_token(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_cmp.h(56): warning: #1295-D: Deprecated declaration awss_cmp_coap_deinit - give arg types int awss_cmp_coap_deinit(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\dev_bind_internal.h(17): error: #5: cannot open source input file "awss_dev_reset.h": No such file or directory #include "awss_dev_reset.h" packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\passwd.c: 14 warnings, 1 error compiling awss_dev_reset.c... packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_reset\awss_dev_reset.c(4): error: #5: cannot open source input file "dev_bind_internal.h": No such file or directory #include "dev_bind_internal.h" packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\awss_reset\awss_dev_reset.c: 0 warnings, 1 error compiling os_misc.c... packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\os\os_misc.c(4): error: #5: cannot open source input file "dev_bind_internal.h": No such file or directory #include "dev_bind_internal.h" packages\ali-iotkit-latest\iotkit-embedded\src\dev_bind\impl\os\os_misc.c: 0 warnings, 1 error compiling dm_client.c... packages\ali-iotkit-latest\iotkit-embedded\src\dev_model\iotx_dm_internal.h(118): warning: #1295-D: Deprecated declaration add_tail - give arg types unsigned int add_tail(); packages\ali-iotkit-latest\iotkit-embedded\src\dev_model\iotx_dm_internal.h(119): warning: #1295-D: Deprecated declaration reset_log_poll - give arg types int reset_log_poll();
Jelly
2019-11-13
>报的啥错你得贴出来呀 --- 太多了,我随便截取了一段
Cheney_Chen
2019-11-13
[i=s] 本帖最后由 Cheney_Chen 于 2019-11-13 17:05 编辑 [/i] ali-iotkit 软件包中没有适配配网相关的代码,如果你是个人学习可能需要你参考阿里云官方提供的适配方式自行适配配网相关功能,如果你是公司合作 RT-Thread 有提供一份完整针对 W600 设备的阿里云适配 SDK 支持
Jelly
2019-11-14
不是吧,大佬,出现在env里面让我配置,然后告诉我不能用
Jelly
2019-11-15
>ali-iotkit 软件包中没有适配配网相关的代码,如果你是个人学习可能需要你参考阿里云官方提供的适配方式自 ... --- 不是吧,大佬,出现在env里面让我配置,然后告诉我不能用
1.3k
Jelly
