链表
请教链表代码理解问题
发布于 2019-11-21 17:48:54 浏览:1299
在研究stm32f407的I2S时发现有几个函数是官方写的,但是在手册和官方文档中没有找到出处,请官方能否忙里偷闲加入这部分内容,我将此部分源码贴出来请官方获知: ```c /** * Audio Memory Node Manage */ struct rt_data_node { char *data_ptr; rt_uint32_t data_size; }; struct rt_data_node_list { struct rt_data_node *node; rt_uint32_t size; rt_uint32_t read_index, write_index; rt_uint32_t data_offset; void (*read_complete)(struct rt_data_node *node, void *user_data); void *user_data; }; int rt_data_node_init(struct rt_data_node_list **node_list, rt_uint32_t size) { int result = RT_EOK; struct rt_data_node_list *list = RT_NULL; struct rt_data_node *node = RT_NULL; list = rt_malloc(sizeof(struct rt_data_node_list)); if (list == RT_NULL) { result = -RT_ENOMEM; goto __exit; } memset(list, 0, sizeof(struct rt_data_node_list)); node = rt_malloc(sizeof(struct rt_data_node) * size); if (size == RT_NULL) { result = -RT_ENOMEM; goto __exit; } memset(node, 0, sizeof(struct rt_data_node)); list->node = node; list->size = size; list->read_index = 0; list->write_index = 0; list->data_offset = 0; list->read_complete = RT_NULL; list->user_data = 0; *node_list = list; return result; __exit: if (list) rt_free(list); if (node) rt_free(node); return result; } int rt_data_node_is_empty(struct rt_data_node_list *node_list) { rt_uint32_t read_index, write_index; rt_base_t level; level = rt_hw_interrupt_disable(); read_index = node_list->read_index; write_index = node_list->write_index; rt_hw_interrupt_enable(level); if (read_index == write_index) { return RT_TRUE; } else { return RT_FALSE; } } void wait_node_free(struct rt_data_node_list *node_list) { while (node_list->read_index != node_list->write_index) rt_thread_mdelay(5); } int rt_data_node_write(struct rt_data_node_list *node_list, void *buffer, rt_uint32_t size) { struct rt_data_node *node = RT_NULL; rt_uint32_t read_index, write_index, next_index; rt_base_t level; level = rt_hw_interrupt_disable(); read_index = node_list->read_index; write_index = node_list->write_index; rt_hw_interrupt_enable(level); next_index = write_index + 1; if (next_index >= node_list->size) next_index = 0; if (next_index == read_index) { rt_kprintf("[node]:node list full, write index = %d, read index = %d
", write_index, read_index); return -RT_ERROR; } level = rt_hw_interrupt_disable(); /* set node attribute */ node = &node_list->node[write_index]; node->data_ptr = (char *) buffer; node->data_size = size; node_list->write_index = next_index; rt_hw_interrupt_enable(level); return size; } int rt_data_node_read(struct rt_data_node_list *node_list, void *buffer, rt_uint32_t size) { struct rt_data_node *node = RT_NULL; rt_uint32_t read_index, write_index, next_index; rt_int32_t remain_len, copy_size; rt_uint32_t read_offset, data_offset; rt_base_t level; rt_uint32_t result = size; level = rt_hw_interrupt_disable(); read_index = node_list->read_index; write_index = node_list->write_index; rt_hw_interrupt_enable(level); read_offset = 0; if (read_index == write_index) { result = 0; } else { do { node = &node_list->node[node_list->read_index]; data_offset = node_list->data_offset; remain_len = node->data_size - data_offset; if (size - read_offset > remain_len) { /* Full*/ copy_size = remain_len; } else { /* reamain buffer */ copy_size = size - read_offset; } memcpy((char *)buffer + read_offset, node->data_ptr + data_offset, copy_size); read_offset += copy_size; data_offset += copy_size; node_list->data_offset = data_offset; if (data_offset >= node->data_size) { /* notify transmitted complete. */ if (node_list->read_complete != RT_NULL) { node_list->read_complete(node, node_list->user_data); } level = rt_hw_interrupt_disable(); read_index = node_list->read_index; write_index = node_list->write_index; rt_hw_interrupt_enable(level); next_index = read_index + 1; if (next_index >= node_list->size) next_index = 0; level = rt_hw_interrupt_disable(); node_list->read_index = next_index; node_list->data_offset = 0; rt_hw_interrupt_enable(level); if (next_index == write_index) { result = read_offset; break; } } } while (read_offset < size); } return result; } static void data_node_read_complete(struct rt_data_node *node, void *user_data) { struct rt_device *dev = RT_NULL; dev = (struct rt_device *)user_data; if (dev->tx_complete != RT_NULL) { dev->tx_complete(dev, node->data_ptr); } } ```
ROG
2019-11-22
>楼主可以提pr给官方 --- 我不会啊:'(
ROG
2019-11-22
>可参考一下这篇:https://www.rt-thread.org/document/site/development-guide/github/github/ --- 我好难:'(
ROG
2019-11-25
>不对呀,楼主,你这个是什么版本的?master上没有这些函数啊 --- 不是系统内部的在驱动组件里面。作者是Zero-Free还是ZeroFree这位开发者写的组件。我不知道这是一个人还是两个人,傻傻分不清
ROG
2019-11-25
>不是系统内部的在驱动组件里面。作者是Zero-Free还是ZeroFree这位开发者写的组件。我不知道这是一个人还 ... --- 这是源码
liu2guang
2019-11-25
你这个 sound 驱动是老框架的驱动,这几个函数都是驱动中实现的,新的sound框架已经不需要这些东西了
liu2guang
2019-11-25
新的音频框架建议先看看我这个帖子 [https://www.rt-thread.org/qa/thread-422550-1-1.html](https://www.rt-thread.org/qa/thread-422550-1-1.html)
ROG
2019-11-25
>新的音频框架建议先看看我这个帖子 https://www.rt-thread.org/qa/thread-422550-1-1.html --- 这个是适配哪个开发板啊?
ROG
2019-11-25
>新的音频框架建议先看看我这个帖子 https://www.rt-thread.org/qa/thread-422550-1-1.html --- 怎么联系到你,将你的驱动加入进去不响了,原来的最起码还发声呢:'(
liu2guang
2019-11-26
>怎么联系到你,将你的驱动加入进去不响了,原来的最起码还发声呢 --- :L 我的是模板啊,没有驱动实现
qz_rtt
2019-11-26
看来楼主有还有待提高,加油:)
1.3k
ROG
41
121
