scons编译出错
SCONS编译报错了
发布于 2019-11-26 15:03:44 浏览:2378
之前用的一直好的,编译成mdk5版本也没啥问题 今天为了新加入8266外设,一顿操作后,编译不了了 ``` $ scons --target=mdk5 scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "D:\RTT t-thread-v3.1.3 t-thread\bsp\stm32\stm32f10x-sjj\SConstruct", line 33, in
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb8 in position 14: ordinal not in range(128): File "D:\RTT t-thread-v3.1.3 t-thread\bsp\stm32\stm32f10x-sjj\SConstruct", line 59: DoBuilding(TARGET, objs) File "D:\RTT t-thread-v3.1.3 t-thread\tools\building.py", line 766: EndBuilding(target, program) File "D:\RTT t-thread-v3.1.3 t-thread\tools\building.py", line 858: GenTargetProject(program) File "D:\RTT t-thread-v3.1.3 t-thread\tools\building.py", line 795: MDK5Project('project.uvprojx', Projects) File "D:\RTT t-thread-v3.1.3 t-thread\tools\keil.py", line 290: MDK45Project(template_tree, target, script) File "D:\RTT t-thread-v3.1.3 t-thread\tools\keil.py", line 268: out.write(etree.tostring(root, encoding='utf-8').decode()) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 1126: ElementTree(element).write(file, encoding, method=method) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 820: serialize(write, self._root, encoding, qnames, namespaces) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 939: _serialize_xml(write, e, encoding, qnames, None) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 937: write(_escape_cdata(text, encoding)) File "D:\RTT\RT-thread\env_release\env_released_1.1.1\env\tools\Python27\lib\xml\etree\ElementTree.py", line 1073: return text.encode(encoding, "xmlcharrefreplace") ``` 不知道怎么解决,为什么会有这个问题,编译其他例程又是好的,郁闷,卡在这里了
2019-11-27
感觉你目录中有一个中文源文件名 `xx副本.c`
sjj430
2019-11-26
翻看了 https://club.rt-thread.org/ask/question/66c953b690f7e4f0.html 帖子,类似的问题 按照里面的建议,在`env = Environment(tools = ['mingw']`,前面加了`DefaultEnvironment(tools=[])` 执行 `scons --target=mdk5` 报错信息依旧
我夏了夏天
2019-11-26
你这个 bsp 是什么情况
我夏了夏天
2019-11-26
自己做的 bsp? 按照说明检查一下
sjj430
2019-11-26
>自己做的 bsp? 按照说明检查一下[/quote] `\RTT\rt-thread-v3.1.3\rt-thread\bsp\stm32\stm32f10x` 这个BSP基础上改的 之前做的`OLED SIM800C MQTT SHT20`都能正常运行的 - 一、我网上查了报错,基本上都是代码里有utf-8,但是编译器的PY2.7不支持该制式导致的,但我不知道怎么修改 - 二、我的MDK5的工程在keil下是可以编译运行的,然后在env下scons --target=mdk5却报错,所以我怀疑也不是代码的问题
qz_rtt
2019-11-26
` "D:\RTT\rt-thread-v3.1.3\rt-thread\bsp\stm32\stm32f10x-sjj\SConstruct"` 这个文件,33行,有非ascii字符,楼主检查一下看看
qz_rtt
2019-11-26
补充一下,33行14列 ``` File "D:\RTT\rt-thread-v3.1.3\rt-thread\bsp\stm32\stm32f10x-sjj\SConstruct", line 33, in
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb8 in position 14: ordinal not in range(128): ```
sjj430
2019-11-26
>补充一下,33行14列 [attach]12428[/attach] 可是我没改过这个文件,好奇怪,之前是能正常编译的 干脆我上传一下
我夏了夏天
2019-11-27
不推荐你用旧的 bsp 来实现你的工程
sjj430
2019-11-27
>不推荐你用旧的 bsp 来实现你的工程 这是我下载的最新的3.1.3版本啊
2.4k
sjj430
51
scons不支持python3吗?
编译又出现问题
BSP目录下做好一个项目后,怎么把发给别人的包裁剪的小...
为什么重新scons --target=mdk 后,以前在MDK工程里保存的C文
Scons 添加Group,SConscript已经执行,源码却没有添加进工程
scons如何指定输出目录?
新人求助。
想用env 工具自己构建编译环境想用vscode 进行一些简单程序
关于scons脚本问题
使用scons --target=makefile的问题
