最新的STM32_HAL库无法打开和关闭串口TXE中断
发布于 2019-11-28 11:43:10 浏览:2206
因为STM32的各bsp包里的串口驱动一直都没有实现中断发送,前两天看到论坛上关于这个的讨论 [链接](https://www.rt-thread.org/qa/forum.php?mod=viewthread&tid=422730&page=1#pid469913),就想要试试看。我是在野火429核心板上测试的,调试发现使用STM32_HAL的库函数(宏定义)__HAL_UART_ENABLE_IT(UART_IT_TXE) 和 __HAL_UART_DISABLE_IT(UART_IT_TXE) 并不能打开或关闭 UART_IT_TXE中断。 我先找到了这两个宏定义: ```/** @brief Enable the specified UART interrupt. * @param __HANDLE__ specifies the UART Handle. * UART Handle selects the USARTx or UARTy peripheral * (USART,UART availability and x,y values depending on device). * @param __INTERRUPT__ specifies the UART interrupt source to enable. * This parameter can be one of the following values: * @arg UART_IT_CTS: CTS change interrupt * @arg UART_IT_LBD: LIN Break detection interrupt * @arg UART_IT_TXE: Transmit Data Register empty interrupt * @arg UART_IT_TC: Transmission complete interrupt * @arg UART_IT_RXNE: Receive Data register not empty interrupt * @arg UART_IT_IDLE: Idle line detection interrupt * @arg UART_IT_PE: Parity Error interrupt * @arg UART_IT_ERR: Error interrupt(Frame error, noise error, overrun error) * @retval None */ #define __HAL_UART_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((((__INTERRUPT__) >> 28U) == UART_CR1_REG_INDEX)? ((__HANDLE__)->Instance->CR1 |= ((__INTERRUPT__) & UART_IT_MASK)): \ (((__INTERRUPT__) >> 28U) == UART_CR2_REG_INDEX)? ((__HANDLE__)->Instance->CR2 |= ((__INTERRUPT__) & UART_IT_MASK)): \ ((__HANDLE__)->Instance->CR3 |= ((__INTERRUPT__) & UART_IT_MASK))) /** @brief Disable the specified UART interrupt. * @param __HANDLE__ specifies the UART Handle. * UART Handle selects the USARTx or UARTy peripheral * (USART,UART availability and x,y values depending on device). * @param __INTERRUPT__ specifies the UART interrupt source to disable. * This parameter can be one of the following values: * @arg UART_IT_CTS: CTS change interrupt * @arg UART_IT_LBD: LIN Break detection interrupt * @arg UART_IT_TXE: Transmit Data Register empty interrupt * @arg UART_IT_TC: Transmission complete interrupt * @arg UART_IT_RXNE: Receive Data register not empty interrupt * @arg UART_IT_IDLE: Idle line detection interrupt * @arg UART_IT_PE: Parity Error interrupt * @arg UART_IT_ERR: Error interrupt(Frame error, noise error, overrun error) * @retval None */ #define __HAL_UART_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((((__INTERRUPT__) >> 28U) == UART_CR1_REG_INDEX)? ((__HANDLE__)->Instance->CR1 &= ~((__INTERRUPT__) & UART_IT_MASK)): \ (((__INTERRUPT__) >> 28U) == UART_CR2_REG_INDEX)? ((__HANDLE__)->Instance->CR2 &= ~((__INTERRUPT__) & UART_IT_MASK)): \ ((__HANDLE__)->Instance->CR3 &= ~ ((__INTERRUPT__) & UART_IT_MASK))) ```时间是复合型三目运算符来实现的,简单的三目运算符我还能理解,但是这里的这个有点太复杂了。 通过查资料可以发现,TXEIE中断开关就在CR1寄存器里,所以我直接将上面的三目运算简化为: 打开中断: ```(&(uart->handle))->Instance->CR1 |= ((UART_FLAG_TXE) & UART_IT_MASK);``` 关闭中断: ```(&(uart->handle))->Instance->CR1 &= ~((UART_FLAG_TXE) & UART_IT_MASK);```测试可以实现TXE中断的打开和关闭,也就是说HAL库函数的宏定义里用到的三目运算有问题。那到底错在哪里呢,有哪位能解释一下呢? 还有就是这个宏定义对于有些中断还是可以打开和关闭的,如 ```__HAL_UART_DISABLE_IT(&(uart->handle), UART_IT_RXNE);```因为没有一一测试,暂时只发现TXE中断使能/关闭的问题。
yaomo718
2019-12-12
自己顶一下,不让这个问题沉下去
SXW101320
2019-12-12
您好,我按照之前发的代码的例子,使用串口发送中断。现在串口不能发送。我现在不清楚open时以什么方式打开设备 ``` uint8_t ch[8] = {0xff}; serial = rt_device_find("uart3"); rt_device_open(serial,RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX); rt_device_write(serial, 0, ch, 8); static rt_err_t scm4_control(struct rt_serial_device *serial, int cmd, void *arg) { struct scm_uart *uart; RT_ASSERT(serial != RT_NULL); uart = rt_container_of(serial, struct scm_uart, serial); switch (cmd) { /* disable interrupt */ case RT_DEVICE_CTRL_CLR_INT: /* disable rx irq */ NVIC_DisableIRQ(uart->irq); /* disable interrupt */ USART_INTConfig(uart->Uazx, USART_INT_RDNE, DISABLE); break; /* enable interrupt */ case RT_DEVICE_CTRL_SET_INT: /* enable rx irq */ NVIC_EnableIRQ(uart->irq); /* enable interrupt */ if(serial->parent.open_flag & RT_DEVICE_FLAG_INT_RX) //SXW 20191212接收非空中断 { USART_INTConfig(uart->Uazx, USART_INT_RDNE, ENABLE); } if(serial->parent.open_flag & RT_DEVICE_FLAG_INT_TX) //SXW 20191212发送空中断 { USART_INTConfig(uart->Uazx, USART_INT_TDE, ENABLE); } break; } return RT_EOK; } static int scm4_putc(struct rt_serial_device *serial, char c) { struct scm_uart *uart; RT_ASSERT(serial != RT_NULL); uart = rt_container_of(serial, struct scm_uart, serial); if(serial->parent.open_flag & RT_DEVICE_FLAG_INT_TX) { if(USART_GetFlagStatus(uart->Uazx,USART_FLAG_TDE) != RESET) { USART_ClearFlag(uart->Uazx,USART_FLAG_TDE); uart->Uazx->DT = (c & (uint16_t)0x01FF); return 1; } else { return -1; } } else { USART_ClearFlag(uart->Uazx,USART_FLAG_TRAC); uart->Uazx->DT = (c & (uint16_t)0x01FF); while (USART_GetFlagStatus(uart->Uazx, USART_FLAG_TRAC) == RESET); return 1; } } static void uart_isr(struct rt_serial_device *serial) { struct scm_uart *uart; RT_ASSERT(serial != RT_NULL); uart = rt_container_of(serial, struct scm_uart, serial); /* UART in mode Receiver -------------------------------------------------*/ if ((USART_GetFlagStatus(uart->Uazx, USART_FLAG_RDNE) != RESET) && //SXW接收中断 (USART_GetITStatus(uart->Uazx, USART_INT_RDNE) != RESET)) { rt_hw_serial_isr(serial, RT_SERIAL_EVENT_RX_IND); /* Clear RXNE interrupt flag */ USART_ClearITPendingBit(uart->Uazx, USART_INT_RDNE); } else if(USART_GetFlagStatus(uart->Uazx,USART_FLAG_TDE) != RESET) { if(serial->parent.open_flag & RT_DEVICE_FLAG_INT_TX) { rt_hw_serial_isr(serial, RT_SERIAL_EVENT_TX_DONE); USART_ClearFlag(uart->Uazx,USART_FLAG_TDE); } } } ```
SXW101320
2019-12-12
您好,谢谢您的代码。我现在能串口中断发送了。原因是我之前理解您的代码错了。您在中断函数和putc函数中操作的是禁止和使能发送空中断,而我理解为清标志了。还是就是我的MCU的特点是开发送空中断,会先进入中断服务函数里,此时就会死在中断服务函数里。所有我在开发送空中断时,就是先对发送缓冲区赋值,然后开发送空中断。 ``` uart->Uazx->DT = (c & (uint16_t)0x01FF); USART_INTConfig(uart->Uazx,USART_INT_TDE,ENABLE); ```
2.2k
yaomo718
83
