Kernel
使用paho-mqtt里例程连接服务器失败
发布于 2019-12-19 08:51:02 浏览:2707
【rt-thread】【paho-mqtt】最近由于学习需要,了解了关于rt-thread软件包paho-mqtt的使用,但是使用官方例程时,出现连接不上服务器的情况。具体报错如下: ``` msh />matt start [D/mgtt. sample] inter matt connect callback! [D/mgtt] ipv4 address port:1883 |[D/mqtt] HOST=iot.eclipse.org' [E/mgtt] getaddrinfo err:-1'iot.eclipse.org' [E/mgtt] resolve uri err [E/mqtt] Net connect error(-1). [D/mgtt. sample] inter matt offline callback! ``` 其中服务器IP地址尝试用过:官方例程提供的 `“tcp://iot.eclipse.org:1883”`、用通信猫提供的服务器`"tcp://mq.tongxinmao:18831"`、以及用ActiveMQ建立的本地服务器`“tcp://192.168.0.242:1883”`,都是报同样的错误`”getaddrinfo err:-1“`。 请问有大神做过类似的吗?有没有遇到这种问题,最后怎么解决的,望指点,多谢!! 例程代码如下: ```c #include
#define DBG_ENABLE #define DBG_SECTION_NAME "mqtt.sample" #define DBG_LEVEL DBG_LOG #define DBG_COLOR #include
#include "paho_mqtt.h" /** * MQTT URI farmat: * domain mode * tcp://iot.eclipse.org:1883 * * ipv4 mode * tcp://192.168.10.1:1883 * ssl://192.168.10.1:1884 * * ipv6 mode * tcp://[fe80::20c:29ff:fe9a:a07e]:1883 * ssl://[fe80::20c:29ff:fe9a:a07e]:1884 */ #define MQTT_URI "tcp://iot.eclipse.org:1883" // tcp://iot.eclipse.org:1883 tcp://mqtt.eclipse.org:1883 #define MQTT_SUBTOPIC "/mqtt/test" #define MQTT_PUBTOPIC "/mqtt/test" #define MQTT_WILLMSG "Goodbye!" /* define MQTT client context */ static MQTTClient client; static int is_started = 0; static void mqtt_sub_callback(MQTTClient *c, MessageData *msg_data) { *((char *)msg_data->message->payload + msg_data->message->payloadlen) = '\0'; LOG_D("mqtt sub callback: %.*s %.*s", msg_data->topicName->lenstring.len, msg_data->topicName->lenstring.data, msg_data->message->payloadlen, (char *)msg_data->message->payload); } static void mqtt_sub_default_callback(MQTTClient *c, MessageData *msg_data) { *((char *)msg_data->message->payload + msg_data->message->payloadlen) = '\0'; LOG_D("mqtt sub default callback: %.*s %.*s", msg_data->topicName->lenstring.len, msg_data->topicName->lenstring.data, msg_data->message->payloadlen, (char *)msg_data->message->payload); } static void mqtt_connect_callback(MQTTClient *c) { LOG_D("inter mqtt_connect_callback!"); } static void mqtt_online_callback(MQTTClient *c) { LOG_D("inter mqtt_online_callback!"); } static void mqtt_offline_callback(MQTTClient *c) { LOG_D("inter mqtt_offline_callback!"); } static int mqtt_start(int argc, char **argv) { /* init condata param by using MQTTPacket_connectData_initializer */ MQTTPacket_connectData condata = MQTTPacket_connectData_initializer; static char cid[20] = { 0 }; if (argc != 1) { rt_kprintf("mqtt_start --start a mqtt worker thread.
"); return -1; } if (is_started) { LOG_E("mqtt client is already connected."); return -1; } /* config MQTT context param */ { client.isconnected = 0; client.uri = MQTT_URI; /* generate the random client ID */ rt_snprintf(cid, sizeof(cid), "rtthread%d", rt_tick_get()); /* config connect param */ memcpy(&client.condata, &condata, sizeof(condata)); client.condata.clientID.cstring = cid; client.condata.keepAliveInterval = 30; client.condata.cleansession = 1; /* config MQTT will param. */ client.condata.willFlag = 1; client.condata.will.qos = 1; client.condata.will.retained = 0; client.condata.will.topicName.cstring = MQTT_PUBTOPIC; client.condata.will.message.cstring = MQTT_WILLMSG; /* malloc buffer. */ client.buf_size = client.readbuf_size = 1024; client.buf = rt_calloc(1, client.buf_size); client.readbuf = rt_calloc(1, client.readbuf_size); if (!(client.buf && client.readbuf)) { LOG_E("no memory for MQTT client buffer!"); return -1; } /* set event callback function */ client.connect_callback = mqtt_connect_callback; client.online_callback = mqtt_online_callback; client.offline_callback = mqtt_offline_callback; /* set subscribe table and event callback */ client.messageHandlers[0].topicFilter = rt_strdup(MQTT_SUBTOPIC); client.messageHandlers[0].callback = mqtt_sub_callback; client.messageHandlers[0].qos = QOS1; /* set default subscribe event callback */ client.defaultMessageHandler = mqtt_sub_default_callback; } /* run mqtt client */ paho_mqtt_start(&client); is_started = 1; return 0; } static int mqtt_stop(int argc, char **argv) { if (argc != 1) { rt_kprintf("mqtt_stop --stop mqtt worker thread and free mqtt client object.
"); } is_started = 0; return paho_mqtt_stop(&client); } static int mqtt_publish(int argc, char **argv) { if (is_started == 0) { LOG_E("mqtt client is not connected."); return -1; } if (argc == 2) { paho_mqtt_publish(&client, QOS1, MQTT_PUBTOPIC, argv[1]); } else if (argc == 3) { paho_mqtt_publish(&client, QOS1, argv[1], argv[2]); } else { rt_kprintf("mqtt_publish
[message] --mqtt publish message to specified topic.
"); return -1; } return 0; } static void mqtt_new_sub_callback(MQTTClient *client, MessageData *msg_data) { *((char *)msg_data->message->payload + msg_data->message->payloadlen) = '\0'; LOG_D("mqtt new subscribe callback: %.*s %.*s", msg_data->topicName->lenstring.len, msg_data->topicName->lenstring.data, msg_data->message->payloadlen, (char *)msg_data->message->payload); } static int mqtt_subscribe(int argc, char **argv) { if (argc != 2) { rt_kprintf("mqtt_subscribe [topic] --send an mqtt subscribe packet and wait for suback before returning.
"); return -1; } if (is_started == 0) { LOG_E("mqtt client is not connected."); return -1; } return paho_mqtt_subscribe(&client, QOS1, argv[1], mqtt_new_sub_callback); } static int mqtt_unsubscribe(int argc, char **argv) { if (argc != 2) { rt_kprintf("mqtt_unsubscribe [topic] --send an mqtt unsubscribe packet and wait for suback before returning.
"); return -1; } if (is_started == 0) { LOG_E("mqtt client is not connected."); return -1; } return paho_mqtt_unsubscribe(&client, argv[1]); } #ifdef FINSH_USING_MSH MSH_CMD_EXPORT(mqtt_start, startup mqtt client); MSH_CMD_EXPORT(mqtt_stop, stop mqtt client); MSH_CMD_EXPORT(mqtt_publish, mqtt publish message to specified topic); MSH_CMD_EXPORT(mqtt_subscribe, mqtt subscribe topic); MSH_CMD_EXPORT(mqtt_unsubscribe, mqtt unsubscribe topic); #endif /* FINSH_USING_MSH */ ``` 参考链接:https://github.com/RT-Thread-packages/paho-mqtt/blob/master/docs/samples.md
hichard
2019-12-31
通信猫就可以!要么自己搭一个EMQX。rtt的组件选mymqtt吧,paho-mqtt有一些弊端
CreateShare
2021-01-30
坚持创造!坚持分享!坚持感恩!坚持自然! Keep Creating! Keep Sharing! Keep Thanksgiving! Keep Nature!
换成 `“test.mosquitto.org”` 这个MQTT Broker测试服务器,可以正常测试。 例如,修改 `mqtt_sample.c`,修改MQTT_URI如下: 原来:`#define MQTT_URI "tcp://iot.eclipse.org:1883" ` 改成:`#define MQTT_URI "tcp://test.mosquitto.org:1883"`
2019-12-19
我怀疑楼上的网络就是不通哈,可以在PC上面抓包看看。
RTT_User1
2019-12-19
可以先使用MQTT.fx工具测试一下能不能连接到MQTT服务端
noerr
2019-12-25
先把TCP 测通了吧 之后就把这个mqtt的包拉下来即可
chua052
2019-12-27
>可以先使用MQTT.fx工具测试一下能不能连接到MQTT服务端 --- 用mqtt.fx工具可以通信,按官方例程在keil上软件仿真运行命令“mqtt_start” 不行
chua052
2019-12-27
>我怀疑楼上的网络就是不通哈,可以在PC上面抓包看看。 --- 用wireshark抓包吗?
chua052
2019-12-27
>先把TCP 测通了吧 之后就把这个mqtt的包拉下来即可 --- tcp怎么测呢?mqtt的包我上在ENV工具安装的
noerr
2019-12-31
自己做客户端 电脑上随便写个服务器 收发下数据看看OK不
noerr
2019-12-31
>tcp怎么测呢?mqtt的包我上在ENV工具安装的 --- 自己做客户端 电脑上随便写个服务器 收发下数据看看OK不
2.7k
chua052
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
