Kernel
关于使用arm-none-eabi-gcc的编译问题
发布于 2019-12-31 11:14:00 浏览:2417
我想移植rt-thread nano至我的工程内,工程使用的模板是一个Makefile工程.交叉编译器的版本是: gcc version 8.2.1 20181213 (release) [gcc-8-branch revision 267074] (GNU MCU Eclipse ARM Embedded GCC, 64-bit) 在编译divsi3.S的时候出现编译错误,请问各路大神有没有经验能帮助我解决此问题。以下是编译信息 arm-none-eabi-gcc -x assembler-with-cpp -c -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=hard -DUSE_FULL_LL_DRIVER -DHSE_VALUE=25000000 -DHSE_STARTUP_TIMEOUT=100 -DLSE_STARTUP_TIMEOUT=5000 -DLSE_VALUE=32768 -DEXTERNAL_CLOCK_VALUE=12288000 -DHSI_VALUE=16000000 -DLSI_VALUE=32000 -DVDD_VALUE=3300 -DPREFETCH_ENABLE=1 -DINSTRUCTION_CACHE_ENABLE=1 -DDATA_CACHE_ENABLE=1 -DSTM32F401xE -Irt-thread/include -Irt-thread/components/drivers/include -Irt-thread/components/finsh -Og -Wall -fdata-sections -ffunction-sections -g -gdwarf-2 -MMD -MP -MF"build/divsi3.d" rt-thread/libcpu/arm/common/divsi3.S -o build/divsi3.o rt-thread/libcpu/arm/common/divsi3.S: Assembler messages: rt-thread/libcpu/arm/common/divsi3.S:34: Error: lo register required -- `stmfd sp!,{lr}' rt-thread/libcpu/arm/common/divsi3.S:39: Error: lo register required -- `ldmfd sp!,{pc}' rt-thread/libcpu/arm/common/divsi3.S:46: Error: lo register required -- `stmfd sp!,{lr}' rt-thread/libcpu/arm/common/divsi3.S:51: Error: lo register required -- `ldmfd sp!,{pc}' rt-thread/libcpu/arm/common/divsi3.S:55: Error: unshifted register required -- `mvn r0,#0' rt-thread/libcpu/arm/common/divsi3.S:71: Error: only lo regs allowed with immediate -- `mov ip,#0' rt-thread/libcpu/arm/common/divsi3.S:74: Error: unshifted register required -- `orr ip,ip,#0x20000000' rt-thread/libcpu/arm/common/divsi3.S:75: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `movs r1,r1,lsr#1' rt-thread/libcpu/arm/common/divsi3.S:76: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:97: Error: instruction not supported in Thumb16 mode -- `ands ip,r0,#0x80000000' rt-thread/libcpu/arm/common/divsi3.S:98: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:99: Error: instruction not supported in Thumb16 mode -- `ands r2,r1,#0x80000000' rt-thread/libcpu/arm/common/divsi3.S:100: Error: lo register required -- `eor ip,ip,r2' rt-thread/libcpu/arm/common/divsi3.S:101: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:102: Error: unshifted register required -- `orr ip,r2,ip,lsr#1' ... rt-thread/libcpu/arm/common/divsi3.S:192: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `cmp r1,r0,lsl#1' rt-thread/libcpu/arm/common/divsi3.S:194: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `cmp r1,r0,lsl#2' rt-thread/libcpu/arm/common/divsi3.S:196: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `cmp r1,r0,lsl#3' ... rt-thread/libcpu/arm/common/divsi3.S:254: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:255: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:257: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `cmp r1,r0,lsl#30' rt-thread/libcpu/arm/common/divsi3.S:258: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:259: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:261: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `cmp r1,r0,lsl#29' rt-thread/libcpu/arm/common/divsi3.S:262: Error: Thumb does not support conditional execution rt-thread/libcpu/arm/common/divsi3.S:263: Error: Thumb does not support conditional execution ... Makefile:96: recipe for target 'build/divsi3.o' failed make: *** [build/divsi3.o] Error 1 请问是不是我需要使用更低版本的编译器去重新尝试编译?
Mestic英
2019-12-31
是否我不需要添加编译此文件。。。
2.4k
Mestic英
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
