page256_or_1_byte_write
发布于 2020-02-14 21:02:50 浏览:1192
有个关于page256_or_1_byte_write 这个函数的问题 代码如下 ```static sfud_err page256_or_1_byte_write(const sfud_flash *flash, uint32_t addr, size_t size, uint16_t write_gran, const uint8_t *data) { sfud_err result = SFUD_SUCCESS; const sfud_spi *spi = &flash->spi; static uint8_t cmd_data[5 + SFUD_WRITE_MAX_PAGE_SIZE]; uint8_t cmd_size; size_t data_size; SFUD_ASSERT(flash); /* only support 1 or 256 */ SFUD_ASSERT(write_gran == 1 || write_gran == 256); /* must be call this function after initialize OK */ SFUD_ASSERT(flash->init_ok); /* check the flash address bound */ if (addr + size > flash->chip.capacity) { SFUD_INFO("Error: Flash address is out of bound."); return SFUD_ERR_ADDR_OUT_OF_BOUND; } /* lock SPI */ if (spi->lock) { spi->lock(spi); } /* loop write operate. write unit is write granularity */ while (size) { /* set the flash write enable */ result = set_write_enabled(flash, true); if (result != SFUD_SUCCESS) { goto __exit; } cmd_data[0] = SFUD_CMD_PAGE_PROGRAM; make_adress_byte_array(flash, addr, &cmd_data[1]); cmd_size = flash->addr_in_4_byte ? 5 : 4; /* make write align and calculate next write address */ SFUD_INFO("addr=%d ",addr); if (addr % write_gran != 0) { if (size > write_gran - (addr % write_gran)) { data_size = write_gran - (addr % write_gran); } else { data_size = size; } } else { if (size > write_gran) { data_size = write_gran; }else { data_size = size; } } size -= data_size; addr += data_size; memcpy(&cmd_data[cmd_size], data, data_size); result = spi->wr(spi, cmd_data, cmd_size + data_size, NULL, 0); if (result != SFUD_SUCCESS) { SFUD_INFO("Error: Flash write SPI communicate error."); goto __exit; } result = wait_busy(flash); if (result != SFUD_SUCCESS) { goto __exit; } data += data_size; } __exit: /* set the flash write disable */ set_write_enabled(flash, false); /* unlock SPI */ if (spi->unlock) { spi->unlock(spi); } return result; } ```最终是调用result = spi->wr(spi, cmd_data, cmd_size + data_size, NULL, 0); 将数据写入flash 在执行之前可以看到data_size的值并不等于入参size,会根据page的大小和地址做改变,flash 每次写入应该写入一个page 那么若地址为page的起始地址,长度小于page,是不是应该先读取一个page的内容,然后在memcpy写入的数据,然后在写入page, 若地址不为page的起始地址,那么要考虑写入的长度是否在两个page内。 不知道我这样的理解对不对,但是这个函数并没有读取的操作。 还是说flash可以不以page进行写操作的么?
ZBXY_7941
2020-06-19
在这个程序中 make_adress_byte_array(flash, addr, &cmd_data[1]); cmd_size = flash->addr_in_4_byte ? 5 : 4; 这两句代码是啥作用?您可以讲解一下吗?
1.2k
freedom195
好好学习,天天向上
30
53
【分享】如何使用 SFUD 库来操作 SPI Flash 设备
SFUD怎么使用
请教大家一下关于 SFUD 的的问题
移植sfud
使用SFUD操作FLASH
env使用easyflash不是3.2.4版本,而且没有type插件?
新增了W25X32设备成功,无法格式化
easyflash随着数据存储量增加,耗费时间加长
关于SFDP的问题
spi nand flash 能使用SFUD驱动吗
21
rvcore
