SFUD测试出现的问题
发布于 2020-02-21 16:02:56 浏览:1545
**1.背景:** 主控芯片:LPC54606 Flash芯片:W25Q256 SPI总线:SPIFI **2.初始化打印信息如下:** [SFUD] (..\..\components\drivers\spi\sfud\src\sfud.c:861) The flash device manufacturer ID is 0xEF, memory type ID is 0x40, capacity ID is 0x19. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:131) Check SFDP header is OK. The reversion is V1.5, NPN is 0. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:173) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.5, length is 16, parameter table pointer is 0x000080. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:203) JEDEC basic flash parameter table info: [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0001] 0xFF 0xFB 0x20 0xE5 [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0002] 0x0F 0xFF 0xFF 0xFF [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0003] 0x6B 0x08 0xEB 0x44 [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0004] 0xBB 0x42 0x3B 0x08 [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0006] 0x00 0x00 0xFF 0xFF [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0007] 0xEB 0x40 0xFF 0xFF [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:206) [0009] 0x00 0x00 0xD8 0x10 [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x20. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:234) Write granularity is 64 bytes or larger. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:245) Target flash status register is non-volatile. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:276) 3- or 4-Byte addressing. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:305) Capacity is 33554432 Bytes. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 4KB block erase. Command is 0x20. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 32KB block erase. Command is 0x52. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud_sfdp.c:311) Flash device supports 64KB block erase. Command is 0xD8. [SFUD] Find a Winbond flash chip. Size is 33554432 bytes. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud.c:840) Flash device reset success. [SFUD] (..\..\components\drivers\spi\sfud\src\sfud.c:941) Enter 4-Byte addressing mode success. [SFUD] W25Q256 flash device is initialize success. [SFUD] Probe SPI flash W25Q256 by SPI device spifi0 success. **3.sf 命令测试结果如下:** msh />sf bench yes Erasing the sf_cmd 33554432 bytes data, waiting... Erase benchmark success, total time: 45.389S. Writing the sf_cmd 33554432 bytes data, waiting... Write benchmark success, total time: 131.072S. Reading the sf_cmd 33554432 bytes data, waiting... Data check ERROR! Please check you flash by other command. Read sf_cmd failed, already rd for 0 bytes, read 256 each time Read benchmark has an error. Error code: 3. This flash operate has an error. Error code: 3. msh />sf write 0 1 2 3 4 5 Write the sf_cmd flash data success. Start from 0x00000000, size is 5. Write data: 1 2 3 4 5 . msh />sf read 0 16 Read the sf_cmd flash data success. Start from 0x00000000, size is 16. The data is: Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F [00000000] 00 00 00 01 00 01 04 05 55 55 55 55 55 55 55 55 ........UUUUUUUU 4.问题 从sf测试的情况来看,对flash的操作还是有问题的。 1)写入读入数据不一致; 2)sf bench 最后的read出错了; 还想请问一下,各位有没有遇到类似的问题,如何解决的?
Alex.Pan
2020-02-21
因为初始化是成功的,所以我觉得读写寄存器是成功的,SPIFI总线已经驱动起来了。
Alex.Pan
2020-02-22
问题已经解决。 在将dummy cycles转换为SPIFI的intermediateBytes时直接使用了如下代码: spifi_command.intermediateBytes = message->dummy_cycles / 8; 但是,该代码在地址数据以标准SPI传输时没有问题。 因为此时dummy_cycles/8就是字节数 但是对于dual和quad模式,会导致字节数减少; 应该修改为如下: if(message->address.qspi_lines!=0) spifi_command.intermediateBytes = message->dummy_cycles*message->address.qspi_lines / 8; else spifi_command.intermediateBytes = message->dummy_cycles / 8;
Alex.Pan
2020-02-22
后来的测试结果: msh />sf bench yes Erasing the sf_cmd 33554432 bytes data, waiting... [66595] E/at.clnt: execute command (AT+CIPDOMAIN="cn.ntp.org.cn") failed! [73595] E/at.clnt: execute command (AT+CIPDOMAIN="hk.ntp.org.cn") failed! [80594] E/at.clnt: execute command (AT+CGREG?) failed! [80702] E/at.clnt: execute command (AT+CIPCLOSE=0) failed! Erase benchmark success, total time: 44.882S. Writing the sf_cmd 33554432 bytes data, waiting... Write benchmark success, total time: 131.072S. Reading the sf_cmd 33554432 bytes data, waiting... Read benchmark success, total time: 5.933S. msh /> 之前由于dummy cycles错误,导致在读出时漏掉了3个intermediateBytes ,所以读出来时前三个字节是0,导致bench read错误。
1.5k
Alex.Pan
21
28
【分享】如何使用 SFUD 库来操作 SPI Flash 设备
SFUD怎么使用
请教大家一下关于 SFUD 的的问题
移植sfud
使用SFUD操作FLASH
env使用easyflash不是3.2.4版本,而且没有type插件?
新增了W25X32设备成功,无法格式化
easyflash随着数据存储量增加,耗费时间加长
关于SFDP的问题
spi nand flash 能使用SFUD驱动吗
