为scons工具添加Flash ram使用占比自动计算功能
发布于 2020-03-02 22:55:09 浏览:1230
[tocm] * 本帖最后由 passion 于 2020-3-2 22:56 编辑 * 为了解决前面发帖的困扰 [https://club.rt-thread.org/ask/question/423709.html](https://club.rt-thread.org/ask/question/423709.html) 在工程中创建如何脚本 calelf.py ```#!/usr/bin/python # -*- coding: UTF-8 -*- import sys import os import commands import math FLASH_SIZE = 1024 MEM_SIZE = 196 TARGET= sys.argv[1] def convertBytes(bytes, lst=['Bytes', 'KB', 'MB', 'GB', 'TB', 'PB']): i = int(math.floor( # 舍弃小数点,取小 math.log(bytes, 1024) # 求对数(对数:若 a**b = N 则 b 叫做以 a 为底 N 的对数) )) if i >= len(lst): i = len(lst) - 1 return ('%.2f' + " " + lst) % (bytes/math.pow(1024, i)) PREFIX = 'arm-none-eabi-size' # The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx) # either it can be added to the PATH environment variable. result = os.popen('arm-none-eabi-size ' +TARGET) r = result.read() # print r arr=r.splitlines()[1].split("\t") # print arr flash = int(arr[0]) + int(arr[1]) mem = int(arr[1]) + int(arr[2]) flash_size=FLASH_SIZE*1024 mem_size=MEM_SIZE*1024 flash_usage = float(flash*100/flash_size) mem_usage = float(mem*100/mem_size) # print ("") print ("-------------------------------------------------------------") print ('Flash: %s / %s , %4.2f%% (.text + .data)'%(convertBytes(flash),convertBytes(flash_size),flash_usage)) print ('SRAM: %s / %s, %4.2f%% (.data + .bss )'%(convertBytes(mem),convertBytes(mem_size),mem_usage))```* 然后在rtconfig.py中添加 POST_ACTION 如:+ 'python calelf.py rt-thread.elf
' *```POST_ACTION = OBJCPY + ' -O binary $TARGET rtthread.bin
' + OBJCPY + ' -O ihex $TARGET rtthread.hex
' + SIZE + ' $TARGET
' + 'python calelf.py rt-thread.elf
'```* 然后就可以尽情的happy了,下面是编译效果展示 ![22333.PNG](/uploads/202003/02/225055ifj2zzj19ooij12u.png) 存在的不足:每个工程都需要单独创建文件,期待能将这个功能添加的scons的官方功能里面 去除原有POST_ACTION 中 SIZE + ' $TARGET
' 可以关闭默认的编译大小输出,只显示自定义的占比式输出 更简洁 鸣谢:我夏了夏天 感谢给予的指点 *
我夏了夏天
2020-03-03
:D 赞!
2020-03-03
前排点赞!
nongxiaoming
2020-03-03
rt-thread大师兄
看起来不错,是不是有点小bug?为啥百分比后面两位小数点一直是00?保留两位小数的话按着两个比值好像不是.00啊
通宵敲代码
2020-03-03
这家伙不懒,他只是什么都不想写
很棒的功能
flyboy
2020-03-05
Do my self();
感觉很棒
passion
2020-03-05
[i=s] 本帖最后由 passion 于 2020-3-5 17:13 编辑 [/i] >看起来不错,是不是有点小bug?为啥百分比后面两位小数点一直是00?保留两位小数的话按着两个比值好像不是. ... --- 很赞的回复 确实有个bug python除法 显示的将其中一个数float下就正常 ``` flash_usage = float(flash*100)/flash_size mem_usage = float(mem*100)/mem_size ``` [attach]13926[/attach] 咱们论坛已经发布的帖子咱们重新编辑?
1.2k
passion
82
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
恩智浦mcxn947的RT-Thread的PIN驱动测评
