STM32_CCM_特殊内存
STM32F4在RT-Thread Studio中使用CCM SRAM
发布于 2020-03-21 20:28:55 浏览:4443
[tocm] STM32F4x有192KB的SRAM,其中128KB 在总线矩阵上,64KB的CCM RAM在专为CPU使用的数据总线上。RT-Thread Studio默认只能使用128KB,没法使用CCM SRAM。参考ST的AN4296文档,实现了CCM SRAM的使用, **必须保证DMA或者其他不通过CPU可能访问到数据的不在CCM RAM里面**。 具体步骤如下: ## 一、配置文件修改 1. 通过设定CCM RAM 区域的起始地址与大小,在链接器文件(.ld)中定义新的区域 ```c MEMORY { ROM (rx) : ORIGIN = 0x08000000, LENGTH = 512k /* 512K flash */ RAM (rw) : ORIGIN = 0x20000000, LENGTH = 128k /* 128K sram */ CCMRAM (xrw) : ORIGIN = 0x10000000, LENGTH = 64k /* 64K ccm ram */ } ``` ## 2. 在链接器中指明, 带有ccmram 属性的代码段必须放在CCM RAM 中 ```c .stack : { . = ALIGN(4); _sstack = .; . = . + _system_stack_size; . = ALIGN(4); _estack = .; } >RAM _siccmram = LOADADDR(.ccmram); /* CCM-RAM section * * IMPORTANT NOTE! * If initialized variables will be placed in this section, * the startup code needs to be modified to copy the init-values. */ .ccmram : { . = ALIGN(4); _sccmram = .; /* create a global symbol at ccmram start */ *(.ccmram) *(.ccmram*) . = ALIGN(4); _eccmram = .; /* create a global symbol at ccmram end */ } >CCMRAM __bss_start = .; .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(.bss.*) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; *(.bss.init) } > RAM ``` ## 3. 修改启动文件 从而在启动时对数据进行初始化并放入CCM RAM (参见红色的代码行): ```asm /* Copy the data segment initializers from flash to SRAM */ movs r1, #0 b LoopCopyDataInit CopyDataInit: ldr r3, =_sidata ldr r3, [r3, r1] str r3, [r0, r1] adds r1, r1, #4 LoopCopyDataInit: ldr r0, =_sdata ldr r3, =_edata adds r2, r0, r1 cmp r2, r3 bcc CopyDataInit movs r1, #0 b LoopCopyDataInit1 CopyDataInit1: ldr r3, =_siccmram ldr r3, [r3, r1] str r3, [r0, r1] adds r1, r1, #4 LoopCopyDataInit1: ldr r0, =_sccmram ldr r3, =_eccmram adds r2, r0, r1 cmp r2, r3 bcc CopyDataInit1 ldr r2, =_sbss b LoopFillZerobss /* Zero fill the bss segment. */ FillZerobss: movs r3, #0 str r3, [r2], #4 ``` ## 二、具体应用 1. 通过在函数原型中添加属性关键字,将需要从CCM RAM 执行的代码放入.ccmram区段: ```c void led08_draw_point(uint8_t x,uint8_t y,uint8_t t) __attribute__((section (".ccmram"))); ``` 2、从CCM RAM 执行文件 从CCM RAM 执行源文件意味着该文件所声明的全部函数均从CCM RAM 执行。 将文件放入CCM RAM,如下所示: ```c /* CCM-RAM section * * IMPORTANT NOTE! * If initialized variables will be placed in this section, * the startup code needs to be modified to copy the init-values. */ .ccmram : { . = ALIGN(4); _sccmram = .; /* create a global symbol at ccmram start */ *(.ccmram) *(.ccmram*) ./rt-thread/components/finsh/cmd.o(*) ./rt-thread/components/finsh/finsh_heap.o(*) ./rt-thread/components/finsh/finsh_heap.o(*) ./rt-thread/components/finsh/finsh_vm.o(*) ./rt-thread/components/finsh/shell.o(*) ./rt-thread/components/finsh/finsh_error.o(*) ./rt-thread/components/finsh/msh.o(*) ./rt-thread/components/utilities/ulog/backend/console_be.o(*) ./rt-thread/components/utilities/ulog/ulog.o(*) . = ALIGN(4); _eccmram = .; /* create a global symbol at ccmram end */ } >CCMRAM ``` 3.从CCM RAM 执行库 将库放入CCM RAM,如下所示: ```c .ccmram : { . = ALIGN(4); _sccmram = .; /* create a global symbol at ccmram start */ *(.ccmram) *(.ccmram*) mylib.a(*) . = ALIGN(4); _eccmram = .; /* create a global symbol at ccmram end */ } >CCMRAM ```
sync
2020-04-17
这个很实用啊,多谢楼主 咨询下,这样处理后CCM SRAM 可以使用rt_malloc分配吗?
majianjia
2020-04-17
>这个很实用啊,多谢楼主 >咨询下,这样处理后CCM SRAM 可以使用rt_malloc分配吗? ... --- 初始化一个memheap就可以直接使用。但是为了避免分配到DMA不能使用的内存。建议不要把所有的memheap合在一起
armink
2020-04-18
果断收藏
williammyq
2020-07-27
楼主,我按照你这种方式定义了一个数组在.ccmram,是直接使用__attribute_(section(".ccmram"))的方式操作的,结果用rt_kprintf是错误数据,用.data就是对的,你试过直接定义位置,然后打印数据吗?
jimmykudo
2020-12-07
按这个方法试了,下载完程序是可以的,重启以后section那个定向那块内存就是NULL
lazyguoguo
2021-06-16
多谢楼主,基本按照楼主配置,ccm可利用起来。我的应用是把任务栈建在 ccmram 。 ```c static struct rt_thread LED_thread; ALIGN(RT_ALIGN_SIZE) static rt_uint8_t LED_thread_stack[512] __attribute__((section (".ccmram"))); rt_thread_init(&LED_thread,"LED",LED_task,RT_NULL,&LED_thread_stack[0],sizeof(LED_thread_stack),RT_THREAD_PRIORITY_MAX-3, 10); rt_thread_startup(&LED_thread); ```
大话西游2018
2021-09-18
请问,修改启动文件这段代码应该加在哪里?可以截图展示下?
4.4k
pjdu
24
54
